April 7th, 2014, 04:22 AM | #1 |
Wrecked.. what are my cosmetic options
I'm Mr. Picky and after a low speed 10-15 MPH Low side its left my bike front to back on the left side scratched and broken. I'm curious what my options are for making it look nice again. I've heard ABS Fairing but are there any good kits with tank cover? I was also told to use a wrap but seeing as in how ive got chunks busted outta my fairing something says that won't fit right.
April 7th, 2014, 05:15 AM | #2 |
Fast-Guy wannabe
MOTM - Jan '13
You could try this http://www.ninjette.org/forums/showt...8&goto=newpost
Or sell it as is and upgrade to that new R6 you oh so earned |
April 7th, 2014, 05:16 AM | #3 |
Fast-Guy wannabe
MOTM - Jan '13
Oh and
April 7th, 2014, 05:17 AM | #4 | |
that. I went through water and the bike just washed out well water and most likely sand and rocks |
April 7th, 2014, 05:19 AM | #5 |
There :P
April 7th, 2014, 05:21 AM | #6 |
Fast-Guy wannabe
MOTM - Jan '13
Don't worry some of the bondo gods on this site with swoop in later and give you some pointers. Off the top of my head I think @tfkrocks had to do quite a bit of body work to her bike to get it back up and running.
April 7th, 2014, 05:28 AM | #7 | |
Join Date: Sep 2009 Motorcycle(s): 2013 Ninja 300 w/ ABS, 2014 NC700X, 2008 Ninja 250 (sold), 2002 Ninja 250 (sold) Posts: A lot.
MOTM - Jan '18, Sep '13
April 7th, 2014, 05:30 AM | #8 |
Exactly! Haha so any feed back on abs fairings?
April 7th, 2014, 06:16 AM | #9 |
Join Date: Apr 2011 Motorcycle(s): 2008 Ninja 250r, Fazer8 Posts: 580
I can not be a true player by playing around. |
April 7th, 2014, 06:19 AM | #10 | |
April 7th, 2014, 07:10 AM | #11 |
Join Date: Sep 2012 Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B Posts: 315
Expensive option: Purchase new or used parts to replace the damaged ones. This will cost, but will best preserve your resale value.
Easy option: Just ride it like it is, or with repair tape. It has become a ratbike. Fun option: Make it naked. You just need a headlight and some turn signals, and a replacement speedo, if yours is trashed. You could also cut back the rear subframe and use a smaller taillight and smaller rear turn signals. Remove as much plastic as possible, paint the coolant tank black, and there you go. The 250 can benefit greatly from the weight reduction, anyhow. I've also seen some nice cafe racers made from newgen 250s. |
April 8th, 2014, 02:31 AM | #12 | |
April 8th, 2014, 08:50 AM | #13 | |
Certified Slacker
Join Date: Apr 2014 Motorcycle(s): 2010 Kawasaki Ninja 250R SE Posts: 232
Ninja Bob |
April 8th, 2014, 10:43 AM | #14 |
April 9th, 2014, 07:43 PM | #15 | |
Join Date: May 2012 Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally Posts: 384
Been down, done that... Why would you want to go down twice? Once is not enough? If you have to lay her down again, do it now since she's already scraped... Héhéhéhéhéhéhéhéhéhéhéhéhéhé |
wrecked | zach | !%@*#$%!)@#&!%@ I crashed! | 43 | May 25th, 2013 06:39 AM |
Wrecked it!!! | Shadow Monarch | !%@*#$%!)@#&!%@ I crashed! | 31 | October 7th, 2012 08:19 AM |
Wrecked my car >.< | insomniaticnotw | Off-Topic | 13 | May 20th, 2012 03:49 PM |
Wrecked | skip | !%@*#$%!)@#&!%@ I crashed! | 22 | March 5th, 2012 01:56 AM |
Windscreen....functional or cosmetic?? | Socal5646 | 1986 - 2007 Ninja 250R Farkles | 23 | September 15th, 2011 07:41 PM |
