April 15th, 2009, 02:55 PM | #1 |
Join Date: Apr 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 114
Any pics or DIY posts for the Shogun frame slider kit?
Hello all!
I just purchased the Shogun kit, and I was wondering if it comes with detailed instructions for the '08 250 install? Has anyone documented their installation process? I'm worried about the "notching" step in particular since I am not very handy. Thanks! |
April 15th, 2009, 04:19 PM | #2 |
just a n00b
Join Date: Feb 2009 Motorcycle(s): '06 R6/'08 250R Posts: 55
No need for a DIY here......shogun did an excellent job with the install instructions. Here is a copy so you know what you have ahead of you. Feel free to ask here if you have any more questions.
Shogun Manual>>>CLICK<<<< |
April 15th, 2009, 07:03 PM | #3 |
Thanks! I really appreciate it.
April 15th, 2009, 08:01 PM | #4 |
Track Junkie
Join Date: Dec 2008 Motorcycle(s): '08 Ninja 250r Track Bike, DR350 commuter, KDX220 woods bike Posts: 602
Las Escobas -- Track Bikes Save Lives JonBroom.com |
April 16th, 2009, 08:56 AM | #5 |
great kit. I just installed one last week.
April 20th, 2009, 05:09 PM | #6 |
In the posted pdf it mentions acquiring the torque values for the kawasaki parts removed during the install. Does anyone here have those?
Thx! |
April 20th, 2009, 08:29 PM | #7 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
which parts do you need the specs for? i may have missed it, but reading it over quickly, it seems to have them listed in the instructions for the kit.
April 21st, 2009, 08:01 AM | #8 |
Step 3 of the install guide states: Remove shift linkage from shift shaft and take counter shaft cover off. Step 11 is the reverse, mount linkage to shift shaft.
It looks like that component is the "Shift Lever Link Bolt" at 104 in-lb which is about 9 ft-lb? Is that correct? Thanks! |
April 23rd, 2009, 02:20 PM | #9 |
I received the Shogun kit today. It did not come with any instructions for the swing arm spools, the bar end sliders, or the frame sliders. I guess the bar end sliders and spools are self evident, but I am grateful to Sloppy2nds for the manual! Thx!
April 23rd, 2009, 02:29 PM | #10 |
You will have one hell of a time removing the bar ends to install the new sliders. There are several ways but here is how I did it without the use of a torch or heat gun to loosen the red loctite:
Used a drill bit that was slightly larger than the diameter of the bar end screw/stud to drill the phillips head off of the stud itself. From there, the stock bar end will slide off and you are left with the stud stuck into the handlebar ends. I then used some vice grips to tightly clamp onto the stud, then broke them lose with that to remove the stock stud completely. The new shogun bar end sliders go on with the new allen bolt. Swingarm spools are self explanitory. You will have some spacers that go between the slider spool and the swingarm. |
April 24th, 2009, 01:52 PM | #11 |
self wrencher
sold the Intuitive slider and ordered the ShoGun
What do you guys use to cut the sprocket cover with? |
April 24th, 2009, 01:57 PM | #12 |
Track Junkie
hacksaw or a dremel works
April 24th, 2009, 02:07 PM | #13 |
taped mine off to prevent collateral damage then hit it with a hacksaw. Hand power baby!
April 24th, 2009, 02:12 PM | #14 |
What is the cover made of? Metal? Plastic?
Thx! |
April 24th, 2009, 02:32 PM | #15 |
its not plastic, def metal. I had to put some time and elbow grease into mine with my dull hacksaw.
April 28th, 2009, 07:01 AM | #16 |
I've got the Shogun frame sliders installed, along with the bar extenders and spools. Thanks for all the info!
April 29th, 2009, 01:26 AM | #17 |
Join Date: Jan 2009 Motorcycle(s): 2009 Kawasaki Ninja 250R Posts: 83
Nice! got pics?
May 1st, 2009, 07:50 AM | #18 |
self wrencher
hey guys...just got the Shogun slider in. There is no label whatsoever on the kit itself. Even after reading the installation instruction, I'm still uncertain of which side is the actual left and right frame slider rail . they curve differently. Is the more "straight" one is on the right side?
May 1st, 2009, 08:48 AM | #19 |
hold it up to where it will mount at each point. It should be obvious which side is which at that point.
May 4th, 2009, 09:53 AM | #20 |
self wrencher
Thanks guys.. Just finished installing it yesterday.
One thing to note though. The rear engine bolt, it appears I can slide it out with my bare hand (after removing the nut)...stock bolt that is. Is this the case with you guys? |
May 4th, 2009, 10:14 AM | #21 |
I wouldnt worry about it. As long as the bolt goes all the way thru everything that its supposed to go thru, and the nut is properly torqued, have fun.
May 6th, 2009, 11:15 AM | #22 |
Here are some pics of mine installed in case anyone can benefit from them.
May 12th, 2009, 09:25 AM | #23 |
I just got around to taking some pics of the bike, so here are some pics of the sliders.
Shogun frame slider - 08-12 | Bigballsofpaint | Motorcycle-related | 17 | May 10th, 2015 08:11 PM |
Shogun frame slider differences | Bob2010 | 2008 - 2012 Ninja 250R Farkles | 6 | July 20th, 2014 08:17 AM |
Shogun S5 Frame Slider Bolts | MyronGanes | 2008 - 2012 Ninja 250R Tech Talk | 10 | February 20th, 2013 09:53 PM |
Shogun frame slider frame bolt question | crankinaway | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 22nd, 2010 06:46 PM |
