August 27th, 2012, 06:23 PM | #1 |
Join Date: Apr 2011 Motorcycle(s): '09 250R, '13 CBR500R Posts: 709
most miles travelled on 1 full tank?
what's the most miles you've gone done on one full tank? add details on riding style and commute type city/hwy.
so far longest i've managed is 166 miles on one full tank. i like to ride her hard, all the way to redline as much as i can. mix of city/hwy commuting to work. |
August 27th, 2012, 06:29 PM | #2 |
Join Date: May 2012 Motorcycle(s): Ninja 250 and Gsx-R 750 k8 (out of commission) Posts: 482
most is 188.. ride pretty aggressive too.. mainly streets to get to work
Omoplariangle-bar |
August 27th, 2012, 06:57 PM | #3 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
I've done around 230 and that was 90% highway 10% city.
I usually fill up at the end of the workweek so I usually don't go over 200 on each tank and I add 3.xxx gallons to fill. |
August 27th, 2012, 07:26 PM | #4 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
Makes me feel better knowing I'm almost on dead E and it's only been 170 miles
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
August 27th, 2012, 07:31 PM | #5 |
Fast-Guy wannabe
MOTM - Jan '13
230 as well
August 27th, 2012, 07:33 PM | #6 |
Join Date: Jun 2012 Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F Posts: 534
I've got no clue.
August 27th, 2012, 07:33 PM | #7 |
Join Date: Mar 2012 Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250 Posts: 237
I normally fill up at 200 but I've gone 230 before and had to use the reserve tank and I ride my bike hard
August 27th, 2012, 08:53 PM | #8 |
250! When it was bone stock and I was learning, it returned about 63 mpg. I got to the reserve at 250. Now I fill up at 200 and it works great.
August 27th, 2012, 08:53 PM | #9 |
Winging It In Life
Join Date: Aug 2011 Motorcycle(s): 2010 250R; 2011 250R (sold) Posts: A lot.
I always fill up at around 200 miles. My commute is mostly highway, but I'd peg the entire 50+ miles one way as 40% city/60% hwy.
I think the most I've pulled out of a full tank of gas was around 220 miles.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015) 2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current) |
August 27th, 2012, 08:59 PM | #10 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
stock used to get 200-210, after area p system and rejet, 180-200. mostly freeway.
August 27th, 2012, 09:10 PM | #11 |
Join Date: Aug 2011 Motorcycle(s): Honda Elite 110 (deceased), Green 2012 Ninja 250 (sold on Pi day); Grey/Green 2019 Ninja 400 ABS Posts: 238
I'm on 209 right now and have at least another 25 worth in the tank.
August 27th, 2012, 09:15 PM | #12 |
ninjaholic
Join Date: Jun 2010 Motorcycle(s): 09' SE 250R (sold), 03' ZX-6R, 99' XL1200C SP Posts: A lot.
I typically get about 200 per tank... depends on how I ride... I get a little more if it's just back and forth to work. I live and work on a military base, so no hard riding there and I only live 10 miles from work.
09' SE Ninja 250R $2,547.83 worth of mods installed... come on Unregistered, you know you want to know what? Check my Blog "Modification List" |
August 28th, 2012, 05:13 PM | #13 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
The most i've ridden on a single full tank was 181. Filled back up with 3.64 gals. I rarely ride to anywhere near empty.
August 28th, 2012, 05:27 PM | #14 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Just did 250 miles on a single tank coming back from a trip to St. Simon's Island, GA. Was an awesome trip running through the backroads of GA. Ran 55-75mph pretty much all the way. Bike has 20,000 miles on it. Bone stock.
August 28th, 2012, 05:34 PM | #15 |
cool, great to know that I have about 40-60 miles left to go before empty. always gets me a little nervous when reaching about 150 miles.
August 28th, 2012, 05:45 PM | #16 |
Wartown, USA
Just bear in mind that at 250 miles, it was down to running on fumes...literally. I could feel it starting to starve out as I pulled into the gas station.
I'd say 200 is pretty safe, unless you are really aggressive with the throttle. Your mileage may vary. LOL |
August 28th, 2012, 06:07 PM | #17 |
Boring is my middle name.
Join Date: Aug 2011 Motorcycle(s): '09 Ninja 250r Posts: 258
I've gone 187 miles on a tank. I definitely could have gotten past 200 though cause when I filled up it took 3.6 gallons.
August 30th, 2012, 08:35 AM | #18 |
One Loyal Fox
Join Date: Apr 2012 Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R Posts: 869
Furthest I went was 185miles on 3.30 gallons, so I could have easily broken 200..extrapolating..could have gotten 269 miles theoretically.
On a different ride, I went on one long continuous no traffic ride and got 174 miles on 2.8 gallons, so extrapolating that, I could have gotten just shy of 300 miles on a tank. However, I won't ever see those numbers because I'd rather not run the risk of running out, so I always fill around 175miles or so.
My riding blog! Check it out if you are bored!aninjaridingpandabear.blogspot.com RIP Alex 8.10.12 |
August 30th, 2012, 08:52 AM | #19 |
My record is 220 miles before having to switch to reserve and find a gas station. This was mostly steady highway riding.
