Old January 27th, 2022, 05:51 PM   #1
Dallas127
Motorcycle(s): 2011 ninja 250r
2011 ninja 250r
I have a 2011 250r my son lost the key to it then I messed up the ignition because I'm not going to buy a new key or ignition. does the 100-ohm resistor on the gray wire work on 2011?
Dallas127 is offline   Reply With Quote
Old January 27th, 2022, 06:30 PM   #2
Sure, 100-ohm resistor is needed on grey wire.
You can also take key-code (printed near bottom-front of ignition) to dealer/locksmith and they can cut you brand-new key.
Old January 27th, 2022, 08:21 PM   #3
Dallas127
2011 ninja 250r
Thank you..... I probably would but the ignition and screwdriver&hammer got into a fight I'm sure you know which one won. I would buy another one but I'm putting everything on a go-kart.
Last futzed with by Dallas127; January 27th, 2022 at 08:25 PM. Reason: i forgot to say thank you
Old January 28th, 2022, 02:54 PM   #4
Here's some diagrams that should help you with minimal wiring for kart. For pre-gen '88-07 models, but same idea.
This one is drawn really well, but re-uses ignition switch.
Here's one that removed ignition-switch, but not drawn to schematic standards.
If you don't use starter-solenoid, make sure you get really heavy-duty starter-button.
NY 2011 Ninja 250R JFMNINJA400 New Members 12 December 10th, 2019 08:36 AM
New old 2011 Ninja 250R MLR New Members 11 February 14th, 2017 11:13 AM
