December 2nd, 2008, 01:46 PM | #1 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 and ZX-12R 2000 Posts: A lot.
Engine Break-In, Pros and Cons
So, how are you breaking in your engine? Are you using the factory recommendation? Why or why not?
Here are additional techniques that I have found: http://motorcycleinfo.calsci.com/NewBike.html http://www.mototuneusa.com/break_in_secrets.htm |
December 2nd, 2008, 02:19 PM | #2 |
I used a modified motoman method which ended up being much like the first link's method.
My biggies were... -change oil/filter often... i did it at 50, 100, 300, 600, 1000 all with conventional 10-40 except the last which was a full synthetic. -vary the rpms and don't stay at the same rpms for long periods of time. (freeway riding) -don't lug the engine (low rpm in a high gear) -stay away from redline for the first few hundred miles. -heat cycle the engine. do your break in with many short rides letting it fully warm up and cool down between rides) instead of one long one. to me, there are many shortcomings of the factory method. the biggest being that operating the bike under their method makes you dangerous on the road. Just ride the bike as you need to as to not be a hazard to navigation. zing it up to 10k with no worries... that's where the bike likes to be run... in the 7-10k range anyway. how many miles on your bike? |
December 3rd, 2008, 05:12 AM | #3 | |
I'm having problems locating oil filters locally. Any suggestions? |
December 3rd, 2008, 11:04 AM | #4 | |
Amsoil: SMF 101 (No longer available. Replaced by WIX 24941.) CarQuest: CFI-89941 Emgo: 10-37500 (includes O-rings) 10-20300 (doesn't have O-rings) Fram: CH6012 Hastings: LF571 Honda: 15410-426-010 or 15410-300-024 Kawasaki: 16099-003 K&N: KN-401 NAPA: PS4941 (formerly 4941) Perf-Form: OF-0047 (formerly J-501) Purolator: ML16812 STP: SMO-12 (Once readily available, now appears to have been discontinued.) Triumph: 1210031 Vesrah: SF-4004 WIX: 24941 Yamaha: 36Y-13441-00 and just in case you've never changed the oil in your bike before... http://faq.ninja250.org/wiki/Oil_Change_Photographs |
December 4th, 2008, 02:09 AM | #5 |
Too sexy for roadrash
Join Date: Aug 2008 Motorcycle(s): 2004 Ninja 250, 2007 Lance GS-R 150 (racing modified scooter), 1980 Honda CB750K project Posts: 89
I break in my engines along the lines of what kkim mentioned.
-Vary the RPMs -LOTS of engine breaking -Frequent oil changes -almost totally ignore factory recomendations Travis
I'm too sexy to get roadrash, that is why I wear my gear all the time. If you are not as sexy as me, then maybe you can get away without it. ~Unofficial ninjette.org fish smacker~ |
December 4th, 2008, 10:44 AM | #6 |
December 7th, 2008, 10:41 AM | #7 |
Broken Bone Hater
Join Date: Dec 2008 Motorcycle(s): 2008 250R, 2005 ZX-6R Posts: 17
Ride the crap outta it varying the RPM's from idle up to redline never holding one RPM for too long.
Lots of engine breaking to help wash the crap out of the cylinders as the rings seat. Change the oil at 60 then again at 300 miles. After that every 3000. Exactly 2 quarts with a new filter. Switch to syn at about 1500 or so if you like. Inspect and change the spark plugs at about 2000 miles. I use K&N filters and Repsol 10w-40 |
February 17th, 2009, 05:11 AM | #8 |
I'm lovin' it.
Join Date: Feb 2009 Motorcycle(s): '09 Black 250R Posts: A lot.
With many people saying "never holding one RPM for too long", I'm wondering how long is too long?
February 17th, 2009, 07:13 AM | #9 |
So slow I'm first!
Join Date: Oct 2008 Motorcycle(s): 06 Kawasaki Ninja EX250 Posts: A lot.
Why... couldn't you've posted this two weeks ago! Hah! It's alright though! I may have passed the 20 mile marker but that was with varying speeds and a little (about 4 miles) of freeway... So that should have sealed that ring the second link was talking about right?
One thing about motorcycle riding I don't like... break ins... I am scared I will not do it right and break Tyke all over again!
