December 4th, 2010, 02:07 PM | #1 |
Join Date: Aug 2010 Motorcycle(s): 2009 Ninja 250r Posts: 61
R-0990 filter and stock intake runners
Hello.
I was curious as to how you fellow ninjetters are connecting the stock intake runners to the R-0990 filter? The runners are a very soft rubber and dont really see how they would make a good seal. Also, what are the effects of just putting the filter directly onto the carbs? I am assuming the lower end of the powerband would benefit from the runners being used, right? Thanks in advance! |
December 4th, 2010, 02:13 PM | #2 |
Join Date: Apr 2010 Motorcycle(s): Yahama v star 650 classic Posts: A lot.
You can slid the runners into the filter fairly easy. Ive seen some people put lube of some kind to help seal it. I have a pic of my filtr on the runners in my album. Id post the pic but im on my cell phone. I think with out the runners, it can hurt performance.
Posted via Mobile Device |
December 4th, 2010, 02:17 PM | #3 |
Here's scotty's picture:
December 4th, 2010, 03:25 PM | #4 |
What are runners? The black pipes between the filter and the carbs?
December 4th, 2010, 03:57 PM | #5 |
MOTM - Sep '18, Feb '16
I just mounted the KN0990 air filter directly to the carbs.
Last futzed with by Racer x; December 5th, 2010 at 06:50 AM. |
December 4th, 2010, 05:03 PM | #6 |
Mine are mounted directly to the carbs. AFAIK, people only have used those runners with the filters to keep the filters from rubbing on the frame. Also, AFAIK, runner length would only affect performance if it were changed between the carbs and head, not between the carbs and filter.
Factory Pro Jet Kit, K&N R-0990 Pod Filter, Sportisi VR Black Exhaust, BRT TIS Ignition, White Paint, and 16/41 Sprockets. Soon: Maybe a 37T Rear Sprocket if I get things running like I'd hoped. |
December 4th, 2010, 05:23 PM | #7 |
IC2(SW)
December 4th, 2010, 05:41 PM | #8 | |
I didnt even think of that. You are bang on!! I am glad you brought that up. I would prefer to mount mine directly to the carb. Thanks for your insight everyone!!! |
December 4th, 2010, 07:24 PM | #9 |
Thanks Alex!
Eric, how did you get the filter on the carbs with out the unners? I tried doing that, but they would'nt sit on the lip far enuff to be able to tighten down. Have you tried both ways with and with out the runners? If so, did you notice any differnce?
December 5th, 2010, 07:07 AM | #10 | ||
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
Now, I can pull it on and off no problem (after loosening it of course). My advice is to use some grease as lube, make sure the clamps are loose and have the screws for the clamps facing up towards the petrol tank on the sides. Example (frame, screw, filter, screw, frame): | * ( ^ ^ ) * | |
December 5th, 2010, 07:28 AM | #11 |
OK I found the stuff and took some photos
YA don't over tighten the clamps Hi GiGs Hows the bike going? |
Free K&N R-0990 Filter | sjc88 | Free stuff! | 10 | October 17th, 2014 05:20 PM |
Shortening intake runners/enlarging opening | quarterliter | 1986 - 2007 Ninja 250R Tech Talk | 15 | July 1st, 2013 07:28 AM |
BRAND NEW K&N R-0990 Air Filter | SMman | Motorcycle-related | 4 | January 29th, 2013 06:58 PM |
K&n 0990 filter on fi ninja | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 14 | April 19th, 2012 04:25 PM |
Gas spills out of my 0990 Air Filter! !@#$% | 00v_Lucky | 2008 - 2012 Ninja 250R Tech Talk | 15 | September 18th, 2010 05:20 PM |
