#1 |
Join Date: Jan 2012 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 347
So i went over to one of my friends house today, and as i was leaving, he saw a nail in my rear tire
![]() Whats the best way i should go about fixing this? Thanks ALOT. |
#2 |
You gots to get a new tire! They are tubeless. And you can DIY with the right tools.
#3 | |
Join Date: Dec 2008 Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike Posts: 890
#4 |
Inspect your tire first. It may not be that bad and a repair may be possible if the tire is still somewhat new and usable. Most tire manufacturers recommend only permanent repairs to be performed from the inside of the tire, using a combination patch/plug method. Repairs from the outside are considered temporary and should be repaired from the inside as soon as possible. The Tech Uni-Seal® Repair Kit has also been marketed by Honda, Kawasaki, and Yamaha with their own part numbers.
A good shop should be able to do a competent and permanent repair job. It could be cheaper than buying a new tire if it's not necessary. |
#5 |
Depends on where the nail is/was, how much life the tires had anyway, and how clean the damage was. Yes, it's sometimes possible to plug a tire. Yes, it's always a safer bet to just replace the tire, but that's something the rider has to decide for themselves. A bunch of "nail in my tire!" threads below:
http://www.ninjette.org/forums/showthread.php?t=53032 http://www.ninjette.org/forums/showthread.php?t=83786 http://www.ninjette.org/forums/showthread.php?t=77787 http://www.ninjette.org/forums/showthread.php?t=87676
#6 |
Okay, how much around would a shop charge to do that? And on CL, someone is selling their oem front and rear tires with 200 miles on them for 60, would it be better to do that? I think my rear tire might have a few k left on them, not positive. But thanks for all the responses so far guys, really appreciate it!
#7 |
Most motorcycle shops don't patch tires.
#10 |
Join Date: Nov 2010 Motorcycle(s): 2012 Ninja 250 Posts: 79
I never fail to get a nail in a rear tire somewhere between 500-1000 miles after installation, so if I were to always change them out I'd have more money in tires than in the bike. I use this instead:
http://www.stopngo.com/ They use mushroom plugs so they seal from the inside out and they work wonderfully for holes in the middle of the tread. I've used them on 3 rear tires that have lasted another 5k+ miles until I had to change them due to tire wear. I'm actually running one of these plugs on my 2012's IRCs. Got the nail at 1k miles and now have 2.5k miles on the rear tire and it hold air just fine and I run it at highway speeds for long periods multiple times a week. Hope this helps. |
#11 |
Pull the nail
Buy this: http://www.slime.com/shop/atv-screwd...lug-kit-21032/ And this: http://www.slime.com/shop/plug-pack-2034-a/ Ream the hole and put in a sticky string. Cut off the excess. Go on a long ride to warm up the tire and melt the goo of the sticky string to ensure it seals the well. |
#12 |
plugging a tire in an emergency is one thing. being cheap and not replacing a damaged tire is another.
#13 |
L8APEX
Join Date: Nov 2011 Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org! Posts: 233
A plug on a bike is like a spare on a car, temporary use only!
www.joemillersmoderngarage.com www.starr-cycle.com ***The most important concept of science isn't memorizing facts, it's observation of phenomena.*** ![]() |
#14 |
While I haven't encountered a situation needing a plug to the tire yet myself, sites like ADVrider have tons of posts from members that have ran plugged tube-less tires, sometimes till they're worn. If you do a good job plugging the hole, I don't see how it's any different than running a plugged car tire.
#15 |
Hey all, thanks for all the help. I just found OEM front and rear tires on CL that only have 200 miles on them, and i'm going to pick both of them up for $60. Good deal? I think so, anyways hope to get them in a few days.
![]() Another question, whats the best and cheapest way about putting on? I know I'm going to have to take it to someone...any tips? |
#16 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
I always plug tires for street use and then replace them before a track day. If I have time I'll pull the tire and patch from the inside, but honestly the snotstring plugs seem to be as good as anything. If a plug is done right, it'll last for thousands of miles. If a plug is done wrong, it will slowly lose pressure overnight or so....some people seem to think a plug is like filling your tire with nitroglycerine, but basic knowledge of tire construction should make it obvious that the process of a plug failing pretty much has to be less exciting than getting the nail in the first place, which you probably don't notice until a day afterwards anyway.
Posted via Mobile Device |
#17 |
Milkshake Drinker
Also, balancing a tire is MUCH easier than removing or installing them.
#18 |
~08 ninja 250~
Join Date: Feb 2011 Motorcycle(s): 08 ninja 250 Posts: 21
I had a nail in my front tire and got many conflicting responses so I emailed Dunlop n they do not recommend pluging it urself but to take the tire to a tire repair facility where they will do a plug/patch combo.. this is a permant repair whereas just a plug is a temp fix..
#19 |
Hey all, thanks again for the help! So, i gotta her fixed!
![]() Anyways, thanks again for all the help. ![]() Heres a pic of the new tire, sorry its not too clear, took it with my phone ![]() |
Nail Polish on rear tire -- damaging? | corksil | General Motorcycling Discussion | 51 | April 28th, 2015 04:20 AM |
I'm on the road and I got a nail in my tire | SSG54 | General Motorcycling Discussion | 5 | July 18th, 2013 07:07 AM |
Is this safe? (nail damage in tire) | Sicafied | 2008 - 2012 Ninja 250R Tech Talk | 11 | August 28th, 2011 06:39 PM |
fking nail man. | tinng321 | General Motorcycling Discussion | 22 | August 17th, 2010 05:40 PM |
Nail Question | BlueTyke | General Motorcycling Discussion | 9 | March 8th, 2009 02:47 PM |