Learn from the mistakes of others, you cannot make them all yourself. Save yourself the trouble and Learn. |
February 17th, 2009, 10:51 AM | #10 |
Sunny, don't stress. Engine break-in on a modern bike is one of those things that everybody is convinced they've done the absolutely correct way:
"7 16.23 mile loops while varying speeds from 22 to 46 mph at 38 second intervals, with 18 minute cool-down periods in between" "1 37 minute ride every other day over a space of 3 weeks, with an oil change on each off day" "1 200 mile ride at 90 mph, 20 minute rest, then a 400 mile ride at 84 mph" You ever notice how you've never read a single post online about someone who believes they've hurt their bike by not breaking it in correctly? That's because that someone doesn't exist. There isn't a wrong way to do it. The Motoman guy isn't accepted as someone who knows what he's talking about by anybody who actually knows what they're talking about. He's become famous because he gives the uninformed new sportbike rider a great excuse to ride their new bike like an ass****, and they have "scientific proof" that what they're doing is good for the engine. The advice about not keeping it at the same rpm's for an extended period is likely sound, and echoed by the manufacturers, but all they are trying to do is limit the (very small) chance of the rings not seating as they should. But for that to happen on a modern engine, a person would have to go out of their way to try and make it happen. I.E., take a bike with literally 0 miles on it, take it to a flat and level piece of road, and ride at the same speed in the same gear under the same load for many hours on end. In the real world, even without varying the revs, the engine load changes as our machines go up and down hills, which requires different combustion pressure in the cylinders, which affects the forces on the piston rings in a slightly different manner. Don't stress.
February 17th, 2009, 11:18 AM | #11 |
Join Date: Dec 2008 Motorcycle(s): 2008 Yamaha FZ6 Posts: 117
I suspect the "keep it under 4k" business is more about keeping you from losing control. By the time the break-in is done you should have developed a sense of how the bike handles, especially with all these young guys starting out on supersports.
Tim |
February 17th, 2009, 05:17 PM | #12 |
I bought some neodymium magnets on ebay when I started riding bikes and I slip one on the oil filter to catch shavings. This is especially helpful right at first as that is when you are going to create burrs.
It's not worth doing if you aren't completely stressed out about it. |
October 29th, 2009, 08:40 AM | #13 | |
knees in the breeze
Join Date: Oct 2009 Motorcycle(s): 2007 Kawasaki Ninja 250r Posts: 17
October 29th, 2009, 09:20 AM | #14 | |
October 29th, 2009, 10:54 AM | #15 |
Join Date: Aug 2009 Motorcycle(s): 07 GSXR600 (N250 sold :( ) Posts: 415
The manufacture's method is impossible to follow on the 250, and the thing is they use the same method for theier bigger bikes, so it is possible to keep the rpms very low on the freeway on a 600 but it's not advisable. I just rode it normally, I did try to vary the rpms in the city but I also did alot of highway riding during he break in period and it was fine.
October 29th, 2009, 03:28 PM | #16 |
Join Date: Jun 2009 Motorcycle(s): Ninja 250R Fuel Injected Model 2009 Posts: 357
Manufacture recommended break in.
I've "broke" 2.5 engines already in other things so I think its time I started listening to the manufacture recommendations. I'm sure Kawasaki know there own engine better than anybody. I actually vlog'd about this just recently. The roads you see in the video are the kind I used to do the first 500 miles (sub 4,000 rpm). It was like serving a prison sentence Once your past 500 though and up to 6,000 rpm its plenty of fun. http://www.youtube.com/watch?v=oi8TYvEqvQc
My vlogs on Youtube are here |
October 29th, 2009, 04:36 PM | #17 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
I've also seen numerous other mechanics and motorcycle review media show that Kawasaki's recommended break-in on the 250 is not needed nor warranted. Most use a similar method if not the same method (just worded a little differently) as motoman. I've read articles from builders that build the bikes up for higher power/speed and use the 'hard' break-in methods for similar reasons to motoman. So if so many people out there use that method to build and break-in bikes for performance, how can he not know what he's talking about as alex said? Just a thought.
October 29th, 2009, 05:11 PM | #18 |
North Alabama Mtn. ryder
I think the recommended break in period is help a manufacturer run warranty time off..never bought a new bike but what's standard a year?
I agree with kkim mostly....ride the bike
QTRltrPWR |
October 29th, 2009, 05:44 PM | #19 | |
IC2(SW)
October 29th, 2009, 08:14 PM | #20 | ||
The only thing you have to read on his page to know that is this: Quote:
October 29th, 2009, 09:42 PM | #21 | |
Join Date: Oct 2009 Motorcycle(s): 2008 Triumph Bonneville Black Posts: 627
I followed the break-in period as recommended by the friggin manufacturer. It's not impossible, though it was tedious for a couple weeks. |
October 29th, 2009, 09:46 PM | #22 |
a lot of us didn't and we're not having problems with our bikes. what does that prove?
