March 11th, 2010, 12:44 AM | #1 |
Carb screw holes
A story of warning to those that replace their carb screws. Make sure you get the right size and your carb threads are properly cut.
Since the OEM carb screws suck, I ran out to my local hardware store and grabbed some 4mm 0.70pitch button-head screws. Unfortunately they don't stock our 4x18mm, so I got some 4x16mm and some 4x20mm. Installed the 4x20 next time I was working on the carbs. I had to pull the carbs off for my current project and decided they were in need of some cleaning inside and out. I'm glad I did because little did I know, one of my screw threads wasn't completely drilled out/tapped. The diaphragm cap screw socket nearest the throttle linkage (top, right carb, right side, front) had been cracked when I put the slightly longer bolt in. Not bad enough to have the screw fall out but it could have been. Here's some pictures of what I'm talking about. First pic I'm pointing to the cracked area with the screwdriver tip. This is behind the throttle cable mounting bracket (incidentally, this is secured with red loctite). DSC04880.jpg DSC04878.jpg DSC04879.jpg Thankfully I don't seem to have been 'screwed' too bad by this mistake, but it's probably something to at least look for if/when you have the carbs off. It'd be unfortunate to lose a few carb screws on the road due to destroyed threads. Also suppose if it really broke the wrong way it could create an air gap for the vacuum diaphragm. Definitely feel that . Unfortunately my roomate's out. FWIW the 4x16 fit just fine in 13 of the 16 holes that are commonly opened on the carbs (4 per float bowl, 4 per jet needle/diaphragm cap). However 16mm is too short to be truly secure in the other three slots that require the screw to go through a metal mounting bracket (all three on left diaphragm cap). If you can find 4x18, use them! If not, take care which size you install.
Proud member of the Blue Army Last futzed with by Momaru; March 11th, 2010 at 11:14 AM. Reason: Spelling fail |
March 11th, 2010, 12:49 AM | #2 |
You are sleeping
Makes me want to go check what came with the kit..
<Yeah, it's a 250. LMFAO! Weaksauce |
March 11th, 2010, 11:15 AM | #3 |
Indeed, if you do get measurements for the supplied screws in (I assume) the factory pro kit, let us know. Might make the 'which kit' decision a little easier
March 11th, 2010, 02:16 PM | #4 |
IC2(SW)
That sucks!!
Good heads up thou |
[RoadRUNNER] - Pot Holes, Sink Holes, and Buckled Roads | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2014 03:01 AM |
Carb swap, setting mixture screw | bowerbird100 | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 5th, 2014 08:01 AM |
Carb screw allen head replacements | M42 | 1986 - 2007 Ninja 250R Tech Talk | 2 | July 27th, 2014 04:54 PM |
Is this screw with yellow paint the one for carb syncing? | Floki | 2008 - 2012 Ninja 250R Tech Talk | 6 | January 17th, 2014 02:54 PM |
Carb Sync Screw Replacement? | MasterCylinder | 1986 - 2007 Ninja 250R Tech Talk | 8 | April 24th, 2012 07:54 AM |
