September 18th, 2012, 02:59 PM | #41 |
Jigglin' your Jiglets
MOTM - Apr '13
Aight @chodette and @alexis, I turned the idle screws in making it leaner because my bottom end is richer than mitt romney, 1 turn in (2 turns out) made it run worse so I tried 1 turn out on both and it the revs got so low the engine died. So I turned the idle knob up and put the screws all the way in to just start from base. 1 Turn out on each, running ok, 2 turns out, running good, 3 turns out running even better, but we know that 3 turns out is too rich, so I put it back to 2 turns and adjusted the idle knob to an appropriate level.
Do you suppose its possible that at idle (uncheckable as of now by AFR tool) I'm actually running lean but then once some throttle is applied it shoots way off to rich? Whats the course of action here???
September 18th, 2012, 03:06 PM | #42 |
Join Date: Nov 2011 Motorcycle(s): 2007 Ninja 250 (sold), '06 Ninja 650R Posts: 455
What is making you think that 3 turns out is too rich?
I would surmise from your post that you are actually too lean and need to keep turning the needle out (CCW) until you get a drop in RPM, then go in 1/4 turn. Sounds like you need to go up a pilot jet size. |
September 18th, 2012, 03:23 PM | #43 | |
also, they call me lexi. not alexis.
September 18th, 2012, 03:24 PM | #44 |
Jig, small changes dawg!! Like only 1/4 turn at a time. Start at 2.5 turns like stock, and try going out in 1/4 increments as needed.
September 18th, 2012, 03:36 PM | #45 | |
MOTM - Apr '13
Didn't you say go down a pilot jet because its too rich????? Lol fine, so you think I need to go richer?
September 18th, 2012, 03:52 PM | #46 |
You were too rich. Then you went too far and went lean. Where are you now? Make one small change at a time yo! you'z makin newbie mistakes.
September 18th, 2012, 03:52 PM | #47 | |
2. The start of the dyno run is too lean (High AF ratio). Keep turning the idle mixture screws CCW 1/4 turn at a time with the bike running until the rpm stops climbing. Then turn CW 1/4 turn. Then adjust your idle to ~1500. That should be about right at idle. |
September 18th, 2012, 04:51 PM | #48 | |
MOTM - Apr '13
I did the quarter turn thing (starting from all the way screwed in, wanted to be sure) and I ended up at 3 turns, then alex and chode both said its too rich and I need to screw it in more or go down a pilot jet
September 18th, 2012, 05:13 PM | #49 |
Ugh, so it was rich at 3, but hanging at idle on 2.5? try 2.75...
September 18th, 2012, 06:22 PM | #50 |
MOTM - Apr '13
Bah, I'll **** with the idle when I get the AFR guage installed
September 18th, 2012, 07:22 PM | #51 |
MOTM - Apr '13
Ok so I took the bike out, top end and midrange is feeling pretty damn good but low end under 5k runs like **** haha. It is hanging when reving down and there is like 0 power until 5k. That's indicative of too lean right right?
September 18th, 2012, 07:25 PM | #52 |
Don't give up now. People have been tuning carbs without AFR and dyno's for decades. It just takes some practice.
Keep turning the needles 1/4 at a time. As a check rev it up and watch how the rpm's return, if they hang high it's still lean, if the drop below it's rich. |
September 18th, 2012, 07:26 PM | #53 |
yes. Bring the mix screws out 1/4 turn.
September 18th, 2012, 07:30 PM | #54 | |
MOTM - Apr '13
Fa sho. It ran good at 3 turns out, I'm at 2 right now. 3 turns was apparently rich but it idled the best at that. Guess Ill do some of this quarter turn nonsense Oh and my off set screwdriver broke a tooth off. Isn't that nice
September 18th, 2012, 07:33 PM | #55 |
I took a bicycle tool apart and use the flat-screwdriver from that. Works well enough for me that I suggest buying a $2 bike tool from wally world and taking it apart for you carbs.
September 18th, 2012, 07:36 PM | #56 |
MOTM - Apr '13
It still works it just gets a little stuck on the broken tooth. I have to force it a bit and will likely end up breaking it some more I already ordered a new one though, will be here on thursday, AFTER I need it
K soon as I finish this sammich I'ma go do this! In the DURK!
