Old October 12th, 2021, 06:46 AM   #1
Topaz
Topaz's Avatar
How to remove glue goo left by removed tank pad?
Hello. My tank pad was peeling off a bit and was letting water and dirt come under it so I took it out.
Now I'm having a hard time to remove the glue goo that it left on the tank.
I tried general purpose cleaner and alcohol. My tanks is still shiny and scratch less so I don't want to go too hard on it.
Any suggestions appreciated!
Old October 12th, 2021, 06:58 AM   #2
I use mineral spirits, AKA Varsol, AKA paint thinner. Not lacquer thinner!
Old October 12th, 2021, 07:13 AM   #3
Also try this stuff. My wife uses it to remove labels from jars she's going to re-use for other things.
https://www.amazon.com/dp/B009M14C4S/
Old October 12th, 2021, 02:31 PM   #4
Topaz
Topaz's Avatar
Thanks!
Old October 12th, 2021, 03:17 PM   #5
ScarabLord
Definitely try Goo Gone!
ScarabLord is offline   Reply With Quote
Old October 18th, 2021, 02:54 PM   #6
VaFish
VaFish's Avatar
MOTM - Jan '16
Third vote for Goo Gone. Great stuff.
If using it on a painted surface wash with soap and water after the goo is removed.
Old October 19th, 2021, 10:35 AM   #7
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
WD40 or whatever flavour you have locally of similar stuff. Spray on agitate & it meltsvright off, no harm to your paint ��
Old January 3rd, 2022, 08:02 AM   #8
TonyLambert
Motorcycle(s): As of now, None but had bmw 100rr 2016 and the Vulcan 650s
Let me know If it will work. I got a long scratch on the center bottom of the gas tank. Went to the garage guy he suggested not to remove it. Otherwise, while clearing it the surrounding area paint will also be affected. So, I hide it with a tank bag that I had ordered from Viking bags.
TonyLambert is offline   Reply With Quote
Old January 3rd, 2022, 08:06 AM   #9
TonyLambert
Old January 4th, 2022, 05:32 AM   #10
Topaz
Topaz's Avatar
@TonyLambert
The goo gone worked nice. I didn't have any scratch on the tank. I only had to remove the glue from the old tank protector, which the Goo Gone did just fine and with not much effort.
Yes, a nice tank protector may hide that scratch of yours, or at least most of it.
Some pics, although not very good. One before removing the protector. At the top you can see the color is different because it was peeling off.
Once before using the Goo Gone, and one after.
I ended up with some scratches. I guess those were caused by dirt coming between the protector and the tank when it started to peel off.
By the way, the protector was a One Design, in case you want to avoid the brand. I know it's a good brand, but it didn't stick well at the point where the N300 makes a little edge in the tank. That's where the peel off started.
I will try a TechSpec next.
Old January 4th, 2022, 06:09 AM   #11
TonyLambert
@TonyLambert
Thanks for the suggestion. Will definitely try it soon and share my experience!
DIY: Super-Secure Gas Tank Holder (for when your tank is removed) headshrink 2008 - 2012 Ninja 250R Tech Talk 21 June 16th, 2014 01:20 AM
New Upgrades - Fender Eliminator, Tank Pad, Tank Overlay Stickers bbjminardo 2008 - 2012 Ninja 250R Farkles 7 March 22nd, 2013 03:51 AM
Anyone removed left hand controls whylee Ninjettes At Speed 12 August 26th, 2012 10:43 PM
How To: Remove Tank Pad MotoED General Motorcycling Discussion 4 March 7th, 2012 12:13 AM
Need adhesive/glue for tank pad davidgz General Motorcycling Discussion 3 September 7th, 2010 05:55 PM
