Old June 27th, 2013, 05:14 PM   #1
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
Is it a huge issue not to use anti seize on spark plugs?
Can I install spark plugs without the wax crayon anti seize?
tsdexter is offline   Reply With Quote
Old June 27th, 2013, 05:20 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Not sure my self but I've used it before. It's a nice idea but I can't see it being a guarantee deal beaker if you don't.
Old June 27th, 2013, 05:41 PM   #3
tsdexter
Hey thanks. Actually, I found this direct from NGK which says specifically NOT to use anti seize as you will probably over tighten and break the plug (bad). Their plugs are designed with special metal plating that breaks away when removing them so they don't seize..
Funny that all the recommendations on here say to use anti seize but NGK says not to...
http://www.ngksparkplugs.com/pdf/tb-...1antisieze.pdf
Old June 27th, 2013, 06:21 PM   #4
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
I've never used anti seize on spark plugs
Old June 27th, 2013, 06:23 PM   #5
you have two options.
1) use antisieze
2) use the correct torque specs.
for gods sake do one of those two. trust me when i say you do not want a siezed plug. destroys the threading which means you get to remove the head and insert a helicoil (drill, retap, coil up) otherwise if you destroy the threads from seizing the plug in and trying to force it out, and don't put in a helicoil, you'll melt the plug hole and lose all your compression. and then the engine doesn't work so good.
spark plugs jcsalazar 2008 - 2012 Ninja 250R Tech Talk 11 May 17th, 2015 08:44 AM
Spark Plugs.... DmbShn41 2008 - 2012 Ninja 250R Tech Talk 13 August 8th, 2014 04:13 AM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
spark plugs postie1686 2008 - 2012 Ninja 250R Tech Talk 7 June 7th, 2011 04:52 AM
Spark plugs... ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 3 August 23rd, 2010 04:02 PM
