October 22nd, 2011, 06:48 AM | #1 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
Cylinder base gasket replacement
When replacing the base gasket do you need to use a gasket cement like Yamabond or just use it plain?
October 22nd, 2011, 07:19 AM | #2 |
MOTM - Sep '18, Feb '16
You can use it plain .Or spray on copper tack. No Yamabond.Thick stuff is no good because the block is trying to move around. Clean the serface with a razorblade and break cleen. You want the serface as clean and scratch free as possable. Be carefull with the razor blase. Maybe a scotch brite to finish it off.
08 and up cylinder base gaskets | bruce71198 | Items Wanted | 3 | June 19th, 2014 07:48 PM |
Gasket, Exhaust Pipe C (11009-1667) fell apart? Replacement options? | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 8th, 2013 10:31 AM |
Head Gasket Replacement | tjkamper | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 13th, 2012 01:58 PM |
Gasket? | ladyrocket | General Motorcycling Discussion | 5 | April 26th, 2011 04:15 PM |
cylinder head cover - gasket | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 7th, 2010 04:22 PM |
