March 7th, 2010, 06:11 PM | #1 |
Join Date: Jan 2010 Motorcycle(s): 2009 Kawasaki Ninja 250r Special Edition Posts: 217
Brakes rubbing
Just wondering if anyone has the same "problem" i say that because i doubt its a big deal. When the bike is off and im just pushing it in our out of the shed, etc. the front disc makes noise as the brake pad is rubbing it. I dont know if this is normal to a certain degree or if i should get the dealer to look at it?
March 7th, 2010, 06:16 PM | #2 |
2008 Kawasaki Ninja 250R
Join Date: Jan 2009 Motorcycle(s): 08 Ninja 250R Posts: 43
My bike does the samething... I never thought much of it but maybe it should be looked at.
March 7th, 2010, 06:20 PM | #3 |
2012 is here,let's ride!!
Join Date: Sep 2009 Motorcycle(s): 2009R,'12 suzuki +500 Posts: 354
same here but not worried about it maybe needs cleaning!?
March 7th, 2010, 06:22 PM | #4 |
You are sleeping
There's no rebound spring on the pads. They are free to rub the rotor if you don't press the lever to squeeze them to it.
<Yeah, it's a 250. LMFAO! Weaksauce |
March 7th, 2010, 08:03 PM | #5 |
This is normal with all disk brakes whether they are on a motorcycle or a car. The pads are always slightly in contact with the rotors until you apply pressure to them for braking.
Rubbing sound in top end? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 16th, 2012 07:10 PM |
DMV needs a pencil rubbing of my VIN? | rmorse | General Motorcycling Discussion | 16 | May 24th, 2012 11:47 AM |
Danmoto Jisu rubbing on brake line. | wicked300z | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 6th, 2012 07:46 PM |
Rubbing / chaffing noise | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 27th, 2012 06:03 PM |
Pulsing, rubbing noise - front brake? | ccampbell | 1986 - 2007 Ninja 250R Tech Talk | 3 | November 28th, 2010 06:53 AM |
