Old July 3rd, 2013, 10:42 AM   #1
Dano
Dano's Avatar
Motorcycle(s): 09' Blue Ninja 250R and 07' Honda 919
Stainless bolts
Ok some of the bolts on my engine are sorta nasty( like corrodes) from the winter it was in my inlaws basement, If I remember from when I had my SV on Ebay they used to sell bolt kits that replaced all the engine case bolts with stainless..different colors and such. Anyone know a link to someone that sells them?
Dano is offline   Reply With Quote
Old July 3rd, 2013, 11:07 AM   #2
Dano
Dano's Avatar
like this from somewhere in the United States.
http://www.jesterstrickbits.co.uk/pr...inja-250R.html
Old July 3rd, 2013, 11:12 AM   #3
Dano
Dano's Avatar
Nevermind, I found them here:
http://www.probolt-usa.com/alloy-eng...l#.UdRpUdnm6t8
Only question now is do I want the silver or black???? Leaning towards the silver to make them stand out!. Whats everyones opinion?
Old July 3rd, 2013, 12:37 PM   #4
Bones85
Seems quite expensive for bolts. Have you checked a local hardware store?
Bones85 is offline   Reply With Quote
Old July 3rd, 2013, 02:57 PM   #5
Stainless steel bolts are much weaker than any steel bolt used by the manufacturer for the engine.
Stainless steel and cast aluminum don't get along well because they react electrolytically, setting up a small electrical current that results in the thread seizing in the casting.
On top of all, they cannot be fished with a magnet if they fall inside the engine.
When looking for replacement steel bolts, use only 8.8 grade or superior.
Copied from:
http://forums.ninja250.org/viewtopic...348&highlight=
"The number in the JIS system means the ultimate tensile strength in kgf/mm^2 divided by 10.
Following is the meaning of the number in the ISO metric system:
The number before the point is the ultimate tensile strength in MPa divided by 100.
The number after the point is 10 times the ratio of tensile yield strength to ultimate tensile strength.
The found JIS and ISO Metric equivalence is as follows:
JIS mark----------------------ISO metric mark
4 or 4T---------------------------4.6~4.8
5 or 5T---------------------------5.6~5.8
6 or 6T------------------------------6.8
7 or 7T------------------------------8.8
8 or 8T------------------------------8.8
10 or 10T--------------------------10.9
Old July 3rd, 2013, 03:12 PM   #6
Joshorilla
Bass Master General
Joshorilla's Avatar
I'd just use normal bolts and spray your metal with ACF50, I live where it rains all winter and it's constantly salty as I am never more than a quarter of a mile from the sea.
I have no corrosion and my bike lives outside 24/7
Old July 3rd, 2013, 03:46 PM   #7
papawhellie
Motorcycle(s): lots
Aluminum is not going to be as strong as stainless or ferrous.
If you know your sizes these will be much cheaper. You can order by piece.
http://www.albanycountyfasteners.com/
http://www.boltdepot.com/catalog.asp...FVQV7AodhBwA2Q
papawhellie is offline   Reply With Quote
Old July 3rd, 2013, 09:22 PM   #8
Dano
Dano's Avatar
they say aluminum bolts. they are replacement for side cases
