Old January 9th, 2015, 05:25 PM   #1
Arrow How To Check Front and Rear Motorcycle Wheel Alignment
http://www.motorcyclistonline.com/ho...rage-tech-tips
Old January 9th, 2015, 06:20 PM   #2
chrly
chrly's Avatar
Motorcycle(s): 2013 Kawasaki EX300 , 1999 Kawasaki ZRX1200.
Funny part is , I never read anyone suggesting that the front end should be checked before anything is done..Not sure about all bikes but I know that it is easy for someone to unknowingly put teh front wheel back on and actually have it in a bind on my personal bikes...
IBA # 59523
chrly is offline   Reply With Quote
Old January 14th, 2015, 09:13 AM   #3
spooph
spooph's Avatar
Motorcycle(s): '08 Ninja 250R
MOTM - Oct '15
This is awesome, very helpful, thanks for posting!
Old January 14th, 2015, 12:19 PM   #4
Bubba
Motorcycle(s): 300
They should remove those stamped alignment marks from swingarm chain adjusters, they are misleading.
Bubba is offline   Reply With Quote
Old January 14th, 2015, 12:35 PM   #5
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Hernan, Great info as usual!
thank you
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old January 16th, 2015, 01:12 AM   #6
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I like it perfect..can't stand it. How so you keep your chain with the correct amount of slack if you have tto align your wheels!
Makes my brain hurt because I remember how frustrated I got with chain maintenance.
Old January 18th, 2015, 09:24 PM   #7
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
The version of this used over on the 500 forum is to attach the string to the rear tire, as it's wider. Run the strings toward the front, just barely touching the front edges of the rear tire. With the strings extended out forward, you should have the same gap on each side of the front tire. Either way, you're just making sure that the one tire's tracking path matches the other tire's, so that they're in alignment with each other.
Note that it's possible to pull on the string too much so it's actually bending around the tire, rather than just indicating the line along the edge of the tire. I have a laser-line level that I've tried to use for this, but I haven't come up with a good fool-proof way to do things. It makes for a nice perfectly-straight "string" for checking alignment, but I just haven't figured out a simple way to mount a pair of them for instant checking. Others have used sections of conduit pipe strapped to the rear tire as well. You just need *something* extending in a straight line to the other wheel to verify that they line up.
Old January 19th, 2015, 07:38 AM   #8
chrly
chrly's Avatar
I just make sure the front wheel/forks are not in a bind then align the rear axle with the swingarm bolt. I have a simple device that checks distance.
IBA # 59523
Old January 19th, 2015, 10:23 AM   #9
verboten1
verboten1's Avatar
MOTM - June '15
being centered to each other is not critical. being parallel to each other is.
Point in case, my viragos (both of them) the rear wheel is offset to the right of center by 1/4" or so (from the factory)
BMW GS's have an offset as well IIRC
Ride more, worry less.
Old January 19th, 2015, 11:02 AM   #10
chrly
chrly's Avatar
As does teh Kawi ZRX1200.
IBA # 59523
Old January 19th, 2015, 11:18 AM   #11
Yep - sounds similar to the one we have here in our DIY area:
DIY- Chain Adjustment and Rear Wheel Alignment
Old March 26th, 2015, 08:28 AM   #12
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
I also tie the string to the rear tire, then use hammers to tie the string up front to make it nice and taunt.
I suppose tying the string to the front tire is a much much quicker way if you have 2 people doing it.
I have no friends....so I was forced to do it alone =/
[motorcyclistonline] - How To Check Front and Rear Motorcycle Wheel Alignment | MC GA Ninjette Newsbot Motorcycling News 0 January 5th, 2015 10:50 AM
Rear-wheel feels like it's kicking out of alignment Sykes92 Riding Skills 28 March 15th, 2014 05:11 AM
Rear wheel alignment SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 23 April 7th, 2013 09:51 AM
Rear Wheel Alignment Gorilla25 2008 - 2012 Ninja 250R Tech Talk 16 September 27th, 2011 11:38 AM
rear wheel alignment tool quanttrom 2008 - 2012 Ninja 250R Tech Talk 11 September 3rd, 2011 10:03 PM