September 19th, 2012, 06:27 PM | #57 |
MOTM - Apr '13
Ok, so I started from 2 turns out and went by a quarter turn all the way to 4 turns and the low end is all poop, even though it wasn't this bad before at 3 turns. I've since gone up 2 sizes in the jets and gone up 2 clip positions on the needles, then I decided to tune the idle and it seems like no matter what position the screws are at its always lean (this is lean right?) I ordered the next size up pilots #40 but they won't arrive before the dyno
Here's a vid of how its running right now just to confirm that I am actually too lean
September 19th, 2012, 10:09 PM | #58 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
dat last pull...
need mo' brap brap. |
September 19th, 2012, 10:40 PM | #59 |
Join Date: Jan 2012 Motorcycle(s): 2009 250r, 2000 zuma, 1980 sachs prima Posts: 34
Could be a vacuum problem. After I re jetted mine it ran awesome from 4 thousand to to the limiter but had a bad hang going back to the idle. I had a vacuum line routed wrong. You could check your lines and check to make sure there not cracked.
September 19th, 2012, 10:42 PM | #60 |
MOTM - Apr '13
Hmm, do you recall which one?
September 19th, 2012, 11:26 PM | #61 |
No I don't recall. If I where u I would find the diagram and check your hoses though. That's how I found it. If it is your problem you could mess with the mixtures screws all week and get nowhere. As soon as I figured it out it ran awesome at 2 3/4 turns out and dropped right to idle.
September 19th, 2012, 11:27 PM | #62 |
MOTM - Apr '13
What mods do you have?
September 19th, 2012, 11:48 PM | #63 |
Join Date: Aug 2012 Motorcycle(s): many kawasaki 2 stroke triples and a 250R now. Well no more 250R, 2013 300 now Posts: 146
I would say you are trying to tune the wrong circuit. The "idle" circuit which consists of the pilot jet and fuel screw, is basically only for your idle mixture. When adjusting your fuel screw, it should be turned in and out until you get the highest idle. What that means is you have the best air/fuel mixture for idle. And that circuit is done, no need for any more adjustment.
In the vid, it sounds rich, as the motor is studdering, where as a lean mixture would cause a flat response. That would be either your needle position, spring tension on the slides, or the air bleed hole size in your slide. And it is a misconception that a dyno run is just sampling your main jet. As you are rolling on the throttle, it is sampling the air/fuel mixture in your low/mid rpm section (needle/needle jet) I equate the needle/needle jet with accelerate pumps on older cars and carbed hot rods. As you roll or whack open the throttle, the fuel/air coming in has to be the correct ratio. Just as the accelerator pump adds a lot of fuel when throttle valves are opened up letting in a lot of air. If your needle/needle is incorrect, either the motor stumbles trying to burn too much fuel, and doesn't fire every time it should, or if it's lean, there is not enough fuel for each combustion cycle and the motor runs flat like you are running out of gas. Get the idle circuit correct, then work on the needle position. |
September 19th, 2012, 11:54 PM | #64 |
Slipon 2 brothers. Snorkel removed. Dynojet kit. Pipercross air filter.
September 20th, 2012, 12:10 AM | #65 | |
MOTM - Apr '13
Oh and I'm having them install an O2 bung so I'm hoping we can just plug the AFR gauge of the dyno straight into my midpipe for a more accurate AFR reading
September 20th, 2012, 12:23 AM | #66 | |
September 20th, 2012, 12:33 AM | #67 |
MOTM - Apr '13
Welp, no matter the throttle setting it ran like poop from 3-5k whether WOT or not.
I'm a bit confused about how this works, lets say I go WOT at 1.5k rpms and it revs up to 3 still WOT, if I were to be checking the AFR, would I only be seeing the AFR of the main jet? So according to this chart, if I'm at WOT (assume I've been at WOT) would I only be seeing the main jet come into effect like this chart says? Originally that's how I thought it worked, then I read something that had me thinking that pilots affect low range (0-5k), needle affects midrange (5k-9k) and mains affect top end (9k-redline). If you can answer this question I think I'll understand If I am WOT at 3k rpms, is the main jet the main factor into how much fuel is delivered?
