Old October 7th, 2010, 02:10 PM   #1
kn250
Motorcycle(s): 2009 kawasaki ninja 250r
Unhappy smoke out of the exhuast
today i relize that i see bkack smoke out of my muffler but i ride about 20min i star see white smoke so i dont know what i really i need help and one thing my gas drop pretty fast the smok only come out when im hight rpm every time i shift gear need help asap tjanks
kn250 is offline   Reply With Quote
Old October 7th, 2010, 03:21 PM   #2
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
Have you checked the oil? Is it running through oil very fast?
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old October 7th, 2010, 03:22 PM   #3
kn250
how do i know or where i look at im new at this stuff
Old October 7th, 2010, 03:36 PM   #4
Viper-Byte
Viper-Byte's Avatar
There is a sightglass on the right hand side of the bike, it has a high and low mark. (needs to be checked when the bike is level, not on side stand)
Old October 7th, 2010, 03:43 PM   #5
kn250
i saw that when the bike is on kick stand its low but u out the bike straight up its full i dont have a bike stand hope that work. what should i do if low
Old October 7th, 2010, 05:30 PM   #6
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
White smoke usually means coolant is mixing in with the fuel. You might have a coolant leak, not oil. Oil is usually a black smoke, not white. Check your coolant level, if it seems low then you might want to get your engine checked. If it's a blown head gasket (most typical place for a coolant leak) then it can cause more problems then just white smoke.
sombo is offline   Reply With Quote
do i use the stock exhaust gaskets with areap exhuast? rabies 1986 - 2007 Ninja 250R Tech Talk 4 September 27th, 2012 06:18 PM
WTB: 2008 rearset and exhuast USMCEvan Items Wanted 11 January 13th, 2012 03:45 PM
Area P Exhuast Hanger cbowman78 2008 - 2012 Ninja 250R Tech Talk 2 November 2nd, 2010 12:48 PM
