Old June 27th, 2013, 12:18 PM   #1
indr
Can a shifter like this be used on our bikes?
I know ours has the adjustable linkage rod that runs between the shaft (that goes inside the engine), and the shift lever itself.
This would eliminate the linkage rod and hook up directly to the shaft.
So, I were to flip that shifter upside down, and tighten it to the shaft appropriately, it should work, no?
Would it reverse the shifting? I.e. shift up to gear down and shift down to gear up...
indr is offline   Reply With Quote
Old June 27th, 2013, 12:24 PM   #2
probably. you might have to bend it out just a little bit. and yes it would put it in "GP-shift"
Old June 27th, 2013, 12:37 PM   #3
lgk
If the offset and splines were right, you most definitely could.
Old June 30th, 2013, 06:58 AM   #4
bruce71198
bruce71198's Avatar
It will be GP shift also it will be to long unless you have rear sets. If your not running rear sets try a shifter designed for a Honda 50.
My shifter be getting stuck lately rasta 2008 - 2012 Ninja 250R Tech Talk 18 May 25th, 2014 11:20 PM
Shifter wanarace94 Items Wanted 3 May 12th, 2013 07:07 PM
Shifter Adjustment Liist 2008 - 2012 Ninja 250R Tech Talk 2 November 9th, 2011 02:26 PM
shifter help .something. 2008 - 2012 Ninja 250R Tech Talk 2 September 5th, 2011 03:07 PM
Shifting without shifter!? JMIrrobali 2008 - 2012 Ninja 250R Tech Talk 2 September 3rd, 2009 05:35 PM
