Old April 4th, 2018, 01:30 PM   #1
[motorcycle.com] - 2019 Honda CB300R Announced for America
It took a while longer than we had hoped, but American Honda has finally announced the new Neo-Sports Café-inspired CB300R is coming to the United States as a 2019 model. At $4,649 for the base model and $4,949 with ABS, the 2019 Honda CB300R is priced $300 higher than the 2018 CB300F which it will replace.
For that extra three Benjamins, you get the Neo-Sports Café styling resembling the new CB1000R, following an industry trend of a modern take on old-school aesthetics. The round headlight, radiator guards, two-step seat all look similar to the CB1000R. The sculpted fuel tank also shares the same shape as the CB300R’s big brother, though it does sacrifice some volume, carrying just 2.7 gallons of fuel (compared to the CB300F’s 3.4-gallon tank).
The CB300R (right) shares a visual aesthetic with the bigger CB1000R that Honda calls a “Neo-Sports Café” design.
The engine remains the same 286cc Single found in the CB300F (and the faired CBR300R). For the CB300R, Honda refined the intake path and added a new underslung exhaust with a dual-chamber muffler. Along with a significant weight reduction (a claimed 317 pounds, down from the CB300F’s claimed 348 pounds), Honda claims the new intake helped improve initial acceleration by 4%.
While the CB300F had the frame and pivot plates as a single unit, the CB300R uses a new high-tensile steel tube frame with separate steel pivot plate. According to Honda, this new design reduces the amount of stress transferred from the rear wheel to the main frame between the head and seat rail. The design also allowed Honda to optimize the strength of each piece separately, using thinner materials and reducing weight.
The swingarm is also new, with thicker material at the cross member but tapering towards the rear axle. The new 17-inch aluminum wheels with five Y-shaped spokes resembles the design of the larger CB1000R.
The suspension system is comprised of a 41mm inverted fork and a revised single rear shock with seven steps of spring preload adjustment. Nissin supplies the radial-mount four piston front brake caliper and 296mm front disc and the rear wheel’s 220mm disc and single-pot caliper. An IMU-controlled two-channel ABS is an available option.
Other features a new full-function LCD display, full LED lighting, and aluminum rider and passenger foot-peg hangers.
The 2019 Honda CB300R will be offered in two colors: Chromosphere Red and Matte Gray Metallic. Expect to see the CB300R in showrooms in July.
2018 Honda CB300R SpecificationsMSRP$4,649 ($4,949 with ABS)Type286cc liquid-cooled 20º single-cylinder four-strokeValve TrainDOHC; four valves per cyclinderBore x Stroke76.0mm x 63.0mmCompression Ratio10.7:1InductionFuel injection w/ 38mm throttle bodyIgnitionFull transistorizedStarterElectricTransmissionManual w/ six speedsClutchMultiplate wetFinal DriveChainFront41mm telescopic fork; 5.1 in. travelRearPro-Link single shock; 4.2 in. travelFrontHydraulic w/ single 296mm disc; ABS optonalRearHydraulic w/ single 220mm disc; ABS optionalFront110/70-17Rear150/60-17Rake (Caster Angle)24.7ºTrail93mm (3.7 in.)Length79.5 in.Width31.7 in.Height41.3 in.Seat Height31.5 in.Ground Clearance5.9 in.Wheelbase53.3 in.Fuel Capacity2.7 gal.ColorChromosphere Red; Matte Gray MetallicCurb Weight313 lbs. (317 lbs. with ABS)The post 2019 Honda CB300R Announced for America appeared first on Motorcycle.com.
Click here for full story...
[motorcycle.com] - 2019 MotoE World Cup Teams Announced Ninjette Newsbot Motorcycling News 0 March 19th, 2018 09:30 AM
[motorcycle.com] - Canadian Content: Kawasaki Z900RS Cafe and Honda CB300R Ninjette Newsbot Motorcycling News 0 February 23rd, 2018 04:41 PM
[motorcycle.com] - 2019 Honda CB300R Confirmed for Canada Ninjette Newsbot Motorcycling News 0 January 9th, 2018 05:01 PM
[motorcycle.com] - New Harley-Davidson 48X and Pan America for 2019? Ninjette Newsbot Motorcycling News 0 December 20th, 2017 05:51 PM
[motorcycle.com] - First Look: 2018 Honda CB125R And CB300R Ninjette Newsbot Motorcycling News 0 November 6th, 2017 08:51 PM
