June 1st, 2010, 03:36 PM | #1 |
Guest
Posts: n/a
Anyone installed a remote start on the 250r?
I just finished installing an alarm on my bike this weekend. My first alarm install (took me about 8 hours!) I am now going to attempt to install the add on remote engine start module, but I can't seem to figure it out. Anyone here installed a remote start to their 250r? If so please advise.
June 2nd, 2010, 06:43 AM | #2 |
Hmmm... Not sure how well this would work for carbs. The remote start system can't pull and control the choke for you. Is it really worth the risks that come with it though.
June 2nd, 2010, 08:36 AM | #3 |
Guest
Posts: n/a
Carbs are no problem with remote start. I've had remot starts installed on almost all my toys and never had a problem, just never did the install myself. Here in socal I don't even need to use the choke! Not really a risk.
Posted via Mobile Device |
June 2nd, 2010, 10:05 AM | #4 |
Ther's always a risk with any vehicle without an automatic transmission and even some that do have auto (see below). Before you go looking for the "reply" button, let me explain.
I'm sure your using some sort neutral safety but all switches can fail or the controller could have clitch. Happens all the time. I had a mint 98 Mustang GT automatic transmission with all the bells and wistles including a viper alarm with prox sensor, remote start, window control modules, etc... Hit the remote start one morning and got up to get dressed for work while the car was warming. Needless to say I came out to leave and smoke was pouring out from the interior. Long story short...the remote start control module was melting away and nearly ready to catch fire. All I'm saying is it worth the risk? I could see a bike trying to start while parked in a garage and was accidentally left in gear. Just my
June 2nd, 2010, 06:05 PM | #5 | |
You can use my diagrams if it helps you set it up, and for the chock, maybe leaving it 1/2 way on at night can solve the problem? 2008+ Ninja 250r FULL Wiring Diagram here! |
June 2nd, 2010, 06:13 PM | #6 |
so if you don't need to use the choke to start/warm up the bike, why is it that you need a remote start? Seems to me, you can just start the bike when you're ready to ride and ride off w/o having to remote start it.
I don't get it. |
June 2nd, 2010, 06:49 PM | #7 |
Join Date: Jan 2009 Motorcycle(s): 2008 250R (Black) Posts: 298
The remote start needs to be hooked up at 2 points, to the ignition and the start relay. So, when you hit the start button, electricity goes through the ignition as if the key was being turned over. And electricity needs to be sent to the starter-relay to turn the motor over, which it does for a preprogrammed amount of time/seconds.
Get hold of the wire that sends 12V out of the ignition when the key is turned to "ON". Thats where you hook up the 12V from the remote switch. Same goes for the wire from the starter switch on your handlebar. You hook up the remote power to the wire that goes "out" from the real starter switch. Best is to get a hold of a wire diagram for the 250R, makes it easier to find the right wires without testing manually with voltmeter. Should also be explained better in the paper that you get with the alarm-kit, but feel free to ask if you wonder about anything! I installed an alarm with remote start/ignition switch once, not on the 250 tho. The thing i used most was the "ignition off" feature, which is pretty easy to fix, its just a grounded wire. Remote start, i never used so i disabled it, leaving it to only turn on the ignition. What if, someone accidently put your bike in gear while u were away(?), you always gotta check before, and then there is no points of having a remote start in my case. It ended up being more of a showoff gadget for friends, than actually useful to anything. I usually turned ignition on with the remote when i left from home, then when i parked somewhere i could lock the bike up, take all keys away and walk into for example a shop and turn of the bike/engine as i walked away from the bike. People will look a bit confused around them. |
June 2nd, 2010, 09:16 PM | #8 |
Guest
Posts: n/a
Guinss & John, thanks for your help. I am going to try to get this done over the weekend. Will post my results.
Dubojr, I understand your concern. I hope you didn't think I was trying to be rude with my reply. That was not my intention. I can see where you are coming from with the risk. I do understand the possibilities of what can happen. I just simply decided that for me it is a risk I am willing to take. I am not saying that I recommend everyone else to put a remote start on their 250. To each his own I guess. Kkim, Since the weather is mild here year round, I never really need to use the choke. Even though I don't usually use the choke I still like to start the bike and let is run for a few minutes to warm up. I guess I really don't "need" it just like most of the other farkles I added to the bike. I just like gadgets and I like tinkering with things. Just for fun I guess. |
June 2nd, 2010, 09:22 PM | #9 |
cool, Dave... just couldn't understand it from a warmup stand point.
