Old May 7th, 2009, 08:51 AM   #1
MrTiddles
Motorcycle(s): 2008 250R
250r Popping Out Of Gear
So once in a while my 250 pops out of gear, mainly in 2nd gear it seems, always during accel. Scares me to death, especially when I'm under semi-hard throttle.
Anyone else have this problem?
MrTiddles is offline   Reply With Quote
Old May 7th, 2009, 08:57 AM   #2
Apex
Livin' the Minimoto Life
Apex's Avatar
Not really. I do know that when it happens it is because I didn't make a solid shift.
Old May 7th, 2009, 08:57 AM   #3
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Sounds like your clutch cable or shifter needs some adjustment.
TrueFaith is offline   Reply With Quote
Old May 7th, 2009, 08:58 AM   #4
1hardryder4life
Motorcycle(s): Nothing
are you making a solid shift from 1st to 2nd every time? If not, it can often times slip down into nuetral if the shift from 1-2 is not solid.
If you are making solid shifts, then this probably wont be an easy repair. rounded gear dogs and bent or worn shift forks can be a costly transmission repair...IF it comes to that.
1hardryder4life is offline   Reply With Quote
Old May 7th, 2009, 09:01 AM   #5
Apex
Apex's Avatar
It could also be a simple shifter adjustment. The foot lever may be a tad high, and out of the range of his ankle movement. Lower it by a tooth or two, and see if that helps.
Old May 7th, 2009, 09:23 AM   #6
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
You either don't have it all the way in gear, it needs adjusted, or you bent a shift fork (or you have a blue bike).
Old May 7th, 2009, 09:27 AM   #7
Apex
Apex's Avatar
Originally Posted by CC Cowboy View Post
You ever don't have it all the way in gear, it needs adjusted, or you bent a shift fork (or you have a blue bike).
Dang those blue bikes!!!!
Old May 7th, 2009, 09:37 AM   #8
/moving to tech forum
Old May 7th, 2009, 10:47 AM   #9
MrTiddles
lol, I DO have a blue bike...
Anyway, I think it may be a clutch adjustment issue, my clutch handle seems to maybe not quite go all the way engaged when I let it forward. If that makes sense. I'll fiddle with it.
*edit*
Ok, I adjusted the clutch line and the shifter mechanism in ways suggested above, we'll give it a while and see if it helps. Thanks guys.
Last futzed with by MrTiddles; May 7th, 2009 at 12:38 PM.
Old May 7th, 2009, 12:48 PM   #10
Kolya1981
Generic User Title
Kolya1981's Avatar
Motorcycle(s): Green 2008 Kawasaki Ninja 250R, Slate 2009 Triumph StreetTriple R
I had this problem when I first got the bike. It would randomly pop out of gear even with the clutch handle adjusted correctly. Also, I had the problem where it would pop out of 6th into a false neutral. I initially thougt it was user error, but I started purposefully making sure I was shifting properly and still had the problem. I changed my oil early in, and the problem stoped so I never had the dealer check it out. When I got the 600 mile check up it started again, looked at my invoice and said "bulk 10W40 generic" under the parts list. I changed my oil imediately with kawi oil and it solved the problem again. So take that for what it is worth, but maybe the transmissions on these sr just very picky about oil? For me it only does it with the bulk oil they use at the dealership. I change to regular old Kawisaki oil and it fixes it.
Posted via Mobile Device
Kolya1981 is offline   Reply With Quote
Old May 7th, 2009, 02:14 PM   #11
MrTiddles
Awesome, I'm due for an oil change, so I suppose I can just shotgun this problem. Thanks for the suggestions, sir.
Old May 7th, 2009, 03:55 PM   #12
CC Cowboy
CC Cowboy's Avatar
Synthetic is the way to go.
Old May 7th, 2009, 04:09 PM   #13
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I have this problem . It happens under hard acceleration . Kinda finds a false neutral. I blame myself for it most of the time . It dose not happen when I am deliberate between first and second. It never happens in any other gear.
Old May 7th, 2009, 08:17 PM   #14
craha
ninjetter
craha's Avatar
I have the same problem, always thought it was my poor shifting. Didn't know that I could adjust the shifter foot lever to accommodate. Thought I had to replace the whole rearset to improve the ergos.
Any tips or pix to help make this adjustment?
PS-My bike is blue also!
craha is offline   Reply With Quote
Old May 8th, 2009, 04:12 PM   #15
adjustment pics in here... I won't hold you having a blue bike against you, but in the future, I wouldn't advertise it either!
http://www.ninjette.org/forums/showthread.php?t=15136
Old May 11th, 2009, 09:15 AM   #16
djindia23
Ride or Die Ninja
Motorcycle(s): Blue Ninja 250R (the fastest color)
blue 250s are the fastest.... dont listen to these guys!!! lol...
djindia23 is offline   Reply With Quote
Old May 11th, 2009, 09:26 AM   #17
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Not when they are no in gear.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old May 11th, 2009, 09:34 AM   #18
Snake
Snake's Avatar
I had this problem before and it stopped doing it when I tightened the loose chain. Check your chain and see.
Old May 11th, 2009, 01:56 PM   #19
MrTiddles
Interesting. I'm due to take the bike in for a dealer maintenance, still have some money on that 'plan' i got transferred from the original owner. Anyone have tips on adjusting the chain themselves?
popping noise jcsalazar 2008 - 2012 Ninja 250R Tech Talk 13 October 25th, 2014 03:30 PM
Popping the clutch dcx4610 Riding Skills 14 October 10th, 2012 06:08 PM
Popping during deceleration chikenstrips 2008 - 2012 Ninja 250R Tech Talk 5 April 25th, 2012 07:00 PM
Popping on deceleration... Skippii 1986 - 2007 Ninja 250R Tech Talk 26 October 3rd, 2011 02:34 AM
My bike kept sputtering, exhaust made a popping sound, first gear barely moves? Bostonninjabastard 2008 - 2012 Ninja 250R Tech Talk 6 May 11th, 2010 06:21 AM
