May 3rd, 2012, 06:50 PM | #1 |
Rider of the Blue Comet
Danmoto Jisu rubbing on brake line.
Has anyone installed the Danmoto Jisu? Mine clears the swingarm, but I noticed the rear brake line rests right on one of the edges of the exhaust can. I've ridden many miles and the exhaust is hot to the touch, but doesn't feel hot enough to melt the rear brake line.
Does anyone know if the heat from the exhaust will adversely affect the rear brake fluid or possibly melt the rear brake line? |
May 3rd, 2012, 06:52 PM | #2 |
It can't be a good idea. Any way to re-route it, even slightly? Can you post a pic?
May 3rd, 2012, 06:58 PM | #3 |
I can take some pics tomorrow. The rear brake line is routed through those guides on the swingarm and doesn't give much play.
Looks like I might have to get some heat shield tape and wrap the brake line. |
May 3rd, 2012, 08:45 PM | #4 |
Join Date: Apr 2012 Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR Posts: A lot.
My Jisu isn't rubbing the brake line...
May 5th, 2012, 03:33 PM | #5 |
Join Date: Dec 2011 Motorcycle(s): '09 250R No longer. '06 Mini Posts: 116
I have no problem with the rubbing. You can rotate the can around the pipe end and clear away from potential things that may rub.
HTH |
May 6th, 2012, 05:58 AM | #6 | |
Thanks All. Posted via Mobile Device |
May 6th, 2012, 10:09 AM | #7 |
Jigglin' your Jiglets
MOTM - Apr '13
Just bend the metal holding the brake line
May 6th, 2012, 10:40 AM | #8 |
Join Date: Mar 2012 Motorcycle(s): '08 Ninja 250R (SOLD - 2/16/2013) Posts: 492
We need more/better clips of the Jisu, preferably not taken inside a garage! No offence Sean
Mods/Add-on list: DanMoto Jisu, Snorkel delete, Shimmed needles, K&N Drop-In filter, T-Rex frame sliders, Shogun swing-arm spools, CBR250 Rear Hugger, Buell XB Pegs. DIY polished rim lips |
May 6th, 2012, 11:25 AM | #9 |
I originally recorded it outside but it didn't transfer right, and it was already in the garage so I did it there. But I'll record a flyby and an outside idle/rev either tonight or tomorrow.
May 6th, 2012, 12:02 PM | #10 | |
Can wait to order mine and purr up and down my neighborhood
May 6th, 2012, 07:31 PM | #11 | |
Link to original page on YouTube. |
May 6th, 2012, 07:46 PM | #12 | |
Danmoto Jisu install problems? | chrisa7x | 2008 - 2012 Ninja 250R Tech Talk | 5 | April 14th, 2014 06:53 AM |
DanMoto JISU Discoloration Fix | cmSAE | 2008 - 2012 Ninja 250R Tech Talk | 12 | May 16th, 2013 03:20 PM |
Has anyone had any problems with the DanMoto JISU exhaust?? | NinjaBoyEddy | 2008 - 2012 Ninja 250R Tech Talk | 46 | January 8th, 2013 07:10 PM |
Danmoto Jisu vs Stock vs Baffle | MikeDohz | Videos | 2 | July 5th, 2012 07:00 AM |
Danmoto Jisu vs gp | -kj- | 2008 - 2012 Ninja 250R Tech Talk | 53 | May 30th, 2012 12:31 AM |
