September 11th, 2009, 05:25 PM | #1 |
Join Date: Jul 2009 Motorcycle(s): 2005 ninja 250 Posts: 17
RPM's on highway-a little high?
So, I looked but couldnt really find much on my question. Well I have but they are all lower than mine. I have an '05 -250 In 6th gear on the highway my rpm's seem a bit high. Off the top I know my speed-o is about 5mph off. say im doing 75 it's really doing @70ish. When I'm doing 80 (so thats 75mph) my rpm's are at 10k ...am I just worried or is that a bit high? I was watching a guys youtube ride/vlog with a 250 and he was at 7500rpm doing 72-75 mph on the highway. I should note that his is an '08 250 ...i know there are some diff. to the motor from what ive read... but is mine way too high for only doing @75mph? (I'm here in AZ so the speed limit is 75mph) if so is there anything I should do or look at? TIA
edit-i should also say i have read some about older gens tac's not being correct....could this be true? what should the rpm's be at -at this speed? tia |
September 11th, 2009, 08:50 PM | #2 |
Newb..... on a steeek! :D
Join Date: Feb 2009 Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow Posts: A lot.
No, you're not really far off. The guy in the youtube video had different sprockets to lower the rpm's. I have stock gearing but a modded engine on a '94 ninjette. At almost any indicated speed in 6th gear I'll be running at about 1000-1500 rpm's higher then the speed indicated. So at 80 indicated I'm usually running close to 9500 rpms.
So, no your bike is ok. |
Just cleaned carbs - now stuttering at low RPM, fine at high RPM | Ohio | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 5th, 2014 10:30 PM |
High rpm running | mikromo | General Motorcycling Discussion | 4 | September 21st, 2013 09:46 AM |
High handle bar vibration, hard to get into high RPM, is this normal? | jackliu239 | 1986 - 2007 Ninja 250R Tech Talk | 24 | September 19th, 2013 09:04 PM |
Highway speed in relation to rpm.. | Rollingmenace | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 5th, 2013 04:10 PM |
Rpm too high? | mms1361 | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 3rd, 2011 07:20 PM |
