Old April 8th, 2012, 07:25 AM   #1
rich3389
96 ninja keeps dying?
I bought a 96 ninja 250 w/ 12k miles. It ran perfect for a few days then it would randomly die when warmed up. I had the carb rebuilt and changed the spark plugs and the problem still persists...
Problem: runs fine until warmed up, then will stall at idle, idle is set at 1500-2000 rpms, no amount of throttle will keep it running. And will not start until cooled down.
Also noticed that the left carb seems to leak gas into the head when bike sits a while off, even after the carb rebuild, related problem maybe?
rich3389 is offline   Reply With Quote
Old April 8th, 2012, 08:39 AM   #2
Welcome to the site!
Did you rebuild the carbs?
Crack open the gas tank after it dies and see if the engine re-starts and works normally.
If so, the tank ventilation is compromised and gas can't flow down.
The second easy thing to do is to verify the level of the fuel inside the bowl of each carb by connecting a transparent hose (U-shape) to the drain nipple, open it and checking the level while the engine is working.
Old April 8th, 2012, 10:49 AM   #3
rich3389
I did rebuild the carbs
I also tried the opening the gas cap trick with no results...
The problem seems to occur once the engine is warmed up, it will start to spit and sputter then die.
Old April 8th, 2012, 07:51 PM   #4
It could also be valves out of adjustment, which changes with temperature.
A mix that is good for a cold engine may be bad after it warms up.
It seems that the mix is over-rich for low rpm's, unless it also happens at higher rpm's.
Are you sure that the choke is fully releasing the carb's plunge when off?
Old April 8th, 2012, 08:37 PM   #5
Running fine at start-up and then having issues when warm is a classic symptom of rich mix. Also, carb cleanings do wonders on carb'd bikes.
Old April 9th, 2012, 04:53 PM   #6
rich3389
UPDATE: I took the bike out today and it seems that if I keep the throttle low, the problem seems to be non existent, it when I give it 60%+ throttle when it starts to hesitate and die.
Old April 9th, 2012, 05:05 PM   #7
Check your intake for leaks.
basically, at idle, spray various parts of the intake with WD40, and if the idle shoots up momentarily, that part that you just sprayed is sucking in unfiltered air.
Just Dying to Ride... nickjpass Ninjettes At Speed 39 March 25th, 2015 01:51 PM
250R dying tsmith3605 2008 - 2012 Ninja 250R Tech Talk 4 August 14th, 2013 01:35 PM
2005 Ninja 250r Dying while riding? Aeather 1986 - 2007 Ninja 250R Tech Talk 44 October 9th, 2012 10:32 AM
Random Dying? Coolbpf 1986 - 2007 Ninja 250R Tech Talk 8 July 21st, 2012 08:39 PM
Bike dying on me at stoplight ... Davis937 Riding Skills 11 April 18th, 2011 01:21 AM
