February 27th, 2013, 09:12 AM | #1 |
Join Date: Feb 2013 Motorcycle(s): Frankenstein Posts: 49
Have I wired this correctly? (SOLVED)
Hi all, just stopping by to ask your opinions on my wiring. I'm building a bobber using a 2010 ninja engine with '90 carbs and a 21119-1229 CDI. I have had a good mooch through the forum but I can't find a diagram without the standard loom and fusebox.
Thing is I'm getting no spark, nothing. The pick-up coil reads about 100 ohms which I think is correct? I'm running the more modern coil-sticks (coil-in-cap) which seem ok, and the feed to the coils and the cdi comes in at 12v. WHich is making me thing I've either been sold a duff cdi or I've cocked up on the wiring. Last futzed with by RBN; March 4th, 2013 at 01:19 PM. |
February 27th, 2013, 09:28 AM | #2 |
Your problem is that your IC igniter (CDI) is wrong. The one you have, controls a pre-gen engine. The timing for the two engines are different. You need p/n# 21119-0096
March 4th, 2013, 12:36 AM | #3 |
What's the reason it won't spark though? Is the pickup coil different or something? It wouldn't run if the timing was miles out but it'd still spark.
March 4th, 2013, 12:49 AM | #4 |
have you taken care of all the appropriate safety kill switches lines? i think there is 2
March 4th, 2013, 02:24 AM | #5 | |
As far as I can tell the CDI has everything it needs 12v feed (I don't *think* this model had the anti-theft resistor did it?) wires grounded where needed etc etc. |
March 4th, 2013, 07:58 AM | #6 |
You could by-pass the CDI and test the coils by charging them and quickly opening the circuit before reaching ground (which is what the pick-up unit and the CDI do for each spark).
The coils work better with positive on one specific leg (top, I believe). http://faq.ninja250.org/images/a/a7/..._Schematic.pdf As you know, the pick-up coil needs certain gap to be able to send the pulse to the CDI. It would be great that you could borrow parts from a working pre-gen to test everything. Can feel your frustration, ...........don't give up
March 4th, 2013, 11:10 AM | #7 |
Turns out it was a duff CDI. By pure 1 in a million chance it turns out that the Yamaha XV250 has the exact same CDI (albeit probably with totally different timing) as I have access to a xv250 I was able to try the CDI and the spark is huge!
Never would have expected that bike to have the same unit, what are the chances of that? Here's where my friend noticed it was the same: http://www.auszookers.com/forum/view...445146#p445146 |
March 4th, 2013, 11:16 AM | #8 |
a CDI is a CDI, all its doing is charging the coils and then cutting power at a specific delay after the pickup coil is triggered. the difference between CDIs come from how much charge current the coils need, and what kind of delay is needed for timing. some manufacturers put extra stuff in (ranging from safety-kill management, all the way up to simple forms of traction control and launch assist)
March 4th, 2013, 01:24 PM | #9 | |
Either way I'll be returning this one and picking up another old EX250 one. |
[RoadRUNNER] - Heated Clothing: Getting Wired | Ninjette Newsbot | Motorcycling News | 0 | December 31st, 2014 03:11 AM |
So I wired up my after market LED turn signals... | justdrew | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 9th, 2013 06:53 AM |
Turn Signals not working correctly | aspenratt07 | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 1st, 2013 08:46 PM |
Akropovic Slip-on - Not running correctly | golayajay | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 18th, 2011 02:04 PM |
[crash.net - MotoGP] - Lorenzo airbag deployed correctly. | Ninjette Newsbot | Motorcycling News | 0 | November 20th, 2009 08:41 AM |
