Old October 3rd, 2012, 12:16 AM   #1
Monkeytofu
I told you bro
Monkeytofu's Avatar
High temp spray paint coming off of my headers/pipes, what next?
so my headers are starting to chip and peel in high friction areas on my headers and exhaust pipes. I really love the look of the 250 with the stock exhaust so I'm thinking of repainting them, but what should I do this time? Should I pay someone to do it for me? Should I do it myself?
It's really a damn shame this is happening, my pipes stock when I first finished them but the paint is just not up to snuff.
What's the call you would make?
Old October 3rd, 2012, 12:38 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
plastidip
AFM #676
Supersports are for n00bs
Old October 3rd, 2012, 03:55 AM   #3
johnjohn
Motorcycle(s): Honda, Buell, Kawasaki, Suzuki, Yamaha
lol
johnjohn is offline   Reply With Quote
Old October 3rd, 2012, 09:23 AM   #4
CThunder-blue
ModMy250.com
CThunder-blue's Avatar
Paint is all about the prep work. Did you scuff & clean your pipes before you painted?
The www.ModMy250.com guy
Old October 3rd, 2012, 09:57 AM   #5
stealth250
Gearhead
stealth250's Avatar
+1
stealth250 is offline   Reply With Quote
Old October 3rd, 2012, 10:18 AM   #6
Monkeytofu
I told you bro
Monkeytofu's Avatar
Yup.
Put down a layer of primer, then sanded, and then painted with my normal high temp paint. The paint is holding well in most parts but I'm pretty sure a combination of other factors including weather and general use are contributing to this. I don't garage my bike so it's not hidden from the elements.
Edit: considering powder coating it this time or taking it to someone who does. Any ball park idea of what a job like that would cost? I'm guessing around 200 at the cheapest.
Old October 3rd, 2012, 10:48 AM   #7
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Primer failed. I don't know of any high-temp primers. Hi-temp paints I've seen are meant to be applied directly to the metal surface. Check out http://www.eastwood.com for some nice high-temp paints. However, if you're the least bit lean the temps of the exhaust at the head will be higher than any paint you can apply. Consider ceramic coating? Though, not sure why bother, the Ninja exhaust system isn't known for rusting out.
Old October 3rd, 2012, 10:51 AM   #8
GeorgeRYoung
Motorcycle(s): EX250, C10 Concours
Paint for stoves
Painted my fairly rusty headers, brush on enamel for the cast iron stove. Worked fine so far on the EX250:
GeorgeRYoung is offline   Reply With Quote
Old October 3rd, 2012, 11:34 AM   #9
CThunder-blue
ModMy250.com
You shouldn't have needed to primer the pipes. Sand/scuff/clean and paint. Even if you wanted to primer the pipes, you should have still sanded and cleaned prior to the primer.
Old October 3rd, 2012, 01:59 PM   #10
Monkeytofu
I told you bro
Monkeytofu's Avatar
Rustoleum makes a high temp primer for headers.
I'm considering ceramic. I mostly care about the aesthetics of my headers and exhaust pipes. It doesn't really matter in the end if our pipes are painted or not, I just don't to have to buy any headers other than stock since they're all so loud (even the area-p imo).
I did this too.
Sanded pipes down to metal, scuffed them up, primed, sanded, primed spots without much primer, sanded, painted, then clear coated. all high temp paint rated at 2000 and all the same brand.
Maybe I just didn't do it well enough but main issue here is friction with the headers and pipes taking paint off (at least on my pipes), not paint just flaking off by itself.
Old October 3rd, 2012, 02:16 PM   #11
bdavison
Wartown, USA
bdavison's Avatar
Unbolt everything and get it to the point that you just need to pull to have the can off. Now scuff/sand it up. Fire up the bike and get the exhaust good an hot(do not ride it), then (Carefully-Dont burn yourself.) remove the exhaust, and paint it while its still hot. The heat will help it cure better, and you get a better matte coating with no runs.
It doesnt really matter what you do, if you scrape the exhaust can up against something, it will chip off the high-temp paint.
Old October 3rd, 2012, 02:16 PM   #12
CThunder-blue
ModMy250.com
I would go with a high temp ceramic paint.
Old October 3rd, 2012, 08:02 PM   #13
FrugalNinja250
Those "2,000°F" ratings are fairly theoretical in the real world. They get them in closed environmental chambers under perfect conditions with no rain, road dirt, constant expansion/contraction due to thermal cycling, etc. Have you thought about just polishing them? (Referring to the actual exhaust pipes, the mufflers don't get near as hot.)
