Old December 12th, 2016, 08:23 AM   #1
mediace
Motorcycle(s): el250
Adjusting AirFuel screw
EL250
Adjusting Air Fuel screw with idle screw both run at 1200+-
Engine already Warm up
Done Valve adjusting
Running test/adjusting one at a time
Carb one
run adequately at settings 2 1/2 turn, set to 2 3/4 turn
Carb two
Problem to run smoothly at same idle screw setting (default at 2 1/2 turn)
Need to increase throttle for engine to run
What is possible cause..?
Thanks in advances
mediace is offline   Reply With Quote
Old December 12th, 2016, 09:12 AM   #2
Blockage in idle mixture passages on carb #2 would be my guess.
Have you synced the carbs? I would try that and see what that shows you. If there is a problem it's going to take significant adjustments to get them close. At that point it's showing you they need to come off and be gone through.
Old December 12th, 2016, 09:37 AM   #3
mediace
Done bench sync and will do manometer sync after try cleaning it again thoroughly.
Old December 12th, 2016, 11:10 AM   #4
Be sure to remove the idle mixture screws and confirm a spring, washer, and o-ring, on each. The o-ring can tear and get stuck in the passage. Spray cleaner through the passages and confirm they are open.
Float levels should also be checked, as well as removing and carefully cleaning all the jets and other passages.
Old December 13th, 2016, 04:40 AM   #5
mediace
it seem my bike will have different vac pressure when throttling from idle position. possible butterfly valve leaking/gap or pilot jet or something else that i'm not so sure.
Done idling manometer check and settle for now.
Adjusting clutch. ZeroGravity360 2008 - 2012 Ninja 250R Tech Talk 16 May 21st, 2016 04:40 PM
2008+ Ninja 250 Carburetor Screw size, allen screw size! Runeknight95 2008 - 2012 Ninja 250R Tech Talk 4 March 2nd, 2015 11:49 AM
Adjusting headlights? uKER 2013 - 2017 Ninja 300 Tech Talk 2 July 8th, 2013 07:50 PM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
Help with adjusting the values Ingersoll 2008 - 2012 Ninja 250R Tech Talk 2 January 14th, 2010 08:08 AM
