May 12th, 2014, 03:28 AM | #1 |
Engine Room-> Dyno
282 build w pics
I am again building a 66mm motor(282cc); figured I would post up some pics as I go.
We have had issues in the past with overbore cylinders leaking... so I had my machine guy press them out and reseal them the same way they do for Diesel engines; shouldn't have anymore issues. Nothing like fresh machine work. Question is... how much did I take off the deck and why?? ....MORE TO COME |
May 12th, 2014, 08:27 AM | #2 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
squish. .5mm
May 12th, 2014, 09:09 AM | #3 |
Engine Room-> Dyno
yes, but .5mm is a little aggressive from my measurements.
Like us on Facebook! https://www.facebook.com/pages/Carol...25707357500770 |
May 12th, 2014, 01:20 PM | #4 |
How will you determine what the limit is?
May 12th, 2014, 03:49 PM | #6 |
Sure, but the 08 and up 250 has 1mm of squish with the base gasket installed so you have that much plus the thickness of the head gasket.
May 14th, 2014, 05:14 AM | #7 |
Board Member
if you decked the head, I would say you took off .2-.3mm. Depending on the pistons chosen, I would say your shooting for 13:0 - 14:0 to 1 compression.
May 14th, 2014, 05:15 AM | #8 | |
Board Member
May 14th, 2014, 05:27 AM | #9 |
Engine Room-> Dyno
Yes you can re use the base gasket, you can actually stack base gasekts if you needed to increase your deck height. Make sure to buy a new head gasket though.
May 14th, 2014, 05:28 AM | #10 |
Board Member
May 14th, 2014, 05:33 AM | #11 |
Engine Room-> Dyno
Yep pretty close.
on this particular cylinder we took, .004"/.01mm off the deck surface. 13.5:1 compression.
May 14th, 2014, 05:38 AM | #12 |
May 14th, 2014, 05:40 AM | #13 |
Engine Room-> Dyno
In some cases yes, it depends on the desired specs for the build.
Here we were simply getting rid of low spots on the cylinder deck.
May 14th, 2014, 07:15 AM | #14 |
What are the ramifications of taking to much off? What can be gained with squish? I reuse the base gasket and sometimes leave it out
May 14th, 2014, 07:27 AM | #15 |
Engine Room-> Dyno
Ramifications = piston to head contact or other contact point inside the combustion chamber
Increased squish/quench area is just one more piece we can move in the game in order to obtain a certain combustion chamber clearance or compression ratio. For the most part the squish/quench area forces the a/f mixture into the center of the combustion chamber and in some cases creates more of a turbulent/swirl of mixture to accomplish a more complete burn. Anytime you are talking about removing material, you are changing you cam timing... make sure you double check Piston to valve clearances... as you take material out the EX cam gets closer and closer to contacting the piston at approx 10^ BTDC. We don't leave them out; that leaves nothing to seal the cases together. If you left it out, the end result would be comparable to milling the cylinder .008"/.02mm.
May 14th, 2014, 07:59 AM | #16 |
MOTM - Sep '18, Feb '16
The service limit of the head is .019. I removed .010 from a block top. I don't like the idea of cutting the head. I used 13 to 1 JE pistons with no issues.
May 14th, 2014, 08:05 AM | #17 |
Engine Room-> Dyno
Hey Eric
Did you send a 250 cylinder down to Carolina Cycle for machine work?
May 15th, 2014, 09:57 AM | #18 |
My thoughts are as little squish as possible but not so little that the pistons hit the flat surface of the head at higher RPM. The rods are short and pistons light so my first test cut would be .25mm, then remove the base gasket. Speaking of the base gasket, is it really a gasket? I think its a shim designed to reduce gauling between the soft aluminum of the block and crankcase as they expand and contract during heat cycles.
May 15th, 2014, 10:10 AM | #19 | |
Board Member
May 15th, 2014, 11:39 AM | #20 |
No.. but please PM me with details about what you can do. And cost. I need a real head
May 15th, 2014, 01:40 PM | #21 |
yes, but the head gasket seals out coolant, oil and combustion chamber pressure. When not running the base gasket i do use a scim coat of Honda Bond. No leaks on any so far.
May 19th, 2014, 03:46 AM | #22 | |
Engine Room-> Dyno
That should be fine.
May 19th, 2014, 03:47 AM | #23 |
Engine Room-> Dyno
PM sent
May 19th, 2014, 04:17 AM | #24 |
I did not get it.
May 19th, 2014, 05:49 AM | #25 |
Board Member
more pics? I like these types of threads....
May 19th, 2014, 10:40 AM | #26 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
Proper quench can be the difference between a good running engine and a pile of scrap. The harder you twist up the tune, the more important. It should be as close as possible without anything hitting. On a KZ-900/1000 that would be .035
I have no idea on a 250 Ninja. I have run many engines with Honda Bond or GasgaCinch in place of the base gasket when the deck would be a bit too high. Just be sure when you assemble, there is no oil on the mating surfaces.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
May 19th, 2014, 01:14 PM | #27 |
Wheres the pics as the title of your thread states? What pistons are you using? |
07' Ninja 250 Farkles (pics pics pics) | instinct | 1986 - 2007 Ninja 250R Farkles | 4 | April 15th, 2014 06:26 PM |
Turbo'd 2008! pics! pics! pics! Dyno run video! | TheDuck | 2008 - 2012 Ninja 250R Tech Talk | 38 | September 19th, 2013 08:28 PM |
track pics / not crash pics | almost40 | Pictures | 14 | September 19th, 2013 08:27 PM |
Why just post pics of your lid? POST PICS OF EVERYTHING!!! mwahahahahahahaha | Stingray1000 | Motorcycle Gear | 3 | May 8th, 2012 08:17 PM |
Some of the few pics of I have of my bike NOT moving (warning, large pics) | Kurosaki | Pictures | 13 | December 21st, 2008 03:43 PM |
