Old May 9th, 2010, 06:16 PM   #1
Gyrene
Motorcycle(s): 2004 Ninja 250
Vibration!!!!!!
My 2004 Ninja 250 vibrates like crazy the faster I go, not shaking but vibration. It get's so bad that on long rides my hands become numb, especially my fingers. It is as though my fingers are falling asleep. I know that on 250's this is the norm but is there any recommendations on a way to reduce the amount of "felt" vibration? Would foam grips help? I feel like I have carpel tunnel going on in my wrists after only 350 miles on the bike.
YouTube
Most motorcycle problems are caused by the nut that connects the handlebars to the saddle.
Gyrene is offline   Reply With Quote
Old May 9th, 2010, 07:44 PM   #2
make sure your motor mounts are tight.
Old May 10th, 2010, 06:36 AM   #3
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
I was very surprised to find all three of my engine mount bolts had come loose. The two rear ones have nuts and the front one goes into a blind nut that is welded to the frame. If they are loose, use some Loctite when you re secure them.
JeffM is offline   Reply With Quote
Old May 17th, 2010, 07:42 AM   #4
nosro
Motorcycle(s): 2006 ex250
I was also surprised by how loose my engine mount bolts were. At 6000 miles, the bolts have needed to be retightened three times. At one point, one of the bolts was so loose that it was nearly "finger" tight. I'm using blue Loctite next time.
Use a torque wrench.
http://faq.ninja250.org/wiki/Checkin...ne_mount_bolts
nosro is offline   Reply With Quote
Old May 25th, 2010, 09:44 PM   #5
03slime250
Motorcycle(s): 2003 ninja 250
do you have bar ends on it?
03slime250 is offline   Reply With Quote
Old May 28th, 2010, 11:58 PM   #6
longhorn
Vibration!!!
After only 350 miles! It's a sport bike not a cruiser, much over 100 miles is cruel and unusual punishment on a ninjette. I admire your tenacity. It shouldn't vibrate that much, mine doesn't. But as the others said "check engine bolts" first, don't grip the bars; just hold them gently and if all that fails think of changing out the gearing (see posts on "Sprockets" above).
longhorn is offline   Reply With Quote
Old May 29th, 2010, 12:44 AM   #7
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
so .. did ya find out what's causing the bad vibes?
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old June 2nd, 2010, 10:55 AM   #8
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
High frequency vibrations I think are norm for this bike; it's very hard to get a smooth two cylinder motor unless they're opposed pistons like BMW. I've got the stock bars and bar end weights on my '06, but run gel grips and gel gloves. When I ride I don't grip the bars; a tight grip transmits more vibration energy into my hands. Since going with gel grips and modifying my hand position I haven't had any problems with numbness or fatigue. I may fill the bars with steel or lead shot in the future just to see what happens.
Vibration while idling. sailorninja 1986 - 2007 Ninja 250R Tech Talk 17 October 9th, 2014 12:04 PM
Increased vibration Olie 2008 - 2012 Ninja 250R Tech Talk 5 May 29th, 2014 06:31 AM
Wrist vibration setasai General Motorcycling Discussion 12 July 12th, 2011 02:41 PM
Vibration singlecoillover 2008 - 2012 Ninja 250R Tech Talk 11 March 3rd, 2011 11:48 AM
Please help me!!!! - vibration MikeCG23 2008 - 2012 Ninja 250R Tech Talk 6 August 27th, 2010 03:51 AM
