June 28th, 2012, 08:05 AM | #1 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Which battery Lithium/Ni/Acid/Gel ? Where did you buy yours?
I need a new battery for my 08 ninja . I have a totally dead solid state maintenance free GS Yuasa YTX&A-BS
I want to get another battery on the cheap .... but I dont want one that will be fried in a season? I got an acid battery for my jet ski and four wheeler but I have to fill the cells every year so I am shying t words a cheap maintenance free battery or a gel But I am cheap ... to cheap for gel it seems is this a decent one ? anyone have any luck with the cheapo ebay batteries? http://www.ebay.com/itm/GEL-GTX7A-BS...0827%26ps%3D54 |
June 28th, 2012, 08:21 AM | #2 |
ACFT,Trk, Cage, M/C mech.
Join Date: Jun 2012 Motorcycle(s): SV650 track,YZF450,GS1100ESDbought new in'83,BANDIT1200, Raced into ground '86 &'88 GSXR750's... Posts: 12
I just bought an el cheapo f $40 & a deltran tender...
For my project EL250... I have 11 years on my Bandit battery, by plugging in to the battery tender after Every ride. Park bike , lube chain, inspect, everything& plug-in I have 4 BT's , on lawn tractor, 8 yrs, SV 5 yrs.... They ( BTender) pay for themselves in 2 yrs!!!
Bicycle, & motor cross, the best skills Elevator!! |
June 28th, 2012, 08:36 AM | #3 | |
Intrepid Adventurer
the 2 amp is too much to leave on continually and the harbor freight one didnt seem to work :/ which battery tender do you use?> deltran has like ten different kinds they even hav one that can charge four batterys at once! |
June 28th, 2012, 08:39 AM | #4 |
Join Date: Nov 2011 Motorcycle(s): 1999 Honda VFR800 Posts: 93
i think the batt in my 2006 is dying & i think im gonna try this place:
http://www.batterystuff.com/powerspo...sYTX7L-BS.html i keep my bike plugged into a BT all the time too but i think sometimes they just die. however, my bike was used and i dont know how the batt was treated before i got it. i use the battery tender JR. it has the LED that flashes green when almost charged & then just stays green. |
June 28th, 2012, 08:44 AM | #5 |
Intrepid Adventurer
I just bought an absorbed glass matt type el cheapo battery on ebay.
http://www.ebay.com/itm/310410222808...84.m1439.l2649 I hope it holds up well the YUSA battery I took out of my bike was the original and it has been in the bike since I bought it and let it sit for the last 18months un attended . So no wonder it died. I read that the AGM batteries are the most versatile low maintenance batteries no adding acid and they are less fragile than the gel batteries. I guess gel batteries are deep cycle and very sensitive to over charging or surges |
June 28th, 2012, 08:53 AM | #6 |
There's no need to buy a charger that will charge multiple batteries. A Battery Tender Jr. is hard to beat and can be purchased on a good sale for $20. Yuasa has a version too that's similar and seems to be good piece as well. If by chance it goes bad you also don't loose a multi-charger that cost an arm & a leg.
June 28th, 2012, 08:58 AM | #7 |
Intrepid Adventurer
Lithium Ion Battery ??? | Jason5885 | 2008 - 2012 Ninja 250R Tech Talk | 21 | February 9th, 2015 06:11 PM |
[RoadRUNNER] - Is That a Shorai Lithium Iron Battery in Your Pocket? | Ninjette Newsbot | Motorcycling News | 0 | October 2nd, 2013 01:00 PM |
Another Lightweight Lithium Battery | icbm | General Motorcycling Discussion | 1 | February 18th, 2012 08:39 AM |
Get your own Lithium battery powered Tron cycle | mrlmd | General Motorcycling Discussion | 2 | October 26th, 2011 06:39 AM |
