Old May 30th, 2018, 06:05 PM   #41
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Originally Posted by Nextbesthing View Post
Thanks. I might experiment a bit.
Man I am jealous. I sure would like to have a bike or 2 for projects...I would really love to do up a streetfighter and then use the other one to do every single mod there is on the wiki so I can see just what the differences are...
Old May 30th, 2018, 09:37 PM   #42
Nextbesthing
Nextbesthing's Avatar
Motorcycle(s): 95 ninja 250, 08 KLR 650
I will say most of my knowledge of motorcycle mechanics have come from these ninjas even though I had owned many bikes before. So far my only "mods" are the rear fender/turn signals the cush drive shims, washers on my needles and the battery box mod. I'd be curious to hear if I missed any obvious ones.
Nextbesthing is offline   Reply With Quote
Old May 30th, 2018, 09:40 PM   #43
jcgss77
jcgss77's Avatar
Yeah, That's what I am talking about! I have done all of those except shimming the cush drive. I am mostly interested in stiffening up the suspension. I would really like to get a 300, but those things are SO hard to find a deal on. I absolutely WILL NOT pay retail for a vehicle.
Old May 30th, 2018, 10:08 PM   #44
Nextbesthing
Buy the 300 shock it's 50 times better than the pregen
Old May 31st, 2018, 08:12 AM   #45
jcgss77
jcgss77's Avatar
How so?
Old May 31st, 2018, 08:35 AM   #46
How so?
Has:
- preload adjustment
- stiffer spring for riders heavier than 135-lbs
- stiffer damping for better control
Old May 31st, 2018, 08:46 AM   #47
Nextbesthing
Yeah. It's the first thing I would do if I were to buy another pregen. It's like riding a new bike and thanks to the trusty center stand it only takes about a half hour even if you suck at using tools like I do.
Old June 2nd, 2018, 08:08 AM   #48
MR2Aaron
Motorcycle(s): 2003 Kawasaki Ninja 250
Bumping this because I have a question. Is there a method for creating a gas "IV" type deal, just a small bottle to run the engine rather than the gas tank. I was thinking about attaching a petcock to an appropriate bottle or something with some old inner tube as a gasket... I have seen similar things and was wondering if they work with a vacuum operated carb.
I believe that Motion Pro also makes a tool that is basically what you describe. A ~1 liter bottle that you fill with gas and hang up somewhere to get the engine running without the fuel tank in the way. It's meant to be used for syncing carbs and such.
You can also just use a really long hose and put the actual fuel tank on a table or something next to the bike, which has the advantage of costing almost nothing, vs like $100 for the fancy Motion Pro bottle.
MR2Aaron is offline   Reply With Quote
Old June 2nd, 2018, 09:30 AM   #49
Ram Jet
Ram Jet's Avatar
Here's something I made out of a Brakleen airisol can. I simply drilled-out the fitting for the spray nozzle and soldered in a brass fitting.
Bill
Old June 3rd, 2018, 09:57 AM   #50
Nextbesthing
Thanks guys. I thought it was something moderately common. I just have a completely dry gas tank and didn't want to put gas in it just to have it go bad. As you can tell by the age of this thread it takes me a long time to do things.
Old June 5th, 2018, 04:47 PM   #51
Nextbesthing
How bad is too bad for diaphragms? It has a bit of deformation. Looks fine just a bit wavy in one spot. I tried to photograph it, obviously it was impossible.
Old June 5th, 2018, 05:25 PM   #52
Nextbesthing
How do I make these ducatiman clean? I wish I had gotten the before pics but you might be able to tell the state of things by the jets.
Old June 5th, 2018, 05:29 PM   #53
Nextbesthing
Dirty.
Old June 5th, 2018, 07:47 PM   #54
You're gonna need:
- heavier-duty industrial chemicals than you've been using
- ultrasonic cleaner
- soda-blasting equipment for small parts
- decades of experience on thousands of carbs
Old June 5th, 2018, 08:41 PM   #55
jcgss77
jcgss77's Avatar
You're gonna need:
In other words, you need a Ducatiman.