August 30th, 2012, 08:52 AM | #20 |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
210 and i ran out of gas on interstate 95 lol
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
August 30th, 2012, 09:05 AM | #21 |
Join Date: Sep 2011 Motorcycle(s): 1986 Goldwing, 1996 CR500, 2011 Ninja 250, 2009 Harley Heritage Softail, 1941 Suzuki Gerbil 250 Posts: 427
The most miles I had from one tank was 267.9 from a 4.2 gal fill up. I was trying for best mpg that tank though. I rode 90% surface streets and 10% highway. On surface streets I kept it to 40-45 mph and on highway 60-65 mph. I coasted to stop lights and shifted at 5-6k. The bike is stock (except for frame sliders and tail bag, lol).
I know there's a 7th gear here somewhere... Changing to 15T/41T, now I'll get that 7th gear, lol. |
August 30th, 2012, 09:25 AM | #22 |
Join Date: May 2012 Motorcycle(s): Currently: 2012 Honda NC700X; Previously: 2010 Ninja 250R Posts: 47
I've pushed 230 before filling up. I looked in the tank and saw a bit of gas still which makes me think I could get near 250. It was probably close to 65mpg. This was early on in my motorcycling life when I was afraid to push the higher RPMs and was easy on the throttle.
August 30th, 2012, 09:42 AM | #23 |
My estimated mpg has been 55 mpg.
August 30th, 2012, 10:01 AM | #24 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
I got 130 on my 6r once lol
about 210-230 when I had the 250
----> My Youtube! <---- Unregistered, watch my youtube page! |
August 30th, 2012, 10:12 AM | #25 |
I think I managed to squeeze out 275 on one tank when bone stock. Now I get about 190-205 on one tank with all the mods and riding hard.
August 30th, 2012, 10:27 AM | #26 |
Join Date: Jan 2012 Motorcycle(s): Ninja 250r - Track whore, Ninja 300 - SOLD, KTM RC390 - Orange Hulk, Ducati 899 Panigale - Red Devil. Posts: A lot.
375kms I think is the max... About 235miles...
August 30th, 2012, 10:41 AM | #27 |
Join Date: Mar 2012 Motorcycle(s): '14 Honda NC700X; '14 Honda CRF250L; '07 Lifan 200 Posts: 623
262 and I ran out of gas...switch was already set to reserve! Ooops! It was my FIRST full tank of gas on my 2007 Ninjette. Now I fill up at 215ish.
August 30th, 2012, 11:13 AM | #28 |
Join Date: Jun 2012 Motorcycle(s): '13 Ninja 300 Posts: 4
This is a dumb question, but how do you switch to the reserve tank?
August 30th, 2012, 11:59 AM | #29 |
Join Date: Mar 2012 Motorcycle(s): 2012 Ninja 250 J Posts: 18
Don't the new Ninjas have no reserve? If they do, I'd like to know because I have a 2012 model too!
August 30th, 2012, 12:26 PM | #30 |
New gen has no reserve
August 30th, 2012, 01:20 PM | #31 |
Certified looney toon
MOTM Jul '13, Jul '14
According to my mpg app, best run was 213 miles and I average about 53 mpg. Though I usually fill up before its empty (typically around the 200 mark) so never really pushed to see her true range.
When I first got my new gen the reserve was one of the first things I looked for. Le sigh, not to be had.
August 30th, 2012, 01:27 PM | #32 |
Track Clown
MOTM - Sep '15
I have gotten well over 200 miles, this is my route to work every day(50 miles one way):
August 30th, 2012, 01:41 PM | #33 |
@cbinker is that as fun as it looks??
August 30th, 2012, 01:54 PM | #35 |
Ninjette Fanboy
Join Date: Jun 2012 Motorcycle(s): 2008 Ninja250 Posts: 307
Anywhere between 130 to 220 miles - depending on road and riding conditions.
I think half the gas evaporates and vents through the gas tank...and mocks me by that annoying gas tank whistle....lol |
August 30th, 2012, 05:18 PM | #37 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
i got to 190 miles today, filled up 3.5 gallons at the gas station and i always fill up with it on its side stand
August 30th, 2012, 06:11 PM | #38 |
Join Date: May 2009 Motorcycle(s): 04 ninja 250, 05 zzr 600 (sold), 07 cbr600rr Posts: 319
i rode over 43k miles on an 04 and i used to get 240 to 250 miles before i switch to reserve...one time i got closed to 290 before reserve......and then another 40 before i start running on fumes...
i usually fill up about 4.2 gallons when i hit reserve... |
August 30th, 2012, 07:08 PM | #39 | |
Join Date: Jun 2012 Motorcycle(s): 09 ninja 250r Posts: 191
I am 30 miles away from school and i found that annoying after a while. I always fill mine up when it shows to be a quarter before E..about 3.8 gallons. Got an average of about 40 mpg...huh thats pretty bad actually. But then I do shift at about 7k.
"trust me, I am not a lawyer." |
August 30th, 2012, 09:17 PM | #40 |
Join Date: Nov 2011 Motorcycle(s): 2012 ninja 250 Posts: 296
Posted via Mobile Device
[visordown.com] - One tank of fuel, 520 miles | Ninjette Newsbot | Motorcycling News | 0 | September 9th, 2013 12:00 PM |
How many miles do you normally go per tank? | austinm911 | General Motorcycling Discussion | 76 | July 7th, 2013 04:47 PM |
Fuel Tank never get full? | Brently7785 | 2008 - 2012 Ninja 250R Tech Talk | 17 | August 30th, 2011 03:30 PM |
How many miles per tank? | Yasko | 1986 - 2007 Ninja 250R Tech Talk | 25 | March 27th, 2011 09:09 AM |
[topix.net] - BMW hunt for most-travelled GS | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 07:50 AM |
