August 15th, 2011, 09:48 PM | #1 |
New engine, new clutch problem
I'm starting a new thread on my [new] clutch problems, because it is now on a new engine (1.2K miles).
I want to cry. I am now having the SAME problem with the clutch on my new engine, that I had on the old one The friction point is all the way out, and the cable has a ton of slack... How on earth can the new clutch in the new engine have the same problem as my old clutch, in my old engine. The only part that is the same is the clutch cable. I see zero signs of damage or fraying. I don't think it could be too stretched, because if I don't loosen the heck out of it, the problem gets worse. If I adjust the cable the way it is supposed to be, my hand won't even open wide enough to release the clutch smoothly. Since I got the engine from a 2010 salvage from an ebay wrecker, I don't really know the history of the engine, but it sure was clean, and had no visible signs of damage. I also have another thread open about a whine.... the current theory I am chasing down is possible an over-tight cam chain. With 1.2K miles, it SHOULDN'T have had the valve cover off, so it probably didn't have botched work for the cams or valves. I really don't even know what to think anymore. I don't know what to do, but cry...
August 15th, 2011, 10:23 PM | #2 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
Is the clutch fully engaged with no slipping without a cable? If so, then the problem is the cable/lever/adjuster.
"What a sweetheart."- ninja_sleeper to me |
August 15th, 2011, 10:31 PM | #3 |
Correct... I think. I just ordered a cable, although I see no damage on the old one. I've done so much chasing my tail this year, that I needed to know it wasn't the cable, so I'm glad you said that.
August 16th, 2011, 05:25 AM | #4 |
Keep us updated Bob.
August 16th, 2011, 07:32 AM | #5 | |
Mature motorcyclist
Join Date: Jan 2009 Motorcycle(s): 2008 Ninja 250R, blue Posts: 126
Could it be that you have unusually small hands? In that case, a set of adjustable levers could solve your problem. Chris |
August 16th, 2011, 08:21 AM | #6 |
Smoker
Where in CA are you?
August 16th, 2011, 10:37 AM | #7 | |
August 16th, 2011, 10:38 AM | #8 |
August 16th, 2011, 10:51 AM | #9 |
You are sleeping
Sounds weird, man.
You dive in the clutch yet to see what's poppin'? Is it the oil you are using or something? The clutch is way out at the end of the pull on this bike for me currently.. but I think it's always been like that. I have been beating my clutch into the ground for 10k Mi now. Have you had a crash or anything? Any bent handlebar parts for any reason or tight/pinched lever bolts or pinched cable or something? Good luck in your detective work. When you figure it out I'm sure you'll wonder why you didn't see it sooner. Maybe it just needed some lube or the return spring is going out or something.
<Yeah, it's a 250. LMFAO! Weaksauce |
August 16th, 2011, 11:11 AM | #10 |
Is your clutch perch in the right spot? Having it in the correct spot on the handlebar can lengthen or shorten the cable.
August 16th, 2011, 11:15 AM | #11 | |
August 16th, 2011, 11:20 AM | #12 |
Interesting thought, that didn't occur to me.... but, yes it is in the correct spot. I just ran out to double-check.
August 16th, 2011, 11:23 AM | #13 |
Did you run back as well, or was it more of a saunter?
August 16th, 2011, 11:26 AM | #14 |
I ran... don't have the confidence at the moment to saunter.
August 16th, 2011, 12:03 PM | #15 |
You can always try to micro-adjust it by moving the perch and the angle of the lever. I found when I rotated my lever up the cable got tighter, so I put it back down a bit.
August 16th, 2011, 12:06 PM | #16 |
self wrencher
headshrink,
you have ALL kinds of problem man...maybe you should just "ride it". |
August 16th, 2011, 12:14 PM | #17 |
I would love it.
Engine Problem | Gavin_Coffey | 1986 - 2007 Ninja 250R Tech Talk | 40 | May 6th, 2014 06:30 AM |
[motogp.com] - Dovizioso in top five despite engine problem | Ninjette Newsbot | Motorcycling News | 0 | April 25th, 2014 02:40 PM |
[motogp.com] - Hayden left on sidelines with engine problem | Ninjette Newsbot | Motorcycling News | 0 | October 15th, 2013 03:22 AM |
[motorcyclenews.com - sport] - Checa Crashes After Engine Problem | Ninjette Newsbot | Motorcycling News | 0 | July 20th, 2013 03:30 AM |
[motorcyclenews.com - sport] - Checa Crashes After Engine Problem | Ninjette Newsbot | Motorcycling News | 0 | July 20th, 2013 01:40 AM |