October 29th, 2009, 09:50 PM | #23 | |
It probably doesn't make a large difference, but I'm sure Kawi (and every other bike mfg) wouldn't recommend it if there wasn't some reason for doing so. Maybe the bikes will last 150,000mi instead of just 120k, haha. |
October 29th, 2009, 10:31 PM | #24 | |
October 30th, 2009, 12:28 AM | #25 | |
Ugh. Everyone PLEASE stop playing the "Kawi knows their engine better than ______, so we shouldn't debate and should listen to them" card. Not only are you stating the obvious first conclusion anyone will come to on their own before hearing or discovering otherwise, but it is also well-known that they have not written a single word of their break-in procedure differently in over 30 years. It is the exact same for every engine/bike they sell. There is no engine-specific instruction in their break-in procedure and, therefore, none of their "intimate knowledge of the engine" is reflected in that recommendation.
The only thing for sure is that manufacturers do not give bike-specific recommendations. For example, Kawi's instructions have persisted for many decades across all models despite advances in manufacturing and design. To say that you are following Kawi's recommendation because they "know this bike" implies that they developed this recommendation for this bike. They did not, and that is never more obvious than on a bike that requires you to drive over 600 miles at under 35MPH (significantly under if you vary RPMs like you should) just so that they can leave the break-in procedure word-for-word identical. |
October 30th, 2009, 01:54 AM | #26 |
Join Date: Dec 2008 Motorcycle(s): 2010 Ninja ZX-6R Posts: 211
I picked up a new plated 8th month 2009 ninja yesterday. I was told by the Kawa dealer to take t up to 110 kilometers an hour and let it gently drop off and then bring it back up and let it gently drop off etc.
The dealer knows my route to work and back and based off the traffic said the cunningham Highway would be good for the 110 up and down and Ipswich motorway would be good for allowing it to vary the revs below 110 due to the way it moves in the morning and afternoon. I was then told once it hits 600 kilometers open it up. I tend to listen to them then anything else. I previously owned a 2008 model and was told the above by the same dealer and did exactly as above with the 2008 model and had no problems. |
October 30th, 2009, 02:15 AM | #27 | ||
October 30th, 2009, 02:49 AM | #28 | |
Having worked on metal i know if you work at it slow you grind away imperfections, if you work at it too hard and fast you grind away that imperfection but can also take away a lump that's bigger than that imperfection was anyway, so you trade a bump for a hole. If you want to see it with your own eyes, grab a piece of aluminum and cut it roughly. Stick it in a vice grips and try to file it with a hand file (same kind of reciprocating movement a piston makes) Ok they recommend the same for all there bikes (do they really?). That does not surprise me. While the bikes may look different, do different things, one thing that does not change is the tolerances in manufacture that kawasaki choose for best performance/reliability. Nearly every engine in there range uses the same base materials and is designed at full speed to get the pistons moving at around 20 m/s. So its easy for Kawi to say that the ideal speed for one of there piston rings (same materials on most of there range) grinding against a cylinder wall (same material on most of there range) is in or around 5 - 8 m/s. And before someone points out that there engines rev to different red lines. * 08 Ninja 250 redline 12.5k, stroke 41.2mm = 17.167 m/s piston speed * 08 Ninja 250 4k break-in = 5.5 m/s * 08 Ninja 250 6k break-in = 8.24 m/s * 09 zx6r redline, 13.9k stroke 42.5mm = 19.7 m/s piston speed * 09 zx6r 4k break-in = 5.6 m/s * 09 zx6r 6k break-in = 8.5 m/s So 2 very different engines with the same break-in advice, but its almost as if Kawi came to the conclusion that for grinding away there aluminum cylinder walls with there piston rings 5.5m/s is about perfect. And after the grinding is done (and oil changed) about 8.25 m/s to 8.5 m/s should be perfect to polish them to a nice finish. After that you can go crazy cause the job is done. But if people want to believe some anonymous dude on the internet who won't pay to fix your bike if it fails early that's your choice. Me I choose to listen to the engineers who know the materials all Kawi's engines are built with and know all Kawi's engines target 20 m/s and have extrapolated some hard number for breaking in almost any Kawi bike from a 2 cylinder 249cc producing 33 bhp to a inline 4 600cc producing 112bhp.
October 30th, 2009, 03:01 AM | #29 | |
Also, this is over DECADES. Comparing two modern engines to a procedure created decades ago is not equivalent to comparing a 1970's motor to a 2010 one. Materials have changed. Tolerances have tightened. Computerization has made everything more accurate from the moment the raw materials are cast to final assembly. What has NOT changed, is the recommended break in procedure. |
October 30th, 2009, 03:03 AM | #30 | |
October 30th, 2009, 04:51 AM | #31 |
I thought about it and decided it wasn't really relevant...but it probably still is! I wish I still had that engine/trans. When our first child was on the way, I stupidly sold the car at a substantial loss. It would be worth well over $120K, now. Great memories! Alabama Highway Patrol were definitely impressed with it.
