Old October 13th, 2009, 08:43 AM   #1
austexjg
austexjg's Avatar
Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r
Oil change - forgot metal washer - help?
I did my own oil change today - I forgot to reuse the flat metal washer that goes at the bottom of the oil filter - only metal washer that goes over the filter bolt just under the filter.
I read somewhere that forgetting the washer could allow for the spring to push against the filter, making it less effective?
I plan on changing my oil frequently - can the washer not be used until the next time I do an oil change without causing problems?
This is a typical noob mistake, but I don't want to cause myself more problems in the future to save a new oil change.
If i don't replace the washer, will the filter fail?
If I replace the filter washer - will all the new oil drain out and will the filter be ruined?
I did not use a torque wrench, but I was careful and added minimal pressure when tightening the filter bolt.
Thanks for the help....
Last futzed with by austexjg; October 14th, 2009 at 08:24 AM.
austexjg is offline   Reply With Quote
Old October 13th, 2009, 08:56 AM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Good for you. Step one was trying it, step two now is learning from the mistake. Weather it is changing oil, getting naked, or major work get in the habit of laying parts out as you take them off. You will be less likely to forget something.
I plan on changing my oil frequently - can the washer not be used until the next time I do an oil change without causing problems? If i don't replace the washer, will the filter fail?
You should be OK especially if you put a decent filter in (has some structural integrity and not a roll of toilet paper). My first Ninja was a pre-gen I bought used and I changed the oil right way and found that washer missing. Who knows how many miles and oil changes it had been among the missing.
To replace that washer you have to take the filter our and you will dump all the oil. The chances of picking up some contamination if you try to reuse the oil just aren't worth it.
You don't indicate if this is a brand new bike, bought used with xx miles or what so hard to have a feel for when you would be changing oil again.
Before you ride again check for any leakage just to be sure. Then, before you change oil again get yourself a basic torque wrench. Especially if you plan on doing many DIYs or your own maintenance.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old October 13th, 2009, 08:57 AM   #3
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
Hey John,
I would drain the oil out, put the filter assembly back together with the washer. The filter should be fine. Now here comes the question to use the oil again or not? I am sure you will get lots of reuse and lots of dont reuse opinions. For the cost of 2 quarts i would put new oil. To save the cost you could drain the oil into a brand new pan that has never had dirty oil in it. I just think to get that drain pan totally clean of any little metal bits or dirt would be tough.
Old October 13th, 2009, 09:01 AM   #4
austexjg
austexjg's Avatar
I bought the bike with 1450 miles - I changed the oil becuase it had not been done at 500 miles (per manual) - I used factory filter from Kawasaki dealer and Royal Purple 10w-40 motor oil - I plan on Mobil 1 next time
I plan on doing oil changes regularly, will buy a torque wrench before next oil change.
Aside from leaks, what else should I keep an eye on?
Old October 13th, 2009, 09:07 AM   #5
g21-30
g21-30's Avatar
Do you have an oil leak from the filter housing? If not, wait until your next oil change. If you are worried, you can drain the oil, replace the washer, and reuse the filter. DO NOT REUSE THE OIL. NOTE: There is no way you're going to crush the filter, unless you can break the outer plate that the bolt goes thru!!!!
Old October 13th, 2009, 09:56 AM   #6
OldGuy
Live Life
OldGuy's Avatar
- ATGATT -
Old October 13th, 2009, 12:34 PM   #7
austexjg
austexjg's Avatar
I decided to do "the right thing" and pull out the oil filter and replace the washer I forgot. I did not lose that much oil - but then again the oil line was closer to the top line on the gauge, so this may have been the best thing overall. My mind would not stop thinking about it and since it was raining anyway, I decided to get dirty again. It took less than a minute to correct the rookie mistake - it will never happen again - and now my brother can do his the right way the first time, if he learns from my mistake.
Thank for all the input...
Old October 13th, 2009, 12:37 PM   #8
rockNroll
rockNroll's Avatar
Motorcycle(s): black
You did the right thing. Confidence is important when riding a bike and if you were gonna have worries about oil leaking, or any other problem stemming from the missing washer, fixing it and putting your mind at ease was the best choice.