September 20th, 2012, 12:52 AM | #68 | |
September 20th, 2012, 12:59 AM | #69 |
MOTM - Apr '13
Ok, through your answers and a bit of reading on carbs I have a very mildly vague idea about how this works
When you said if I'm in the power band then yes its showing the main jet, is that because at that point the engine is revving fast enough that it is sucking in enough air that the main jet is the "limiting factor" in how much fuel is being added? Right now, I think my main is about right or one size too big, I'll see when I get on the dyno. My needle is way too damn high, that is for sure and I think what is causing the problems at 3-5k, its just letting in too much fuel. I'll drop it down to 4th position when I get a chance. So then Ja-moo, if you look at my dyno, what do you make of that? What would be the reason (its done at WOT by the way) that it goes from an AFR of 10.0 at 3k to an AFR of 16.0 at 6k? And how would I fix that? And finally, while I have the dyno tomorrow should I test like a 1/4-half throttle rev through the entire range? That would tell me how well the needle is seated right? Boy learning sure is fun! Maybe I'll just take the easy route and install EFI so the computer can have all the fun tuning the AFR to perfection
September 20th, 2012, 02:58 AM | #70 |
MOTM - Sep '18, Feb '16
You are getting there.
One thing that is confusing you is wide open throttle just opens the throttle. The slide does not start to move until after the throttle moves then it starts to move according to engine speed. Opening up the throttle at 3000 rpm will not go immediately to the main jet. So maybe think idle jet from idle to 2000. pilot jet from 1500to 4500, main jet and needle from there. They all overlap. The idle holes are built into the carb body and throttle plate. Once you open the throttle they are done.then it is pilot jets. Did the pilot jets come in yet? turning the screws all day will not make any difference once you start to open the throttle. That is why a richer pilot helps with cold running.It gives more fuel with the cold air. Maybe this will help. http://www.gadgetjq.com/keihin_carb.htm
September 20th, 2012, 10:50 AM | #71 | |
September 20th, 2012, 10:56 AM | #72 |
MOTM - Apr '13
I think that it is resisted, it has settings for vehicle weight and stuff like that. They are also capable of recording quarter mile times on it, if it wasn't resisted people would get ridiculously fast '1/4 mile' times right? Idk I'll ask him.
And the dyno is done in 4th gear. What would you recommend, rev the bike to 4k in 4th and then do a wot roll on?
September 20th, 2012, 01:33 PM | #73 |
MOTM - Apr '13
Well my Afr curve is **** right now but at peak I just made 30.5hp. What now bitches!?!?
September 20th, 2012, 01:39 PM | #74 |
September 20th, 2012, 02:04 PM | #75 |
You are lean for safety. Try to get closer to 13. Have you installed the BRT ignition system? What jets are you using?
September 20th, 2012, 02:09 PM | #76 |
If your max afr is 12.2 you are way too rich. at least one jet size. What does the whole plot look like?
September 20th, 2012, 02:15 PM | #77 | |
MOTM - Apr '13
Oh for sure its scanning right now. My poop zone at 3-4k had an AFR of like 8, it was so bad. When I got to the place I switched my needle position from 5 to 4 and we ran it but it still had that crap zone. After the dyno run was finished I saw that at idle my afr was between 11-12 (it would change around in that region) so I adjusted the mix screws in a quarter turn to 2.75 out and when I left, the poop zone was gone! Most likely I'm at the rich limit in that 3-4 zone
September 20th, 2012, 02:21 PM | #78 | |
MOTM - Apr '13
Since I changed the mix screws a quarter turn leaner, that lower poop zone is gone, most likely its at the rich limit. My O2 bung and sensor have been installed, I just need to wire up the guage so it turns on
September 20th, 2012, 02:58 PM | #79 |
The BRT igntion system is adjustable. You can add timing at 7000 and take a little away at 9000 going say from 42 to 44 then back to 42. That will remove the flat spot in your curve, Also give more than 7 deg advance at red line raising the HP some more. On top of that you can raise the rev limit to 14000 from the factory 13500. That way you can push the engine a little harder and not hit the factory limiter that comes on to strong.
wait there's more. You have two maps to choose from on the fly with a bar mounted switch. Before when I said 48 pilots .I ment going from stock 30 to 40. My bad.
September 20th, 2012, 03:01 PM | #80 |
MOTM - Apr '13
Well, the BRT sounds sexy as hell, whats the typical price associated with one?
Dynamometer / Tuning / Jetting / Performance / Cost Question | dcj13 | General Motorcycling Discussion | 2 | December 20th, 2014 05:22 PM |
Dyno-tuning Results Two Brothers Exhaust | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 21st, 2012 07:23 PM |
Dyno Charts with jetting and stock exhaust? | KURT | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 27th, 2011 10:03 AM |
08 250R Dyno / after full exhaust + jetting | Order | Videos | 20 | January 19th, 2011 11:12 PM |
Dyno (re)Tuning Mods (with problems) vs Stock - Video and Graphs | TheDuck | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 9th, 2010 02:27 PM |
