January 21st, 2010, 01:45 AM | #1 |
self wrencher
Faster flashing signal
Anyone know how to build a flasher that would flash twice the speed of stock flasher (or an adjustable one)? I like the hyperflashing and think it's more noticable to cagers. Saw some circuits that uses the 555 chip..not sure if that will work in our case.
January 21st, 2010, 03:01 AM | #2 |
FORMER MOTORCYCLE RIDER
Join Date: Dec 2008 Motorcycle(s): Rode an 08 250r then rode an 08 ZX-6R until i totaled it on 7/10/10 Posts: 758
programable flash rate
http://www.customdynamics.com/trick_...#Trick_Flasher or the cheap way have different wattages front to back, mine flash fast after putting on 09 sigs (zx6r) |
January 21st, 2010, 07:39 AM | #3 |
self wrencher
I saw that 2 years ago. I'd like to build it for fun though. Prob cost $10 in parts...
I have all LEDs signals and with stock flasher it's solid light. Changed out with a no load flasher, it flashes stock rate. I'd like hyper flash rate Posted via Mobile Device |
January 21st, 2010, 09:43 AM | #4 |
IC2(SW)
See if you can bust open the electronic flasher...... and mod it
January 21st, 2010, 11:20 AM | #5 |
January 21st, 2010, 09:10 PM | #6 |
self wrencher
im in the medical field so i'm blind when it comes to electronic stuffs although this seems like a fun little winter project.... need to find a dictionary to find out what a potentionmeter means
January 21st, 2010, 09:14 PM | #7 |
January 22nd, 2010, 12:10 PM | #8 |
self wrencher
increasing value of resistor in the flasher relay causes it to flash faster or slower?
January 22nd, 2010, 12:45 PM | #9 |
I'm gonna guess that decreased resistance will yield a faster flash. When adding in LEDs (lower resistance than stock incandescent bulbs) you get a quicker flash, which is (one reason) most people need to switch flasher relays. Just a mildly educated guess though.
January 23rd, 2010, 11:56 PM | #10 |
self wrencher
Okay tried...failed. & gave up
ECU Flashing | garth285 | 2013 - 2017 Ninja 300 Tech Talk | 30 | July 13th, 2015 11:47 AM |
Dashboard flashing? | arnoldc6 | 2008 - 2012 Ninja 250R Tech Talk | 4 | March 27th, 2013 05:55 AM |
HELP PLEASE!!! Proton's now flashing on both sides | b4idie | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 11th, 2012 02:30 AM |
Help needed: Weird flashing rate | chokne | 2008 - 2012 Ninja 250R Farkles | 8 | June 28th, 2010 05:31 PM |
Higher flashing rate on new turn signals??? | Kitdog | 2008 - 2012 Ninja 250R Farkles | 10 | June 25th, 2010 12:17 PM |
