June 28th, 2011, 02:30 PM | #1 |
[motorcyclistonline] - New Low-Profile Oil Drain Pan from Harley-Davidson
Design Includes Hardware Corral, Pressure Vent Hole and Carrying HandleMILWAUKEE (June 27, 2011) The new Low-Profile Oil Drain Pan (P/N 63795-10, $29.95) from Harley-Davidson® Genuine Motor Accessories can help reduce the mess and clean-up required when changing motorcycle fluids. Designed specifically for use with Harley-Davidson motorcycles, the low-profile design fits under lowered motorcycles, even when on the side stand. The 10-quart capacity will capture two engine-oil changes or the complete drain fluids (engine oil, primary and transmission) from one motorcycle. Large enough to catch the oil from the entire length of the primary, this drain pan will also hold and drain an inverted primary cover. The drain pan features a raised hardware corral, a filter drain surface, and a pressure vent hole that prevents messy oil burping. Drained waste oil is sealed inside the pan with high-quality gasketed caps and plugs. A convenient carrying handle simplifies transport to an approved waste oil facility. New Low-Profile Oil Drain Pan from Harley-Davidson | Digg It | Add to del.icio.us Click here for full story...
[motorcyclistonline] - 2015 Harley-Davidson Ultra Classic Low | FIRST RIDE | Ninjette Newsbot | Motorcycling News | 0 | February 22nd, 2015 07:00 PM |
[motorcycle.com] - Harley-Davidson Goes Low for 2015 | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2014 09:40 AM |
[motorcyclistonline] - Harley-Davidson Low Rider | First Ride | Ninjette Newsbot | Motorcycling News | 0 | June 15th, 2014 06:20 AM |
Oil drain plug gasket for oil change. | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 10th, 2012 01:00 PM |
[topix.net] - Business Profile: Stock's Harley-Davidson | Ninjette Newsbot | Motorcycling News | 0 | June 20th, 2010 12:10 PM |