I fully understand toys. have fun. |
June 2nd, 2010, 09:38 PM | #10 |
Mine got progressively worse. I absolutely need to use my choke now, though I can turn it down almost instantly.
June 3rd, 2010, 06:10 AM | #11 |
June 3rd, 2010, 06:14 AM | #12 | |
June 3rd, 2010, 06:38 AM | #13 |
This thread makes me want to install alarm and remote control myself!
*goes searching for it on internetshops* |
June 3rd, 2010, 07:10 AM | #14 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
What remote start brand are you thinking about? I've installed many in cars and might have some insight. My friend has a factory remote start on a 80cc scooter, seems strange but whatever floats your boat!
June 3rd, 2010, 10:22 AM | #15 |
Guest
Posts: n/a
It is a Spy 5000m. Here is the manufacturer web site: http://www.zmc.com.sg/product.php?ca...20Bike%20Alarm
It is a really nice system. It is a 2 way pager system with a 5,000 meter range. You can set the fob on voice alert or vibrate, and it has a multi color lcd screen with clock, etc. Seemed like a lot of features for the price and of course the remote engine start. |
June 3rd, 2010, 10:31 AM | #16 |
ah ok, spy 5000m, I was thinking of installing this alarm, but I am really concerned about the quality of this thing, I saw these going for 70$ shipped last month.
Spy 5000m, Beret 5000m, Voyager 5000m, why so many brand names for the same product? hummm ? MA004S.jpg Last futzed with by Alex; June 3rd, 2010 at 05:40 PM. Reason: fixed mongo pic |
June 3rd, 2010, 12:03 PM | #17 |
Guest
Posts: n/a
Yes that is the one. I also was wandering about the quality, however I read a few reviews on the other forums and also spoke to an alarm shop in Florida. This is the exclusive alarm that he installs on all motorcycles. He had nothing but good things to say about the alarm so I felt pretty comfortable. With anything out of China there are usually 1 factory who manufactures the same product for different companies and just puts a different name on it. With many of the expensive alarms from the big names you are just paying for their advertising. These $300.00 alarms probably cost .50 to make.
June 9th, 2010, 07:11 AM | #18 |
Actually, when i came to think about it, the 250R got the "must be in neutral to start"-feature. So, i take back my meaning about remote start not being safe. Im so close to ordering one myself.
Dave, did you get it installed yet? Was wondering about the difficulty on getting everything installed on the 250R, i have only installed it on a simple 50 cc myself. |
June 9th, 2010, 09:14 AM | #19 |
Guest
Posts: n/a
I was just thinking that same thing yesterday! The bike won't start if it is not in neutral so no worries about starting in gear. I should be finished tonight. I will post the finished product tomorrow most likely.
June 9th, 2010, 10:07 AM | #20 |
Yep, guess that is different than a cage application. Must have a clutch switch bypass for cages. That's what makes it a little unsafe.
I just start mine and by the time I have my gear and packs ready to go...the bike is ready to go. Could be intersting for $70 bucks though...!
June 11th, 2010, 04:39 PM | #21 |
Guest
Posts: n/a
Remote Start successfully installed!
The remote start is a success! We finished it yesterday. I will upload pics & more info over the weekend. We ran into a roadblock at first. I did not know that the new 250's had an immobilizer! We took care of that though with something called a 100 ohm resistor (I think that is what it is called) Anyway, it made the remote engine start work perfectly. The 5000m is a great alarm.
June 11th, 2010, 04:43 PM | #22 |
June 11th, 2010, 04:55 PM | #23 |
Guest
Posts: n/a
I am speaking of my 2008 250r. I confirmed that it does have an ignition immobilizer, unless the guy was wrong. Something about if all of the ignition wires have the same voltage it does not and if one of the wires has a lower voltage it does? When we first installed the remote start, the bike cranked over but would not start. If we put the key in the ignition and did the same thing the bike would start with the remote start. The installer and I called the guy who sells the alarm (who owns a motorcycle alarm shop) and he stated that this means the bike has an immobilizer. My install guy said he knows how to bypass this and then he got it working. I'm not an install guy, so I don't know, just going by what they said.
