July 24th, 2013, 09:56 AM | #1 |
Fighting Texas Aggie '08
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250r (Race), 2005 Kawasaki Ninja ZX-6R 636 (Track), 2005 Ducati Monster 620 (Street) Posts: 541
Ninja 250 Racers
What are you guys doing to make this little piggy the lightest it can be?
Looking to use my bike for endurance and sprinting as soon as this weekend, I have the next couple of nights to get the parts removed. Currently I have removed all of the non essential plastic parts, horn, cut the race fairings down so the clipons can sit lower. Removed the speedometer and the gas gauage (wasn't function anyway) and left in the tach. The bike has all of the normal racing/track parts on it (rear sets, clip ons, exhaust, air box removed, GSXR shock, front suspension). Bike is fully safety wired and ready to go, just looking to make her a little lighter. Thanks |
July 24th, 2013, 12:12 PM | #2 |
hack off the kickstand and bracket. Can't recall what the rules and regs with CMRA about hacking the frame. I just remember it saying it has to look like production. If hacking the frame is allowed, hack off the tail section just after the seat. Also, possibly hacking the front fairing stay and bend up some aluminum flat stock. Get rid of the rear brake reservoir and fill up a clear tubing with brake fluid. Only other way to lose weight is the rider. lol
Could shave down your top triple tree clamp. Dump the race plastics/fiberglass and make that **** out of some paper mache!! minus the catch can of course lol 415 chain conversion and aluminum sprockets.
July 24th, 2013, 12:35 PM | #3 |
i have all the unneeded cooling stuff removed (like the fan for example). you can use a smaller purge tank for your coolant since hopefully your bike isn't overheating. (racebikes are supposed to be healthy!)
swap the battery to lipo or a123 or whatever is a free 10lbs. the front fairing stay is too heavy, there are lots of bits you can take out in the center between the top frame tubes. leave the seat cross member- it helps with frame flex a lot. if you are in an unlimited class you can cut off the rear subframe for the passenger seat, thats like 10lbs maybe. you can replace the coils and mounts with coilover plugs. also 415 chain/sprockets save a few pounds. obviously all the emissions crap has to go. the front engine mounts where the radiator attaches has a lot of unneeded weight. but you can't modify that unless you are in unlimited rules. everyone here, including those in full stock class remove the kickstand and mount. it is a hazard to leave it on. you can remove a few lbs from the gas tank since you are removing the gas gauge.
July 24th, 2013, 02:01 PM | #4 |
Alex covered some good points I totally forgot.
You don't need to run a thermostat either so ditch the housing and run a straight hose. You don't need the front sprocket cover too. Titanium sprocket nuts.
August 3rd, 2013, 06:09 AM | #5 |
CVMA / AFM / M1GP #250
Join Date: Sep 2009 Motorcycle(s): 2009 Ninja 250r, 2011 Zero S, 2009 KLR 650 Posts: A lot.
Poop more.
Also if you're allowed to in the rules, you can skeletonize the wiring harness so all the headlight/turn signal/brake light wires and relays and fuses can be totally ditched. Some people drill out or custom water jet the rear brake rotor too. |
August 3rd, 2013, 06:15 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
my bike was the exact opposite of where your going. I had all the hardware for my heated gear, aftermaket HID's, radar detector, 4 usb charging ports and my tool kit under the seat. But my bike was slow down the straits, I wonder why
CVMA 250/300 Racers, help please | ahamay | Ninjettes At Speed | 29 | November 9th, 2013 08:19 PM |
Any 250 riders/racers gonna be @ Chuckwalla this weekend? | Nemesis | Ninjettes At Speed | 21 | September 12th, 2011 09:23 AM |
[motorcyclistonline] - Kawasaki’s Ninja 250 Gives Aspiring Racers a Head Start | Ninjette Newsbot | Motorcycling News | 0 | June 30th, 2011 07:00 PM |
[motorcyclistonline] - Kawasaki’s Ninja 250 Gives Aspiring Racers a Head Start | Ninjette Newsbot | Motorcycling News | 0 | June 30th, 2011 11:40 AM |