Old October 13th, 2009, 12:56 PM   #9
agreed - i would have been thinking about it constantly whether it really mattered or not. now its out of your mind and you can focus on enjoying the ride.
Old October 13th, 2009, 01:25 PM   #10
austexjg
austexjg's Avatar
Now if the sun would come out - I want to ride - I have only put 80 miles on it, after a search that lasted weeks. But here in Central Texas, we need the rain BAD....
Old October 13th, 2009, 01:49 PM   #11
HKr1
IC2(SW)
HKr1's Avatar
I decided to do "the right thing" and pull out the oil filter and replace the washer I forgot....
That little voice is a pain in the butt sometimes...... Nag, Nag, Nag.
Old October 13th, 2009, 01:56 PM   #12
austexjg
austexjg's Avatar
And it sounds just like Mom....
Old October 13th, 2009, 06:52 PM   #13
Cedilla
Cedilla's Avatar
Motorcycle(s): 2009 Ninja 250 (sold)
Did you use Royal Purple car oil? If so it contains Molybdenum Disulfide, im not so sure if that should be used with a wet clutch or not, i would definitely look into that. I also would not go with very long drain intervals with Royal Purple as that moly can come out of suspension and clump up.
Cedilla is offline   Reply With Quote
Old October 13th, 2009, 08:08 PM   #14
austexjg
austexjg's Avatar
I called Royal Purple - talked to a guy in the tech dept. - he stated that RP is wet clutch compatible - includes the regular synthetic and Cycle Max. Guy seemed to be truthful, but how soon should I change oils before problems happen? Do you know from experience or read on a forum, because I think the formula changed to be wet clutch compatible? I don't want to ruin my bike because of a simple oil change. Thanks for the heads up...
Old October 13th, 2009, 10:26 PM   #15
Cedilla
Cedilla's Avatar
I don't have any experience with it, im just going by what ive read on the internet, in someone with RP says its okay you should be good to go, I still would not go for more than 3k before changing your oil.
I don't mean to spread any misinformation, just figured id give you a heads up, but I would trust RP before trusting the random babble ive read on the internet about it.
Old October 14th, 2009, 03:36 AM   #16
g21-30
g21-30's Avatar
Does it have "Energy Conserve" in the lower circle on the container? If so, it should NOT be used in the bike engine!
Old October 14th, 2009, 07:44 AM   #17
austexjg
austexjg's Avatar
The SAE circle ahs these abbrev. :
AP/SERVICE
CG-4
CH-4
CI-4SL
Cannot find the words "energy conserve" on the container?
Old October 14th, 2009, 09:51 AM   #18
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
It'd be hard to miss. The words would appear in the circular graphic that tells you the service grade.
Like this:
Old October 14th, 2009, 10:01 AM   #19
austexjg
austexjg's Avatar
No - that is not what the label on the bottle looks like - thanks for the photo.
Old October 14th, 2009, 08:43 PM   #20
headshrink
headshrink's Avatar
So you didn't trust us over at KF, or just doin' more homework?
Old October 15th, 2009, 07:22 AM   #21
austexjg
austexjg's Avatar
Just doing homework - information hoarder....
Old October 15th, 2009, 07:37 AM   #22
rockNroll
rockNroll's Avatar
I read your thread over there too... I think this one was more helpful
Old October 15th, 2009, 11:28 AM   #23
headshrink
headshrink's Avatar
As always
Just stick around here and you'll be fine.
I used to live over there, until Kelly invited me over here. Now I live here and visit there once a month or so. It was kind of weird that I even saw your origional thread over there.
missing the washer between my oil filter and the spring corralhollowkid 1986 - 2007 Ninja 250R Tech Talk 14 July 22nd, 2017 02:36 PM
WTS: 250R OEM oil change items (filter, orings, washer) Teh_K Motorcycle-related 4 March 24th, 2014 05:14 PM
Oil filter washer replacement? cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 18 June 19th, 2013 10:53 AM
Oil Filter Crush Washer Slono 2008 - 2012 Ninja 250R Tech Talk 4 January 24th, 2012 07:14 AM
Missing oil filter washer JokerSeven 2008 - 2012 Ninja 250R Tech Talk 2 February 21st, 2010 07:23 PM
