July 20th, 2012, 07:54 PM | #1 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250r Posts: 27
Help needed immediately! Proton signals + stock rear signals - lighting issue.
I have no idea what I am doing.
I took the right fairing off, hooked up the Proton, and that worked fine, but the back right signal (stock) stays on. I tried the signals (still stock) on the left side as a test, worked fine. Can someone please tell me exactly what I need to do to install the Proton's and have the rear, stock signals work right? |
July 21st, 2012, 01:11 AM | #2 |
Ghost Rider
Join Date: Jun 2012 Motorcycle(s): 2012 Ninja 250r Posts: 84
You can check out this DIY for the Protons and see how the installs compare (yours may vary though, so don't worry if there are a few differences).http://www.ninjette.org/forums/showt...ghlight=proton
Just reading that DIY, I would say to take a look at your wiring set up: "Before you proceed, decide how you'd like your blinkers to work. The proton manufacturers thoughtfully provide some options in this department. There's four wires coming out of the blinker: Black, Red, Orange and Yellow. Black is ground and connects to the black/yellow on the bike side. Red is your running light signal. Orange and Yellow are the control wires for the actual 'blink' when given full voltage by the flasher relay. By itself, orange is for a 'normal' blink while yellow gives you a strobe effect. When both orange and yellow are connected to power, you get a fade in/out effect. " Aside from that, if the Protons are LEDs, possibly an issue with the relay? I haven't any experience with Protons though, so I'm not too sure on the possibilities. |
July 21st, 2012, 02:38 AM | #3 |
Join Date: Mar 2012 Motorcycle(s): 2010 Kawasaki Ninja 250r special edition Posts: 286
Your need a diode kit. Modmy250.com
July 23rd, 2012, 09:28 AM | #4 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
July 23rd, 2012, 10:00 AM | #5 | |
You need the TRIDON EP-45 relay flasher you can pick it up auto zone. For about 12$$ |
July 23rd, 2012, 03:57 PM | #6 |
July 25th, 2012, 10:25 AM | #7 |
i want turn signals, stock rear.. | MikeJames21 | Items Wanted | 3 | October 15th, 2011 01:31 PM |
Need help with Bike Monkey taillight and led proton flush mount turn signals | romeo127 | 2008 - 2012 Ninja 250R Tech Talk | 1 | November 23rd, 2010 01:33 PM |
proton flushmount turn signals help | sherjay | 2008 - 2012 Ninja 250R Farkles | 5 | July 6th, 2010 04:14 PM |
