Old April 10th, 2011, 05:44 PM   #1
red
Motorcycle(s): TR7, Trident, SuperIII, BMW, HD, Duc, Vespa, MP3
gear whine
There has always been lot of gear noise when under power on my bike, relative to the other bikes in the garage (no Kawasaki other than the ninjette). The bike is relatively new and has less than 1000 miles on it.
The noise goes away when the clutch is pulled in. The chain is not too tight.
Do these make a lot of gear noise? Remedy?
Thanks for opinions
2010 Ninja 250R SE - I got this bike for my wife. It was a good trade.
red is offline   Reply With Quote
Old April 10th, 2011, 06:54 PM   #2
cwb48
Mature motorcyclist
cwb48's Avatar
Motorcycle(s): 2008 Ninja 250R, blue
Yeah, the whine is pretty noticible sometimes. Both my '01 and '08 do it, but sometimes I notice it, and sometimes I don't. I've always thought it was the clutch- seems to come from the right side.
It also doesn't seem to be there when accelerating hard, so there's a possible solution.
I don't think it's a defect or problem of any kind, just a quirk.
Chris
cwb48 is offline   Reply With Quote
Old April 11th, 2011, 10:00 AM   #3
dubojr1
dubojr1's Avatar
I remember a whine when mine was new. Either I don't notice it now or it was part of the "break-in".
Old April 11th, 2011, 10:05 AM   #4
red
Mine is loud. Maybe break in will take care of it.
Old April 11th, 2011, 10:17 AM   #5
is your oil level at the proper level in the sight glass?
Old April 11th, 2011, 12:54 PM   #6
red
Oil level looks fine. I can't remember if I changed the oil when I got it so it may be time for fresh reduced-whine oil this weekend. Still has lt 1000 miles. Maybe a premium syn cycle oil.
Old April 11th, 2011, 12:58 PM   #7
don't know if changing the oil will help with the whine level, just wanted to make sure you had enough in the crankcase. Low oil levels can cause more crankcase noise.
My bike whines... and pouts and even has tantrums... I just chalk it up to it being a ninjette.
btw, do you wear ear plugs? that's a good way to getting rid of hearing the whine and to save your hearing.
Last futzed with by kkim; April 11th, 2011 at 02:21 PM.
Old April 11th, 2011, 07:22 PM   #8
red
It's probably due for an oil and filter anyway.
Typically I do not wear plugs unless I am on the highway on a bike that puts the helmet full in the wind. My helmets are pretty quiet.
I must admit that the test riding around the block I have been doing after carb flddling on the ninja have not been following the ATGATT and all bikes make a lot of mechanical racket when you're putting around with ears in the open. But this ninja's noise is a serious gear whine, lots more that anything I am familiar with.
I'll put another thousand miles on it and see if it goes away.
Old April 15th, 2011, 04:01 PM   #9
red
Fresh oil seems to have helped a bit. We'll see after a few thousand miles if it subsides after break in.
Old April 15th, 2011, 04:38 PM   #10
sowega
sowega's Avatar
Motorcycle(s): 899, 748, 250, 250, 70
Kawasakis typically have loud drivetrains; my old 2000 ZX6R, 1998 ZX7R, and 2004 ZX636R all had tons of what I thought was loud mechanical noise while breaking in.
sowega is offline   Reply With Quote
Old April 16th, 2011, 01:21 PM   #11
red
Thanks - was trying to figure out whether a lot of gear whine was normal for these. Sounds like it is.
Old April 19th, 2011, 05:03 PM   #12
onizthegnome
certified newbie
onizthegnome's Avatar
Motorcycle(s): 08 ninja 250r blue
this whine you are hearing, does it happen when you are engine braking? i am starting to notice a low humming sound when i decelerate. i cant tell if its from the engine or the front wheel. it sounds like its coming somewhere from the front though.
locktite ALL the things!!!
onizthegnome is offline   Reply With Quote
Old April 19th, 2011, 07:30 PM   #13
red
Mine is not a low humming, but a gear whine anytime there is load on the transmission.
And of course it is mitigated quite a bit with a helmet on
Gas tank whine or not...at WOT Redsvt 2008 - 2012 Ninja 250R Tech Talk 17 November 15th, 2012 07:05 AM
High pitched engine whine when speeding up. Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 3 October 10th, 2012 09:08 AM
Will these fix that annoying fuel cap whine??? dubojr1 2008 - 2012 Ninja 250R Tech Talk 23 June 30th, 2011 08:19 PM
Whine/squeak from front wheel GeneJunkie 2008 - 2012 Ninja 250R Tech Talk 14 January 10th, 2011 03:16 PM
high pitch whine, even while riding Hokie11 2008 - 2012 Ninja 250R Tech Talk 7 August 17th, 2009 06:18 PM