Old June 6th, 2018, 05:20 AM   #56
Nextbesthing
I'm just shooting for close. So far they have been pinesol soaked and blasted with carb cleaner with a toothbrush for the really caked on stuff. This rack of carburetors will most likely be sitting indefinitely as a spare. I want them cleaned just about as good as they can get to prevent any sort of rust or degradation. Has anyone tried those cheap amazon ultrasonic cleaners? Looking at 6 liters but my tool wish list is so long.
Old August 7th, 2018, 02:03 PM   #57
Nextbesthing
What are you!?!
Old August 7th, 2018, 02:29 PM   #58
Ceeloo Yello
Motorcycle(s): 250
That's constant 12 volts normally not connected to anything.
Old August 7th, 2018, 04:09 PM   #59
Nextbesthing
Thanks, I figured it was headlight related but I must have messed something else up as far as that goes...
Good news everyone, the 95 does run BUT I'm leaking from my float bowls (I think). That and some other odds and ends and we should be riding once I get some new rubber and the light situation figured out.
Old August 7th, 2018, 06:23 PM   #60
Ram Jet
Ram Jet's Avatar
What are you!?!
I used those "dumb dumb" terminals to power my temperature gauge which requires constant power even with the ignition is off.
Bill
Old August 8th, 2018, 04:59 PM   #61
Nextbesthing
Will newgen float bowl gaskets fit my pregen, I keep looking for answers but nothing is consistent. Some say yes, some say no.
Old August 8th, 2018, 06:20 PM   #62
Ceeloo Yello
Motorcycle(s): 250
My understanding is that the carbs are the same, just jetted differently.
Old August 8th, 2018, 08:18 PM   #63
Nextbesthing
That's my understanding as well. Same part numbers.
Old August 9th, 2018, 11:09 AM   #64
Ceeloo Yello
Motorcycle(s): 250
I went cheap and am ordering 4 gaskets for $6 from ali. Just gotta wait another 20 days or so to see if worth it
Old August 9th, 2018, 11:19 AM   #65
Nextbesthing
Now that I have proof of life I want them yesterday... eBay has some pretty cheap options.
Old August 9th, 2018, 12:10 PM   #66
Ceeloo Yello
Motorcycle(s): 250
Gotta be careful with amazon and ebay sometimes ends up being drop shipped from china anyway.
Old August 9th, 2018, 04:41 PM   #67
Nextbesthing
Lol yeah, bought a lot of chinesium over the years.
Old August 14th, 2018, 02:49 PM   #68
Nextbesthing
Good fixes for coolant leaks?? The outside hardline that goes from my radiator to the water pump is leaking where it connects to the pump. I replaced that o-ring with a non oem one with the same fit. I put some regular non hardening gasket maker on after that failed me in a fairly significant bead behind the o-ring, worked until the engine got hot and then didnt. Next someone at work suggested "blue monster" not it's real name but allegedly "if that doesn't work, you're effed." Another non hardening gasket compound, with the same result. I'm tired of draining my cooling system if anyone has a better suggestion. Might try and find a thicker smaller diameter o-ring that will fit more snugly also might try a double o-ring, one in the groove and a bit wider one after the groove. All input welcome, especially why I shouldn't do that, because it seems wrong.
Old August 14th, 2018, 04:55 PM   #69
Ram Jet
Ram Jet's Avatar
Dump the "O" ring altogether. Go to your auto parts store and buy some Fel Pro gasket material. I think Autozone might have some. While you're there pick-up a small can of Permatex High Tack gasket sealer. Make you own gasket, apply the High Tack to both mating surfaces and both sides of the home made gasket. Done deal. I did this in several places on my 82' Honda FT500 Ascot. Works well.
Cheers,
Bill
Old August 14th, 2018, 05:37 PM   #70
Nextbesthing
Okay then, sounds like a plan. Thanks Bill. Like they say, fourth times the charm.
