October 6th, 2011, 02:06 PM | #1 |
Join Date: Jun 2011 Motorcycle(s): 2002 ninja 250 Posts: 96
cluster not working properly after rain
my clutch cable went out last monday so it took me a couple of days to get the cable and replace it. by wednesday it was raining and today is the first bit of sun all week so I decided to take her out and test the cable.
first thing I noticed was the RPM was not moving from 0 so I checked the speedometer cable and it was fine. After about 40 seconds of mildly reving the motor, the dial started to work. same thing happened with the MPH dial. it didn't work at first but after a couple minutes of riding it began to indicate speed. lastly, the temp gauge only moves about an 8th of an inch and then stops but I know the bike is much warmer. I usually have a rain cover but it got torn from winds and it catching on something on the bike so it got kind of soaked. I don't see how water could have entered the cluster but is it possible the dials rusted in a matter of 2 days? |
October 6th, 2011, 02:49 PM | #2 |
Join Date: Aug 2008 Motorcycle(s): 2007 EX250 Posts: 133
Check and see if your ignition module or junction box is wet. That could affect water temp/tach. Speedo is just the cable...maybe it just got hung up somehow.
October 6th, 2011, 02:58 PM | #3 |
it sounds like the back of your gauge cluster is wet... leave the bike in the sun and let it dry out maybe?
October 6th, 2011, 05:01 PM | #4 |
I just rode the bike again after it sitting for a few hours. The rpm still doesn't work immediately and then cuts on. It seems like something is restricting the movement of the dials
October 8th, 2011, 03:09 AM | #5 |
I had the same problem after some condensation.
October 8th, 2011, 07:06 AM | #6 |
October 8th, 2011, 07:21 AM | #7 |
01 Ninja250 not starting properly | petersophy | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 29th, 2014 08:52 PM |
rain, rain, rain - still spring riding is a blast | redbike2 | Ride Reports | 2 | April 27th, 2014 08:49 AM |
How do I use the shock adjustments properly? | Monkeytofu | 2008 - 2012 Ninja 250R Tech Talk | 6 | November 17th, 2012 06:41 PM |
Left turn signals not working properly | maraci | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 16th, 2011 07:38 PM |
LED brake/tail lights not working properly... | sktrs_kpr | 1986 - 2007 Ninja 250R Farkles | 1 | April 8th, 2010 09:59 AM |
