September 26th, 2012, 01:07 PM | #1 |
time is running out....
Join Date: Sep 2012 Motorcycle(s): pregen ninjari Posts: 412
another led turn signal thread (wrong resistors?)
not sure if i got the right resistors.
the turn signals are led. heres the oem wiring on the left. ylw/blk new wires on the right. not sure how to wire in the resistor. heres what i was gonna go off of [ATTACH]03.jpg[/ATTACH] my resistor is dif. i could jus wire one side to the other but both sides of wires are red...??
The King |
September 26th, 2012, 01:16 PM | #2 |
Join Date: Sep 2012 Motorcycle(s): 98 Ninja 250 Posts: 7
A resistor is non-directional. It needs to be wired in parallel with the light. The LED light is polarized and needs + to +, - to -.
Code:
+12V ----+----| R LED+ R LED- GND ----+----| |
September 26th, 2012, 01:31 PM | #3 |
not sure at all what u said. i apreciate the response. sorry for being slow.
is this right?
The King |
September 26th, 2012, 01:41 PM | #4 |
Does that resistor have 2 wires from each end?
If so, then take the +12V from the bike and hook it to any of the 4 available wires. Then hook the LED positive (looks like yellow in your pic?) to the other red wire on the same side of the resistor as the +12V. Now hook the bike ground to one of the other two remaining wires on the resistor, then the LED negative to the last red resistor wire. Edit: like this pic- Last futzed with by jonglauser; September 26th, 2012 at 01:47 PM. Reason: adding pic |
September 26th, 2012, 08:16 PM | #5 |
werd. thank u sir. im sure this will help others in search results in the future
The King |
YOU'RE DOING IT WRONG image thread | adouglas | Off-Topic | 56 | March 23rd, 2014 03:53 PM |
LED Turn Signal problems | nestlesnipes | 2008 - 2012 Ninja 250R Tech Talk | 2 | February 8th, 2014 11:33 PM |
LED Signals and resistors help | Pacemaker | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 29th, 2012 07:12 PM |
4 LED turn signals and what resistors | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 1 | October 8th, 2011 06:05 AM |
LED turn signal problems | shadowskater | 2008 - 2012 Ninja 250R Farkles | 12 | August 14th, 2010 03:08 PM |
