February 22nd, 2011, 04:05 AM | #1 |
self wrencher
Temperature range
Hey guys
Anyone knows what is our bikes' operating temperture range for water and oil is? Also what the max water temp and oil temp before the light comes on? Thanks |
February 22nd, 2011, 05:34 AM | #2 |
Only spec I know is the the cooling fan should come on at 212 degree's
February 22nd, 2011, 05:36 AM | #3 |
self wrencher
If memory serves right, oem water light comes on at around 228F. Not sure oil though. What's the normal temp range for oil in general?
February 22nd, 2011, 05:53 AM | #4 |
I believe anything below the "flashpoint" of the oil you use is acceptable. I would think 400 or less but I don't know for sure.
February 22nd, 2011, 05:54 AM | #5 |
self wrencher
I may be wrong but if your engine oil is 400f your engine may be toasted?
February 22nd, 2011, 06:00 AM | #6 | |
Weird as I used to race go-carts and and our oil temps back then were high 300's and was not uncommon to see low 400's. Guess that's just that particular race application.
February 22nd, 2011, 10:46 AM | #7 |
For oil pressure testing purposes, kawa says the oil temp should be 194 degrees faren. @ 4000 rpms. Water temps avg. will range around 220-225 f. depending on conditions, but the warning light will come on above 230. If the water temp gets that hot, you can pretty much count on your oil being a little hotter than than the water temp. To burn off acids and water condensation in the oil, the oil temp should be above 180. Sustained oil temps above 250 will cause oil (conventional) to break down more quickly. Now that you have the Koso dash ou should be able to monitor your temps more closely, however I don't think you will be in any real danger zones unless you ride in desert type conditions alot.
February 22nd, 2011, 12:54 PM | #8 |
self wrencher
Thanks guys. I guess I'll set oil temp light to come on at 200F and water temp to come on at 228F.
February 22nd, 2011, 01:06 PM | #9 |
It's pretty common for oil to get hotter than the coolant. It doesn't reject heat as well and it goes places coolant can't go, like inside pistons, bearings, crank, etc. The cooling jacket only surrounds the cylinder head and the upper cylinder body; the crankcase and cam areas have no cooling. Heat transfers from the cylinder through metal to air, coolant, and oil. Air and coolant carry the heat away and the radiator can reject the coolant's heat, but the oil just stays in the engine.
February 22nd, 2011, 01:08 PM | #10 |
self wrencher
Just got info from a good shop owner:
Water:230 Oil reg: 240 Synthetic:260 |
February 22nd, 2011, 01:33 PM | #11 |
Join Date: Aug 2009 Motorcycle(s): '09 Ninja EX250J Posts: 177
this is very useful information, i always wondered how hot was too hot. i have the daytona temperature gauge (hooked up to the water) and my bike reached a peak temperature of 217...and that was when i had been sitting in traffic on a hot and humid summer afternoon.
February 22nd, 2011, 02:30 PM | #12 | |
February 23rd, 2011, 08:42 PM | #13 |
self wrencher
It's weird. Koso oil setting only max out at like 140 or somethig like that...hmm I'll set it at 199F to be safe for now
February 24th, 2011, 07:22 AM | #14 |
February 24th, 2011, 08:48 AM | #15 |
self wrencher
Yes, you're right...I mistyped. Anyhow, I guess that "synthetic: 260F" is wrong...I set mine to 198F and adjust as necessary. Need to wait for a hot summer day and see how far it goes up..then I guess I'll put it a few degrees above that.
February 24th, 2011, 09:55 AM | #16 |
I doubt Koso made the program with synthetic oil in mind. 220-225 would be a safe number to set it at.
February 28th, 2011, 04:06 PM | #17 |
Join Date: Feb 2011 Motorcycle(s): 2009 Kawasaki Ninja 250r Posts: 7
This is right out of the service manual . . . .
4-6 COOLING SYSTEM Coolant Flow Chart Permanent type antifreeze is used as a coolant to protect the cooling system from rust and corrosion. When the engine starts, the water pump turns and the coolant circulates. The thermostat is a wax pellet type which opens or closes with coolant temperature changes. The thermostat continuously changes its valve opening to keep the coolant temperature at the proper level. When coolant temperature is below 63.5 ∼ 66.5°C (146 ∼ 152°F), the thermostat closes so that the coolant flow is restricted through the air bleeder hole, causing the engine to warm up more quickly. When coolant temperature is more than 63.5 ∼ 66.5°C (146 ∼ 152°F), the thermostat opens and the coolant flows. When the coolant temperature goes up beyond 96 ∼ 100°C (205 ∼ 212°F), the radiator fan switch conducts to operate the radiator fan. The radiator fan draws air through the radiator core when there is not sufficient air flow such as at low speeds. This increases up the cooling action of the radiator. When the temperature is below 91°C (196°F), the fan switch opens and the radiator fan stops. In this way, this system controls the engine temperature within narrow limits where the engine operates most efficiently even if the engine load varies. The system is pressurized by the radiator cap to suppress boiling and the resultant air bubbles which can cause engine overheating. As the engine warms up, the coolant in the radiator and the water jacket expands. The excess coolant flows through the radiator cap and hose to the reserve tank to be stored there temporarily. Conversely, as the engine cools down, the coolant in the radiator and the water jacket contracts, and the stored coolant flows back to the radiator from the reserve tank. The radiator cap has two valves. One is a pressure valve which holds the pressure in the system when the engine is running. When the pressure exceeds 93 ∼ 123 kPa (0.95 ∼ 1.25 kgf/cm², 14 ∼ 18 psi) the pressure valve opens and releases the pressure to the reserve tank. As soon as pressure escapes, the valve closes, and keeps the pressure at 93 ∼ 123 kPa (0.95 ∼ 1.25 kgf/cm², 14 ∼ 18 psi). When the engine cools down, another small valve (vacuum valve) in the cap opens. As the coolant cools, the coolant contracts to form a vacuum in the system. The vacuum valve opens and allows the coolant from the reserve tank to enter the radiator. |
Article about brakes and temperature | Motofool | General Motorcycling Discussion | 1 | December 25th, 2013 11:40 AM |
engine stalls when up temperature | Bmwusa-e90 | 1986 - 2007 Ninja 250R Tech Talk | 5 | September 8th, 2013 08:29 PM |
A bit about tires and temperature | 2WheelGuy | Videos | 5 | March 6th, 2012 06:17 PM |
Daytona temperature gauge | randomwalk101 | Motorcycle-related | 4 | February 21st, 2011 02:16 PM |
Exhaust Temperature | paterick4o8 | 2008 - 2012 Ninja 250R Tech Talk | 22 | May 5th, 2009 07:40 PM |
