Old September 4th, 2024, 12:50 PM   #1
[ridermagazine.com] - New and Cool Motorcycle Gear: September 2024
Keep up with the latest in motorcycling gear, parts, accessories, and products with Rider’s New and Cool Motorcycle Gear monthly installments. The items in this list are available now. CFMOTO Oil Change Kits These oil change kits make maintenance on your CFMOTO motorcycle easy by including everything you need to replace the oil and filter. […]
The post New and Cool Motorcycle Gear: September 2024 appeared first on Rider Magazine.
These oil change kits make maintenance on your CFMOTO motorcycle easy by including everything you need to replace the oil and filter. The kits are specifically designed for CFMOTO engines, so you know the oil and filter you’re using are an ideal fit for your motorcycle. The kits include two to three quarts (depending on your model) of 10W-40 synthetic blend oil, an oil filter, gaskets, and O-rings. The kits start at $39.99 for the Papio and 300 models and go up to $49.99 for larger models like the Ibex 800 and 800NK. Single quarts of CFMOTO oil are available for $11.99.
Shop for CFMOTO Oil Change Kits
.advgbbtn-0b6ae421-e009-4b85-ac09-29103afa29ce{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-0b6ae421-e009-4b85-ac09-29103afa29ce:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-0b6ae421-e009-4b85-ac09-29103afa29ce > i {display: none !important;}Barnett Complete Scorpion Clutch Assembly with Lock-Up
Upgrade your 2018-2024 Harley-Davidson with the Barnett Complete Scorpion Clutch Assembly with Lock-Up. This setup results in smoother shifting and more progressive clutch engagement.
It’s designed to fit under the stock primary cover and will add pressure as rpm increases. Using this assembly, surface area is increased, and lever effort is kept to a minimum. It includes multiple spring sets for a variety of pressure options, and the pressure plate is CNC-machined from 6061-T6 billet aluminum. This clutch is made in the USA and is available for $1,541.49.
Shop for Barnett Complete Scorpion Clutch Assembly with Lock-Up
.advgbbtn-e31a7745-ab85-48b4-98eb-17f3c05c7856{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-e31a7745-ab85-48b4-98eb-17f3c05c7856:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-e31a7745-ab85-48b4-98eb-17f3c05c7856 > i {display: none !important;}HJC i91 Modular Helmet
The HJC i91 modular helmet is a new model designed for touring and cruising riders. It features a polycarbonate shell designed using CAD technology, and the interior includes moisture-wicking, antibacterial fabric. HJC’s Advanced Channeling Ventilation system keeps your head cool, and the faceshield is Pinlock-ready.
The HJC i91 also includes a multistep internal sunshield, grooves for wearing glasses, and reflective trim, and it is compatible with the second-generation Smart HJC Bluetooth system. Available in solid colors ($249.99) and graphics ($289.99) in sizes XS-2XL.
Shop for HJC i91 Modular Helmet
.advgbbtn-1516ee07-2cb1-4812-9f9a-0471d32e0bff{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-1516ee07-2cb1-4812-9f9a-0471d32e0bff:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-1516ee07-2cb1-4812-9f9a-0471d32e0bff > i {display: none !important;}Bridgestone Battlecruise H50 Tires
The Bridgestone Battlecruise H50 tires, designed specifically for cruising on big-displacement V-Twins, provide durability, deliver smoother handling, and increase rider comfort for long-distance touring. The tires’ handling capabilities allow large cruisers and tourers to turn smoothly at both low and high speeds to reduce fall-in characteristics in corners, and the optimized rigidity distribution reduces vibrations by absorbing energy inputs from the road surface to prevent fatigue on longer rides. Available in a range of sizes with prices starting at $211.99.
Shop for Bridgestone Battlecruise H50 Tires
.advgbbtn-5558c3ba-6e7f-48c2-b2cc-13c69eb99cba{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-5558c3ba-6e7f-48c2-b2cc-13c69eb99cba:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-5558c3ba-6e7f-48c2-b2cc-13c69eb99cba > i {display: none !important;}MotoBikeJack
Ever drop a heavy bike? Picking it back up can be a real pain. And if you’re by yourself, and you’re in sand or on an uneven surface, it’s even worse. That’s where the MotoBikeJack comes in. Made of powdercoated American steel, the jack weighs less than 8 lb and breaks down into four pieces so it can be stowed in a 15×5-inch bag.
