August 5th, 2014, 05:17 PM | #1 |
Bike starts better cold than on a hot day?
My 2009 250 is having a rough time starting. Not early in the day however... It has the most issues in hot weather, or after it has already been warmed up on a short ride. I'll start it up with or without choke and it'll struggle. I'll also hear a strange clicking noise coming from the front. It almost sounds like an electrical click... I've included a link to a video.
When I start the bike in the morning (usually without the choke), it'll start right up without the clicking noise. I've replaced the air filter, charged and tested the battery, cleaned and adjusted the chain, and ran some seafoam through the gas... Nothing seems to fix it. I've searched online plenty and found nothing. Any ideas?
Link to original page on YouTube. |
August 5th, 2014, 06:29 PM | #2 |
MOTM - Mar '13, Jun '14
It's where you live, U DA HO!
August 5th, 2014, 10:55 PM | #3 |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
sounds like it needs checking the valves...
If noone has tried it before, I will !!! |
August 6th, 2014, 08:15 AM | #4 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
The clicking noise is your cam chain slapping around, also known as the Kawi-tick. My 250R ticked a hell of a whole lot until I installed a manual CCT on it. You could also remove and reset the stock CCT but the tick may eventually come back.
August 6th, 2014, 08:48 AM | #5 |
Have you made any carb adjustments?
Stock air filter? What does it idle at when hot? |
August 6th, 2014, 05:31 PM | #6 |
I thought if it was the CCT it would be constant. The bike quiets down after a few seconds... but I'm more worried about the trouble starting than the noise... just thought they might have been related.
And to answer the other questions, I'm using the stock air filter and it idles at about 1300-1400 RPM after warm. I have not done anything to the carbs. |
August 11th, 2014, 12:14 PM | #7 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
When was the last valve adjustment?
August 11th, 2014, 12:16 PM | #8 |
August 11th, 2014, 12:20 PM | #9 |
500??
Ohh I just took another look at your video and you're not even at 7000. Valve clearance check is at 7500 so you could be due early? |
Bike hates the cold starts. | xomilin | 1986 - 2007 Ninja 250R Tech Talk | 23 | November 3rd, 2014 02:27 PM |
cold starts | gkarats | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 30th, 2013 02:14 PM |
Engine dies during cold starts, normal? | caineroad | 2008 - 2012 Ninja 250R Tech Talk | 9 | October 24th, 2013 04:10 AM |
Track day, Race starts and a funny bike? | 5evenz | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 4th, 2013 07:25 PM |
5trstt3dygxrgctbrģ cold tires on a cold day | thomason2wheels | !%@*#$%!)@#&!%@ I crashed! | 6 | December 1st, 2012 08:34 AM |
