December 8th, 2010, 05:19 PM | #1 |
Starting in the cold + Carb Questions
So, last week coming from work at around 3AM, the temp was -5degC. I had full choke. Started up the bike. Bike ran. And 2 seconds later, died.
I started it up again. Again ran and died after 3 or so seconds. Adding throttle made it die faster (I was sure the battery would die before the bike reached normal running condition). I did this atleast 5 times before it finally started it up at very low RPM and VERY slowly climbed upto normal idle RPM. Bike starts up fine when it's warmed up. Runs fine. Etc. I posted the same topic on another forum and people say that it's because the mixture is too lean. So, messing around with the carbs should fix this......? Before I jump in, a few questions: 1) Is this a good simplified explanation of the CVK carbs on our bikes: http://www.youtube.com/watch?v=zUuVQfvWSnI ?? 2) According to that and from what I've been reading here, there are two ways to enrichen the mixture. By getting a smaller needle. Or by raising the already existing needle by putting washers on it. Is this right? 3) The more washers I put on the main jet needle, the richer the mixture will get, right? 4) Any disadvantages of using washers over putting a smaller needle in? 5) Should I mess with the idle screws before or after adjusting the needle? 6) Is there anything else I should do before I adjust the needle? 7) Is it necessary to drain the float bowls to adjust the needle and the idle screws? More to come. |
December 8th, 2010, 05:21 PM | #2 |
8) Is there a pilot needle too or is the idle mixture only adjusted with the screws?
Hard starting in cold weather | scorch | 1986 - 2007 Ninja 250R Tech Talk | 23 | May 13th, 2016 08:25 PM |
Starting and riding on cold engine | itslocfoo | 1986 - 2007 Ninja 250R Tech Talk | 7 | December 10th, 2013 05:51 PM |
Bike having trouble starting and running when cold | jwollam | 2008 - 2012 Ninja 250R Tech Talk | 10 | February 12th, 2013 06:47 PM |
Weird Cold Starting Idle | ajcadoo | 2008 - 2012 Ninja 250R Tech Talk | 9 | March 6th, 2012 08:54 AM |
Having trouble starting in cold weather. | d16soda | 1986 - 2007 Ninja 250R Tech Talk | 7 | September 20th, 2011 10:47 AM |