Old October 3rd, 2012, 08:24 PM   #14
Monkeytofu
I told you bro
Monkeytofu's Avatar
I don't think silver/ unpainted headers would look nice on my bike or else I would have done that. There's also the issue of rust forming on them if I just leave them without paint.
I'm kind of at a loss at what I could do other than pay someone to paint them with ceramic paint, or just try and repaint them with HT paint again. It's a shame black ninja 250 pipes in stock condition are nonexistent
Old October 3rd, 2012, 09:00 PM   #15
CThunder-blue
ModMy250.com
They sell ceramic paint for engines at autostores. I've used some and it holds up pretty well. I've also used some specialized ($40/qt) high temp black coating that can withstand heat from turbo manifolds. That worked really well, but prep is very strenuous. I media blasted the manifolds to get a uniform surface first. Then you spray it on and bake it at 400F. That's the initial cure. The final cure happens when you're boosting and the manifold gets to 800F. That coating held up very well, even to scratches and what not.
Old October 3rd, 2012, 10:14 PM   #16
have you heard an 18" QC system in person? It's the same volume as stock, nearly. Not that it matters because it's your bike and not mine, but still! Don't bash. They're darn impressive.
Old October 3rd, 2012, 10:24 PM   #17
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Had eastwood products too but sent them back before i put it on. Too late now for you but the auto boards tipped me off that...most of the time...it flakes. I sanded the pipe down to stainless and am real pleased with how it looks.
Old October 3rd, 2012, 10:31 PM   #18
Monkeytofu
I told you bro
Monkeytofu's Avatar
Sure I bet it's quiet, but stock is already too loud for me :P I end up coming home on weekends when a lot of people are sleeping (3AM or so) so it helps to be as quiet as possible so you don't piss off the neighbors/HoA
Also I love my dual exhausts <3
not sure how good it would look on my bike:
http://i.imgur.com/qzNwa.jpg
Hell, I might just do it because of the flaking paint and see what it looks like. It's not like the paint is going to get any better.
How'd you sand yours? It took me forever to get them down with sand paper.
Old October 4th, 2012, 07:46 AM   #19
rabies
time is running out....
rabies's Avatar
Motorcycle(s): pregen ninjari
if you want to paint headers and exhaust you need a ceramic based paint.
they make header paint. it holds up to a very high temp.
general high temp paint isnt the same.
it will all burn off or dry and flake off.
you need header paint yo. auto stores have it. usualy black/grey/whiteish
The King
rabies is offline   Reply With Quote
Old October 4th, 2012, 08:06 AM   #20
Yeah, you won't piss of neighbors with a QC system. But if stock is too loud for you, I guess I understand that. I was never personally a fan of the dual exhausts
Old October 4th, 2012, 09:33 AM   #21
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Dual exhausts are damn annoying
AFM #676
Old October 4th, 2012, 09:54 AM   #22
rabies
rabies's Avatar
x55678.3/4
The King
Old October 9th, 2012, 02:10 PM   #23
MasterCylinder
MasterCylinder's Avatar
Motorcycle(s): '90 ex250
Try a brand called "Stove Bright". It works wonders. I, and multiple others, use it on our turbo exhaust manifolds and it holds up just fine.
Just don't forget to prep good.
MasterCylinder is offline   Reply With Quote
Old December 17th, 2012, 01:59 PM   #24
exploring/carolina
exploring/carolina's Avatar
Painted the Ninja 250 exhaust system with 2000F Rustoleum primer/paint. It's starting to bubble/flake too.
Took the exhaust system off of an Aprilia Dorsoduro and had the headers & LeoVince decat ceramic coated at a local shop for $60. The ceramic coating worked out great.
exploring/carolina is offline   Reply With Quote
Old December 20th, 2012, 06:27 PM   #25
Ceramic coated for $60 you say? Huh. Maybe I'll do that with my headers this season. I want to get them coated so my exhaust bungs don't rust.
temp difference between headers bob706 2008 - 2012 Ninja 250R Tech Talk 7 January 25th, 2012 11:53 AM
Spray can touch up paint? Banzai General Motorcycling Discussion 10 May 11th, 2010 12:35 PM
Two Bros EX250 dual pipes+headers djpharoah Motorcycle-related 2 December 7th, 2008 05:02 PM