Three shafts fit into the base, and the top shaft has a ratchet with a webbed strap and hook. It can be used to safely and securely lift a 1,000-lb motorcycle from prone to upright. It retails for $228, plus shipping and handling.*
Shop for MotoBikeJack
.advgbbtn-c34d8efa-d5c8-4c3d-aa9a-9a22ebdfcd50{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-c34d8efa-d5c8-4c3d-aa9a-9a22ebdfcd50:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-c34d8efa-d5c8-4c3d-aa9a-9a22ebdfcd50 > i {display: none !important;}Speed and Strength Men’s Lightspeed Mesh Jacket
The Men’s Lightspeed Mesh Jacket by Speed and Strength provides optimal airflow to keep you cool while riding in hot temps. It’s built with a combined Fierce mesh and AR-600 frame, and it’s equipped with removable Vault CE Level 2 shoulder, elbow, and spine protectors. The lockdown waist adjusters allow for a customized fit, and it includes belt loops for attachment to pants, reflective trim for better visibility, and a pocket for storing a faceshield. Available in black, red with black, or gray with black in sizes S-3XL. Visit your local dealer for pricing.
Shop for Speed and Strength Men’s Lightspeed Mesh Jacket
.advgbbtn-f189cc21-c3a9-4bce-9431-39dcd30887a2{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-f189cc21-c3a9-4bce-9431-39dcd30887a2:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-f189cc21-c3a9-4bce-9431-39dcd30887a2 > i {display: none !important;}EagleRider Motorcycle Rentals and Tours
Try a new motorcycle or find a ride while you’re away from home with EagleRider, America’s largest motorcycle rental company with a wide selection of new Harley-Davidson, Yamaha, BMW, Honda, Indian, and other brands. EagleRider has more than 200 locations worldwide and offers more than 100 guided and self-guided tours. Joining Club EagleRider for as little as $29 per month awards credits that can be used for rentals, among other discounts and perks. Until Oct. 31, EagleRider is also renting Harley CVO models at select locations. Visit the EagleRider website to learn more.
Shop for EagleRider Motorcycle Rentals and Tours
.advgbbtn-4359d9d7-bd09-4c9f-9d85-885141100ab5{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-4359d9d7-bd09-4c9f-9d85-885141100ab5:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-4359d9d7-bd09-4c9f-9d85-885141100ab5 > i {display: none !important;}Honda Gold Wing Chrome Trunk Rack
Take your Gold Wing Tour farther than before with Honda’s factory accessory Chrome Trunk Rack. Designed to fit Gold Wings from 2021 to current, the trunk rack is made from chrome-plated steel and allows extra carrying capacity up to 5 lb. As an original Honda product, the rack integrates seamlessly onto the Gold Wing Tour’s trunk and matches the bike’s styling.
The Chrome Trunk Rack can also be installed on non-touring models with Honda’s Trunk Installation Kit and Trunk Installation Color Kit. The rack is available for $449.95 from your local Honda dealer.
Shop for Honda Gold Wing Chrome Trunk Rack
.advgbbtn-72b2f1ce-e20a-4aa8-9d6e-9af4fbc6ac6a{font-size:18px;color:#fff !important;background-color:#cf2e2e !important;margin:0px 0px 0px 0px !important;padding:10px 30px 10px 30px;border-width:1px !important;border-style:none;border-radius:50px !important;}.advgbbtn-72b2f1ce-e20a-4aa8-9d6e-9af4fbc6ac6a:hover{box-shadow:1px 1px 12px 0px #ccc;opacity:1;transition:all 0.2s ease;}.advgbbtn-72b2f1ce-e20a-4aa8-9d6e-9af4fbc6ac6a > i {display: none !important;}The post New and Cool Motorcycle Gear: September 2024 appeared first on Rider Magazine.
[ridermagazine.com] - September 2024 Ninjette Newsbot Motorcycling News 0 August 13th, 2024 02:01 PM
[ridermagazine.com] - New and Cool Motorcycle Gear: August 2024 Ninjette Newsbot Motorcycling News 0 August 1st, 2024 06:01 AM
[ridermagazine.com] - New and Cool Motorcycle Gear: July 2024 Ninjette Newsbot Motorcycling News 0 July 1st, 2024 02:22 PM
[ridermagazine.com] - 2024 Summer Motorcycle Gear Buyers Guide Ninjette Newsbot Motorcycling News 0 June 3rd, 2024 10:00 AM
[ridermagazine.com] - 2024 Spring Motorcycle Gear Buyers Guide Ninjette Newsbot Motorcycling News 0 April 29th, 2024 01:22 PM
