Old April 24th, 2012, 05:16 PM   #1
CalvinAmI
CalvinAmI's Avatar
Motorcycle(s): '09 Ninja 250r [RED] & '06 Ninja 250 [WHITE]
GUNK in my head!
Oh boy. I believe I just opened a can of worms.
I removed my airbox then removed the carbs to clean, jet, shim, etc.
When draining the float bowls, I noticed the left side (facing the front like sitting on the bike) the fuel draining was crystal clean fuel. "Great!" I said internally.
The right float bowl was drained after and dripped out a good amount of rusty looking crud along with the fuel. Not sludge, just 'dirty' looking fuel with tiny muddy particles smaller than a grain of sand. "Great! There's my problem!" I said internally.
Next I decided to take a peek inside the head (i assume because that is what the rubber boot things said on that end). On the left I see 2 holes with rods going down in some dark oil. (I DID change the oil when I got the bike and haven't put 100 miles on it since... been fixing and modding little stuff. I'll probably change the oil again after I get this cleaning/jetting/pod/etc mod done.)
Well, I move over to the right side and couldn't believe what I was seeing. It looked like SLUDGE that the two rods were sitting in. Really thick lumpy chunky sludge. Have a look for yourself to see what I am talking about. (pics and video taken with my phone with not-so-great lighting, but you can see what I am seeing)
What do I do with the right side? Leave it alone? dip a Q-tip in there and try to remove the sludge? Any thoughts or suggestions?
CalvinAmI is offline   Reply With Quote
Old April 24th, 2012, 06:13 PM   #2
Jono
Jono's Avatar
Did you try blowing your nose?
Old April 24th, 2012, 07:25 PM   #3
CalvinAmI
CalvinAmI's Avatar
Like I am gonna take my fingers out of my nose long enough to blow it... NOT LIKELY!
Old April 24th, 2012, 07:34 PM   #4
Jono
Jono's Avatar
Lolz!
But I don't have a clue what that gunk is on your engine.
Old April 25th, 2012, 01:47 AM   #5
maybe sand will help
Old April 25th, 2012, 01:59 AM   #6
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
Those rods are your valves. The holes are the intake ports.
To my knowledge there shouldn't be oil there. There's valve guide seals in there that prevent that. Does the crankcase breather recirculate into the airbox on ninjas? If it does, that's probably where the oil came from, unless your seals/rings/cylinders are leaking. If it's just the recirculated crap, it's likely a mix of oil and dirt. Your best bet is to blast it with piss and kill it with fire.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old April 25th, 2012, 06:08 AM   #7
CalvinAmI
CalvinAmI's Avatar
Ha! I think i found what that stuff is.
http://www.southbayriders.com/forums...=116254&page=6
It seems to be unburned hydrocarbon buildup. Its natural when crappy gas has been used for a long time with no cleaners (Seafoam). This bike was VERY abused before I got it. I can guarantee it had never seen a bath since It rolled off the production floor. 6 years of sludge, grime, & mud all over everything. I am surprised it even ran (got it for cheap). All the fluids had to be original also. Brake fluid was dark brown, engine coolant was thick and dark green, oil was black with particles, fuel tank hasn't been drained yet but I bet its got a nice amount of crud in it =)
I am not worried about the gunk in there. I'll just ignore it for now and run some seafoam through the next couple of tanks of fuel.
[American Motorcyclist Association] - Chris Borich and Walker Fowler go head-to-head Ninjette Newsbot Motorcycling News 0 October 2nd, 2014 07:10 AM
Front Sprocket Gunk? kaybray 2008 - 2012 Ninja 250R Tech Talk 14 November 2nd, 2013 06:19 AM
Need help identifying carburetor gunk and removing pilot Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 15 August 4th, 2012 07:45 PM
[motorcyclistonline] - Gunk Introduces New Engine Protector to Cleaning System Line-U Ninjette Newsbot Motorcycling News 0 March 11th, 2011 06:20 PM
Truck Headlight Gunk delsin Off-Topic 13 March 8th, 2011 12:00 PM
