July 12th, 2009, 11:36 AM | #1 |
Join Date: Jul 2009 Motorcycle(s): 09 Ninja 250R Posts: 2
HELP! Turn signal wouldn't blink
09 Ninja 250
Had to replace the turn signal fuse a few days ago, now none of the turn lights would flash. They just stay on. Any suggestions? |
July 12th, 2009, 11:41 AM | #2 |
check your bulbs (f/r) on the side that won't blink. one of the bulbs is most likely burnt out.
any guess as to why the fuse blew? |
July 12th, 2009, 11:43 AM | #3 |
Have the signals ever worked since replacing the fuse or has this been the condition ever since the fuse blew?
July 12th, 2009, 04:36 PM | #4 |
are your signals stock or have you replaced with LED?
July 12th, 2009, 10:48 PM | #5 |
The signals are stock.
It only started after the fuse was replaced. Sorry about the multiple post, i thought i would get more reply if i post in different categories. The f/r signal was changed since the bike was dropped a few weeks ago. After the drop, the right side stopped blinking and then the fuse blew. I changed the fuse and now none of the lights blink anymore. |
July 12th, 2009, 11:58 PM | #6 |
first step would be to check the bulbs to make sure they are in workable condition and don't have busted filaments.
Each side (left and right) consists of 2 bulbs, one front, one rear. If any of the two bulbs (front or rear) are non operational, that side will not blink and will stay solid. Have to ask... are you sure the connectors were plugged back in for the fairing indicators? |
July 13th, 2009, 07:20 AM | #7 | |
If any of them are not connected, they won't blink
July 13th, 2009, 09:33 AM | #8 |
/moved to newgen tech
Turn Signals Light Up But Don't Blink | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 12 | April 6th, 2015 01:00 PM |
Right turn signal doesn't blink when clutch in | Carnitas | 2008 - 2012 Ninja 250R Tech Talk | 1 | September 25th, 2014 11:51 PM |
Turn signal won't blink | demp | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 28th, 2014 06:58 AM |
Bike wouldn't turn over. Waited a while then it started. | Rugby Winger | 2008 - 2012 Ninja 250R Tech Talk | 1 | July 29th, 2013 08:42 AM |
