Old March 5th, 2020, 10:05 PM   #1
woodchipliz
woodchipliz's Avatar
Motorcycle(s): 93 ex250
idle @ 7k when choke is on - Fixed
So i did a full tear down, clean and inspection of the carbs. I still have the same problem. When my choke is wide open the bike revs to 7k. If i reduce the choke the engines stalls.
Once warm it idles at 1500
Any ideas why the rpm is so high?
Last futzed with by woodchipliz; March 6th, 2020 at 02:19 PM.
woodchipliz is offline   Reply With Quote
Old March 6th, 2020, 07:38 AM   #2
Can you just back it down enough to get the RPMs about 2500?
It's an enrichener, so raising the RPMs is common.
Once it starts I always set it so it will keep running at a moderate RPM, usually in the 2500 range, until I get my gear on and take off. At that point it will usually idle (barely) with the choke off.
Old March 6th, 2020, 02:18 PM   #3
woodchipliz
Fixed it. Choke rpm is now 4 - 5 K
Old March 6th, 2020, 04:18 PM   #4
What was the problem?
Old March 7th, 2020, 11:24 AM   #5
woodchipliz
in my case i noticed that the right butterfly was opened more than the left one, so i bench sync the carbs and that fixed it
Bike not idling below half choke, idle screw not affecting idle speed Zaraki_Kenpachi 1986 - 2007 Ninja 250R Tech Talk 2 March 6th, 2020 11:13 AM
Dying at idle with choke off jonnybravo9 2008 - 2012 Ninja 250R Tech Talk 6 October 2nd, 2014 09:17 PM
Choke has no effect on idle... Help. Jono 1986 - 2007 Ninja 250R Tech Talk 15 September 14th, 2011 09:45 PM
Choke Idle Speed has Changed patw 2008 - 2012 Ninja 250R Tech Talk 21 August 1st, 2010 10:27 PM
