April 17th, 2011, 08:54 AM | #1 |
Bolt "spacers?"
I'm using 80mm long bolts where my 10x1.25 rear spools once installed so that I can still get the bike on a stand with my Sportisi swingarm cover installed. The heads are wider than the spools which makes it the perfect length, but I need some kind of thin tubular spacer to hold them away from the swingarm/cover.
Nuts will not work because they are too thick and will interfere with the swingarm cover. Any washers thin enough would need to be stacked in a ridiculous amount. So, where can I find 11or 12mm diameter tube/piping of various lengths to make a spacer? I need about an inch, IIRC. When I bought the bolt hardware at The Home Depot, the Hardware guys suggested that I check in plumbing. They couldn't help me there. I checked the section for electrical conduits as well and came up empty. TheDuck used something similar to mount his slightly relocated battery box on his SV650 at the end of this video: |
April 17th, 2011, 09:04 AM | #2 |
Have you considered rubber hose?
April 17th, 2011, 10:16 AM | #3 |
Ah! Thanks. Any idea where to look for something in black that's thick, stiff, and flexible enough to fit tightly (hurr hurr hurr-that's what she said)?
I just kept thinking about a smaller version that pipe that people use to protect the threaded bar in the home-made tire changing station when they are using their No-marr bar. |
April 17th, 2011, 11:04 AM | #4 | |
About 1/2" I.D hose from an auto parts store should work. |
April 19th, 2011, 11:48 PM | #5 | |
Join Date: Jul 2010 Motorcycle(s): Candy Thunder blue 2009 kawasaki 250r, 2010 Dark Stealth Ducati Monster 696. Posts: 891
Last futzed with by vnranger; April 19th, 2011 at 11:51 PM. Reason: Add price |
April 20th, 2011, 12:15 AM | #6 | |
April 20th, 2011, 07:05 AM | #7 |
Awesome! I assume you got the bolt at Ace too? They didn't have the right kind at Home Depot so my current bolts no longer fit inside my slider spools (big six-sided head for a standard wrench/socket) but they work in the mean time.
April 20th, 2011, 09:06 AM | #8 | |
http://cgi.ebay.com/ebaymotors/ALLEN...item3366eefcab Seller ID is: mecanik2000 |
May 8th, 2011, 11:08 PM | #9 |
Well, I bought spacers that didn't fit so I couldn't tighten them down all the way and I ended up losing one... I think. I may have absent-mindedly put ONE in the tool box and left the other installed, but it was almost gone too (loose), so I'm pretty sure I lost it. Oh well.
May 9th, 2011, 01:15 PM | #10 | |
May 9th, 2011, 07:57 PM | #11 |
Thanks for the info ,never know about this rules.Lucky that I bought the right bolt,just measured and mine is 27mm into the hole
Last futzed with by vnranger; May 9th, 2011 at 08:00 PM. Reason: add info |
May 9th, 2011, 08:10 PM | #12 | |
May 9th, 2011, 08:33 PM | #13 |
ACE hardware I think has bearings and spacers. Orchard Supply Hardware also has a bunch of rubber/plastic/metal bearings and spacers. I'm sure one of those would work. Otherwise, I've seen many different diameters of steel tubing at home depot and other hardware stores that you could cut to length.
The chain roller link is a great idea though. Kudos to thinking outside of the box. |
May 9th, 2011, 11:34 PM | #14 | |
Happy to know a Sanjose rider>.I've lived in San jose for 20 years (Piedmont rd and Cropley Ave),just moved up here 3 years ago(because of my job) still miss sanjose alot |
May 9th, 2011, 11:53 PM | #15 | |
Let me know if you need them. |
May 11th, 2011, 06:16 AM | #16 |
Thanks! I won't know until I get new spools after my mishap.
May 11th, 2011, 06:47 AM | #17 |
May 11th, 2011, 08:20 AM | #18 |
May 11th, 2011, 08:25 AM | #19 | |
May 11th, 2011, 07:21 PM | #20 | |
[superbikeplanet.com] - Back in Stock & Shipping: "Roberts" and "Lawson" Yamaha Art P | Ninjette Newsbot | Motorcycling News | 0 | March 13th, 2015 01:40 PM |
[roadracingworld.com] - Yamaha Expects "Spy" Video Footage From Test To Be "Leaked" O | Ninjette Newsbot | Motorcycling News | 0 | February 27th, 2014 11:00 AM |
[topix.net] - "The Fonz", "Ralph Malph" & "Potsie" are giving away Fonzie's motorcycl | Ninjette Newsbot | Motorcycling News | 0 | August 16th, 2012 04:30 PM |
Bolt with "7" and a Red Dot | bananatwazzler | 2008 - 2012 Ninja 250R Tech Talk | 6 | August 23rd, 2011 05:52 PM |
[sportrider - latest stories] - Nitrous Oxide--"Wet" and "Dry" Kits | Ninjette Newsbot | Motorcycling News | 0 | April 9th, 2010 11:30 AM |
