July 17th, 2010, 01:03 PM | #1 |
Join Date: Dec 2009 Motorcycle(s): Ninja 250R Posts: 432
Another valve check thread
Right now I'm checking the valves and I notice that when I'm sticking the feeler gauge between the camshaft and the lifter, the lifter goes down, and it doesn't matter what gauge I use it moves. What's the trick or how it should be done?
July 21st, 2010, 01:24 PM | #2 |
I'm gonna wait for someone with more experience to chime in (only did it once myself), but I am wondering about the valve springs.... this shouldn't be happening.
July 24th, 2010, 05:17 PM | #3 |
I have to agree with Doc. In my opinion, there is so much that can be screwed up with a bad adjustment on an engine that can rev 14K. My bike is under an extended warranty so I don't attempt something that I may be unsure of. True, the Ninjette is a "Budget Rocket" unlike a Ducati or Honda literbike. Then again a screwup gets expensive any way you cut it. In the past, 30 years ago, I did all the maintenance on my Brit cafe racers, but those were simple bikes that were not particularly fast, and had lots of tolerances. Ever hear a 70's Triumph? or Norton? The valve clatter on those bikes was incredible and totally acceptable. They also did not rev 14K. My advice would be to have a pro check it out or at least walk you through the valve adjustment.
August 5th, 2010, 01:23 PM | #4 | |
Join Date: May 2009 Motorcycle(s): 2009 Kawasaki Ninja 650RTE & 2009 Kawasaki Ninja 250R (SOLD) Posts: A lot.
hey how many miles are on your 250? have you had the valve check done to yours yet? - i just hit the 10,000+ mile mark and STILL havent had them done yet. Ive called 3 dealerships around here and when i ask them how much to service the valves,etc... they just ask me if my bike is doing this, sounding like this,etc.... and if its not.... hold off until 15,000 miles or till your bike starts to run like ****, burns oil, etc. |
Stealership is at it again. How much was your valve check? | Floki | General Motorcycling Discussion | 30 | June 30th, 2014 06:48 PM |
Valve Clearance check | tsmith3605 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 26th, 2013 01:10 PM |
Delayed valve check | Lowspeed Lowside | 2008 - 2012 Ninja 250R Tech Talk | 10 | October 14th, 2011 11:11 PM |
How to tell if valve check was done? Looking at 09 250. | rwheelz | 2008 - 2012 Ninja 250R Tech Talk | 5 | September 18th, 2010 04:04 PM |
Question re valve check | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 16 | July 7th, 2010 05:53 PM |
