April 23rd, 2018, 11:30 AM | #1 |
[motorcycle.com] - Alpinestars Releases Limited Edition Kevin Schwantz Supertech R
This weekend in Austin, Texas, during the third round of the 2018 MotoGP calendar, Alpinestars unveiled its latest Limited Edition graphic for the Supertech R boot, honoring 1993 world champion, Kevin Schwantz. To make the occasion extra special, Revvin Kevin was in attendance to personally unveil the boot. The full release is below. Begin press release: Suzuka 91: Four title contenders enter the final lap mere feet apart. An all out battle, passes under braking so late you can not bear to look and the lead will change hands again and again. An inside line appears, barely an opening at all and the number 34 Suzuki dives in and makes the pass stick. When the checkered flag is waved the top four is decided by .556 of one second and Kevin Schwantz is victorious with a final lap battle that is cemented in MotoGP history. No one typifies the all-or-nothing, knife-edge, racing of the era like Kevin Schantz. Hailing from Houston, Texas, a background in motocross gave him the skills to battle shoulder to shoulder in the tight chicanes and historic corners of grand prix road racing with unique style. In 1993 he became World Champion wearing the legendary Alpinestars GP PRO boot and now to mark the 25th anniversary of that title, Alpinestars introduces the Limited Edition Kevin Schwantz Supertech R in a Kevins individual color way – an icon now just as it was back in the 1990s. Designed and developed to the highest technical standards, the Supertech R Boots today represent the pinnacle of racing innovation for track and road use. Every component is meticulously engineered for high performance protection, precision and flexibility. Now available in this classic Limited Edition colour scheme, the Schwantz Supertech R boot is dialled for speed and style, giving fans the opportunity to show their Texas spirit by wearing their favourite riders boots. Alpinestars most iconic road riding boot worn by a roster of the fastest World Champions past and present, the Supertech R incorporates performance innovations, including a redesigned compound rubber sole, an ergonomically profiled shin plate, a redesigned front flex area, plus the pioneering dual torsion, bio-mechanical ankle brace all of which enhance the podium winning performance of this CE certified boot. SUPERTECH R CONSTRUCTION Technical microfiber upper construction offering superb levels of flexibility. Microfiber main shell offers high levels of water-resistance, durability, and improved weight-savings. Material ensures consistent fit for long term usage and is easy to maintain and clean. Redesigned front flex area is constructed from over-injected TPU over inject on breathable mesh with shaped reliefs for improve abrasion resistance and natural forward and back movements. Top gaiter follows leg contour and is made of flexible high-grade synthetic leather reinforced with PU. Lightweight rubber compound sole offers excellent grip and feel and allows for natural flex as the rider changes position and pressure on the foot-peg. PROTECTION Newly designed external TPU shin protection is ergonomically shaped and wraps around to outer calf and is engineered to spread and dissipate impact energy across the entire surface while remaining compact. Integrated replaceable co-injected TPU/Aluminum toe slider features new easy screw fixing concept provides feel and protects the outer toe box structure from abrasion. Replaceable polymer heel plate slider protects from impact and reduces friction in the event of a crash. Supertech R boot is CE certified to EN 13634:2010. KEY FEATURES Flexible accordion microfiber stretch at Achilles allows natural movement. Innovative, full length medial-facing microfiber panel features new texture pattern offering excellent grip and feel against the bike and protects from abrasion and heat. Flexible, lightweight toe shifter allows feel for changing gears. Separate internal bio-mechanical ankle brace works with the outer structure of the boot to form a protective system allowing full and free movement of the foot, ankle, and leg. External entry has stretch accordion panel for a close fit and ease of entrance and removal. New, soft TPU stretch panel on the lateral side gives easy closure with an excellent fit. Zip is made from TPU to reduce friction in the event of a crash. Velcro tab locks the zip pull closed, keeping it flat and secure. Shin plate features new micro-adjustable ratchet top closure for safe and precise fit. On vented version: strategically positioned ventilation in heel and shin TPU guides air through the boot. These boots are available in men’s EURO sizes 39 – 48. SUPERTECH R INNER ANKLE BRACE SYSTEM Separate internal bio-mechanical ankle brace works with the outer structure of the boot to form a protective system allowing full and free movement of the foot, ankle and leg. New research has produced re-profiled double hinged inner and outer torsion bars to give greater impact protection to the ankle by progressively absorbing flex and rotation stress, reducing pressure and hyper-extension injury to the lower leg joints. The inner ankle brace is constructed with a fiberglass re-enforced polyamide compound and ergonomically designed closed cell padding to give protection and comfort. Alpinestars exclusive lasting process has developed the Supertech Rs fit and feel characteristics to an even greater level, ensuring the inner structure allows the rider maximum feedback from the bike. Specially developed polyamide compound moldings give impact protection while retaining the ease of natural skeletal movement. Main upper material constructed from breathable mesh and microfiber chassis supported by an inner ankle soft padding for maximum comfort. Metal eyelet closure ensures rapid and accurate entry and exit and with micro-adjustability, ensures perfect fitting and security. Alpinestars Releases Limited Edition Kevin Schwantz Supertech R appeared first on Motorcycle.com News. Click here for full story...
[motorcycle.com] - Alpinestars Releases Limited Edition MM93 Maze Supertech R boot an | Ninjette Newsbot | Motorcycling News | 0 | August 24th, 2017 04:12 PM |
[motorcycle.com] - Alpinestars Supertech R Released In Limited Edition 99Camo Jorge L | Ninjette Newsbot | Motorcycling News | 0 | June 9th, 2017 03:40 PM |
[motorcycle.com] - Alpinestars Presents: Limited Edition MACH 1 Supertech R Boots | Ninjette Newsbot | Motorcycling News | 0 | May 4th, 2017 10:40 AM |
[motorcyclistonline] - New Product: Alpinestars Limited Edition 'Republik' Supertech | Ninjette Newsbot | Motorcycling News | 0 | April 20th, 2017 11:30 AM |
[motorcycle.com] - Alpinestars Releases Limited Edition Marc Marquez Supertech R Repl | Ninjette Newsbot | Motorcycling News | 0 | April 20th, 2017 11:00 AM |
