July 10th, 2009, 03:12 PM | #1 |
Join Date: May 2009 Motorcycle(s): 2009 Ninja 250R Posts: 8
Optimal RPM
This may be an uninformed question but what is the best RPM for highway. I realize it should be below redline. I just read people talk about how the Ninja can handle highway speed but didn't know what a good cruising RPM was.
July 10th, 2009, 03:18 PM | #2 |
That would depend entirely on the speed you need to travel.
Optimal for what? |
July 10th, 2009, 03:24 PM | #3 |
If I travel for several hours nonstop between 60 and 70 mph what is the best RPM range? This is beginning to sound like a math problem
July 10th, 2009, 03:31 PM | #4 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
whatever revs your turning in 6th gear is perfect.
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
July 10th, 2009, 03:39 PM | #5 |
I'd do it in 6th gear... that would make the rpm and vibration bearable and assure you'll arrive with your fillings intact.
6th for better fuel economy (and sanity), downshift to 5th if you need more power. |
July 10th, 2009, 03:45 PM | #6 |
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 29
75-80mph im hitting 8-9grand for 45mins and its almost unbearable vibration and whine. Backed down to 60-65 around 7-7500....
July 10th, 2009, 03:50 PM | #7 | |
IC2(SW)
Thought 9000rpm was 85 on ours (indicated), purrs like a kitten. Maybe it's just allot smoother than the R1, and I dont notice |
July 10th, 2009, 04:33 PM | #8 |
July 10th, 2009, 04:43 PM | #9 |
Join Date: Feb 2009 Motorcycle(s): '09 Candy Thunder Blue Ninja 250R Posts: 618
July 10th, 2009, 05:02 PM | #10 |
like anything else, it's a compromise to appeal to the broadest buyer group. the gearing works well for almost everything, but isn't optimal for one's specific needs if it falls outside of Kawasaki's gearing choice. That's the beauty of modding the bike... to make it work even better for one's particular needs.
July 10th, 2009, 06:22 PM | #11 | |
Posted via Mobile Device |
July 10th, 2009, 06:54 PM | #12 |
Join Date: Dec 2008 Motorcycle(s): 2005 Kawasaki Ninja ZZR 250; 1996 Suzuki Katana GSXF 600; 80s Yamaha 650 Special; 70s Kawasaki 350 Triple Posts: 448
The standard front sprocket has 14 teeth. Replace it with a 15-teeth one and you will lower the engine RPM by almost 7% at any given speed.
July 10th, 2009, 07:26 PM | #13 |
ahh.....to hell with it not gona post
July 10th, 2009, 08:11 PM | #14 | |
dirty old man
Join Date: Nov 2008 Motorcycle(s): Blue '08 Ninja 250 Posts: A lot.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894) www.friendsofsanonofre.org |
July 10th, 2009, 08:14 PM | #15 |
Frak It
Join Date: Dec 2008 Motorcycle(s): 2008 Ninja 250R Posts: 199
July 10th, 2009, 09:49 PM | #16 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250r Posts: 379
Changing out the front sprocket is really cheap and easy to do as well.
http://www.ninjette.org/forums/showthread.php?t=10273 |
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
Optimal Ass Camera | Jiggles | General Motorcycling Discussion | 9 | June 6th, 2013 09:53 AM |
What is the Optimal Valve Clearance? | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 15th, 2013 02:25 AM |
RPM | OzzyDevil | General Motorcycling Discussion | 8 | April 24th, 2012 04:15 PM |
R6's RPM | Francis | General Motorcycling Discussion | 16 | January 23rd, 2011 04:41 PM |