June 11th, 2010, 04:59 PM | #24 |
According to this schematic, I don't see an immobilizer.
http://www.mickeywebpages.com/users/...e_Dia_v1.1.gif |
June 11th, 2010, 09:25 PM | #25 |
Definitely no immobilizer. =/
June 12th, 2010, 08:08 AM | #26 |
Basically how the system works is:
When the key is in the "ON" position, 12V is allowed to reach the push-button, in this case, the "Starter Button". When the "Starter Button" is held, 12V is sent through "Diode B" and then to the coil on the "Starter Circuit Relay" which is in a N.O (Normally Open state). When the coil in the "Starter Circuit Relay" becomes energized, it becomes N.C (normally closed) creating a closed circuit and further allowing the "Starter Relay" coil to be energized, allowing 12V(with a maximum of 30A) to be send from the battery to the starter, and this cranks the engine. This circuit also send power to the ignition coils.. but I have an appointment at the clinic now. |
June 22nd, 2010, 10:26 AM | #27 |
Ninjette Indian
Did you manage to install the same? waiting for review from your side
June 22nd, 2010, 02:02 PM | #28 |
Jon, I believe way more than 30A goes to the starter, 100-200 when cold.
June 22nd, 2010, 02:06 PM | #29 |
June 22nd, 2010, 02:22 PM | #30 |
That's the "main fuse" for the entire bike and it supplies the white wire main battery bus and only the white wire, it's really not the "starter fuse" but it is located on the starter solenoid. The starter circuit is not fused. The drawing can be a bit confusing.
June 22nd, 2010, 02:27 PM | #31 |
The juice turning the starter doesn't go through a fuse. The juice running the relays does.
June 22nd, 2010, 02:43 PM | #32 | |
June 30th, 2010, 09:38 AM | #33 |
Ninjette Indian
waiting for reviews
July 1st, 2010, 07:46 PM | #34 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Dave is on Vacation. He won't be back for few weeks.
Sportisimoto USA is born. |
August 28th, 2010, 01:44 AM | #35 |
Join Date: Aug 2010 Motorcycle(s): 2008 ninja 250r Posts: 7
Remote start and alarm
Hi I'm new to the forums I'm in the middle of installing a viper 5900 security with remote start and digital tilt sensor. I have everything hooked up but can't seem to find a wire to get my tach signal for the remote start. I previously read someone said there was an immobilizer on these bikes. Any information would be appreciated. Ty.
Josh |
August 28th, 2010, 06:29 PM | #36 |
August 28th, 2010, 10:48 PM | #37 |
Re: help
Let me clarify I'm not looking for a wire for the tach it's self. I'm looking for a wire I can get a signal for the tach to program on the viper 5900. The feature reads the rpms and shuts down if over revving or under revving. On cars u either go to a fuel injector or the coil but no injectors on the bike and the coil wires didn't work. So if anyone knows of a wire on the bike that will work lemme know, ty
August 29th, 2010, 11:24 AM | #38 |
Join Date: May 2009 Motorcycle(s): 2015 V-Star 950 Tourer (Deep Blue) Posts: 570
This may be a silly question, but is there not a built in safety switch that turns the bike off when the kickstand is down while the bike is in gear? Does this not come into play when using a remote starter?
August 29th, 2010, 01:27 PM | #39 |
There Is a safety feature where the bike kills if in gear with stand down but if u wire the remote starts neutral safety switch to the neutral light then the remote start won't start unless in neutral and the bike will start with the stand Down in neutral.
August 30th, 2010, 12:55 AM | #40 |
Why would you start the bike in gear anyway? To use remote start, you'd have to leave it in neutral and the bike will start with the kickstand down as long as it is in neutral.
Remote start = headache | Hijakd | 2008 - 2012 Ninja 250R Farkles | 24 | June 3rd, 2017 03:17 AM |
DIY: Installing Spy 5000m Alarm Remote Start | Den | 2008 - 2012 Ninja 250R Farkles | 62 | November 25th, 2016 03:03 AM |
spy 5000m remote start problems | JohnA1989 | 2008 - 2012 Ninja 250R Farkles | 12 | April 24th, 2012 09:29 AM |
Aftermarket Remote Start/Security Modules | xTKx | 2008 - 2012 Ninja 250R Farkles | 6 | January 26th, 2009 09:05 AM |