October 30th, 2009, 05:04 AM | #32 |
IC2(SW)
Have seen allot of new bikes/cars that people/friends have bought over the years. The peeps that ran the crap out of them, right off the show room floor. Couple years down the road just didnt seem to have good power. This was top end speed, roll on's and such. Now this could come down to little tweaks here and there, but some had the same mods. I really think that the first 1000 miles mean allot to new motors.
Yeah, that was needed on the flat tappit cams. Gets the lifters spining in the bores, keeps from getting the dreaded tap/tap/tap/tap. |
October 30th, 2009, 05:07 AM | #33 |
I guess I can hijack my own thread.
For those of you wanting a trip back in time, check out these Mopar Crate Engines: http://www.mopartsracing.com/parts/blocks.html A major problem with the hemi design was the fact that anytime one changed the spark plugs, the new set would be automatically fouled by OIL. The plugs are installed within a roughly 6" long cylinder and oil would leak around this cylinder into the combustion chamber, while the plugs were out. As soon as the engine was started, instant smoke machine and fouled plugs. Chrysler sold an addon seal kit (more money), which corrected the problem. Of course, the seal kit should have been standard equipment. |
October 30th, 2009, 05:09 AM | #34 |
Kerry, our honeymoon was spent in Pensacola and Destin!
October 30th, 2009, 05:18 AM | #35 |
IC2(SW)
You did, when was that? Dude in our shop built a hemi belvedere, FHO built the motor. I seen the bill on the motor, 26,000 was 572CI. Was kinda sad, he seen this stock hemi car in the dealership he worked at when he was younger. His dream was to have one, so he finally gets it built from the ground up..... and his wife gets him to sell it I took some pics of it as he was building it, will post a couple pics when I get home |
October 30th, 2009, 05:45 AM | #36 |
1973
The engine had 3300 miles on it, when I started the rebuild! I took the heads to a speed shop in Mobile, but I did everything else. Had a local shop dunk the block and I honed the cylinders, and installed rings, bearings, etc. Replaced the cam bearings and installed the cam, along with degreeing it in. Had the local Dodge dealer install the Sox & Martin reverse pattern kit for the A-727 automatic, along with a 4500 RPM stall converter. I ran M&H slicks with a 5.13 gear. The car won the Alabama State Championship in B/Modified at Dauphin Island drag strip. Never even got in third gear. 8500 RPM @ 125 MPH High 11's. |
October 30th, 2009, 02:04 PM | #37 |
IC2(SW)
Hey Sam, Honeymoon was in 73?
Heres my friends car, It was a gutted blue shell when he got it. He did the paint in the driveway, interior/wiring & built transmission in his garage. He never got to run it at the track, but he did enter it in the base car show. Won two trophies Few pics from that day: |
August 6th, 2011, 01:30 PM | #38 | |
Nooblet
Join Date: Jul 2011 Motorcycle(s): 2011 Ninja 250R FI Posts: A lot.
MOTM - Oct '13
August 6th, 2011, 04:07 PM | #39 |
September 24th, 2011, 05:12 PM | #40 |
That rider dude.
Join Date: Apr 2011 Motorcycle(s): 2011 White Ninja 250 SE. Posts: A lot.
*Bump!*
So, Im bumping this because I feel guilty. I was keeping it within the 4k RMP's today and yesterday going around the neighborhood, but I want to go out, and need to go out, by monday. So, I started shifting today at 6k, and slowing down and changing it back up to 4k. I feel guilty though and am pretty uh.... cautious about this. Would it be horrible to just keep shifting to 6k just so I can get to 50 mph, and NOT do frequent oil changes until the 600 mile mark? I have this thing with kawasaki where I pay 60 a month (I know, but im machanically challeged) and they do all the changes and fix ups I need when needed. Im not sure how ever, if I can go in early or frequently. Would this be a major problem? Should I still worry or should I just not care and keep doing what Im doing: Which as stated before, shift at 6k when I want and just drop it when possible. All my locations that I'll be going are pretty close to eachother, and there are a few stop lights along the way. Someone please banish my fears x-( lol And to top it all off, my baby seems like she's struggling when she's at 6k. Working too hard perhaps. |
[crash.net - MotoGP] - Crutchlow: There are pros and cons for everything | Ninjette Newsbot | Motorcycling News | 0 | August 15th, 2013 11:30 AM |
Pros/cons: Standalone back protector vs. CE insert | adouglas | Motorcycle Gear | 7 | August 15th, 2013 09:56 AM |
Pros and Cons of a 150 Tire? | tnr4 | 2013 - 2017 Ninja 300 General Discussion | 28 | April 26th, 2013 12:00 PM |
Muffler location/placement - pros/cons | tltb26 | General Motorcycling Discussion | 28 | June 18th, 2010 10:39 AM |
Advice: buyer pros and cons... | Verus Cidere | General Motorcycling Discussion | 34 | June 11th, 2010 11:02 PM |