Old August 14th, 2018, 05:57 PM   #71
Ceeloo Yello
Motorcycle(s): 250
I think you should just break down and get the correct o-ring from the dealer - no sealant required.
Old August 15th, 2018, 07:09 AM   #72
Did you clean the opening to remove any corrosion? If not cleaned well it will leak. It needs to be smooth and clean.
I'd try another (preferably correct) o-ring with a dab of silicone lube (not caulk) from the plumbing department.
I've replaced leaking coolant seals before, and never needed any additional sealant if everything else is correct.
Old August 15th, 2018, 11:45 AM   #73
Ram Jet
Ram Jet's Avatar
It's your money and time. Permatex High Tack brother. Stay away from that silicone rubber crap unless your trying to seal the timing chain cover to oil pan on a big or small block Chevy. By the way the Permatex cleans-up with lacquer thinner. I've used it to seal the cylinder heads on a Kaw 500 triple (head gasket removed), the exhaust headers on most every motorcycle I've ever owned.
Bill
Old August 15th, 2018, 12:21 PM   #74
Bill
Ya, the stuff I'm taking about isn't a caulk or sealer - just a lube. Just something to help it slide into place without snagging the seal. Some people like to use KY Jelly, if you have that on hand...
Unless there are major problems you should be able to get it to seal with the proper o-ring and a clean surface.
Old August 15th, 2018, 12:51 PM   #75
Ceeloo Yello
Motorcycle(s): 250
Heck I just spray the tube and o-ring with silicone spray. I would make sure to install the water pump side 1st and make sure it is seated properly then attach the radiator side making sure the water pump side stays seated properly.
Old August 15th, 2018, 01:09 PM   #76
Ram Jet
Ram Jet's Avatar
Hey KY Jelly! What temperature is is with able to withstand? I've gotten it pretty hot before but never measured it. A friend of mine asked if I smoked after sex, I told him that I didn't know because I never looked.
Bill
Old August 15th, 2018, 01:20 PM   #77
Bill
It can definitely withstand extreme heat and pressure.
Old August 16th, 2018, 06:44 PM   #78
Nextbesthing
So when my girlfriend asks why I have a bottle of KY jelly in my tool box I'm coming to you for backup.
It stopped leaking for now, no drips at all when I parked this afternoon. I drained the water out and put real coolant in so we will see if that eats away at whatever blue goop we used to seal it. My next checklist item is troubleshooting my headlight. How about fairing stays? Would it be better to buy straight ones or should I try my luck at bending the ones I have???
Last futzed with by Nextbesthing; August 16th, 2018 at 06:56 PM. Reason: Mas informacion.
Old August 16th, 2018, 07:32 PM   #79
Ram Jet
Ram Jet's Avatar
When I bought my 07' Ninja a year ago I tore it apart undoing what damage the previous owner did and performing the maintenance he didn't. When I went to install the upper fairing I was having fits - the bolt holes didn't line up. I then realized that I bought a wrecked bike. At that point I realized that the upper fairing was bent from the crash. I bought a used straight one on eBay. I couldn't imagine trying to straighten out the upper fairing bracket. I guess it could be done with a torch and a jig to line it up but it was beyond my capabilities. The upper fairing bracket isn't easy to find since most squids usually smash-up the upper fairing and bracket.
Bill
Old August 17th, 2018, 02:30 AM   #80
Nextbesthing
Yeah, this was an MSF training bike, nothing straight about her.
New to the 250! Pics of my older projects. Monarch New Members 11 February 11th, 2016 06:06 PM
[motorcycle.com] - Top 10 Winter Maintenance Projects Ninjette Newsbot Motorcycling News 0 January 21st, 2016 08:22 PM
Bike is grounded for a few days. Need some projects. Sykes92 2008 - 2012 Ninja 250R Tech Talk 4 December 31st, 2013 07:22 PM
pics of my other projects Rollingmenace Pictures 1 October 1st, 2012 08:51 PM
[topix.net] - Zacks Projects Harley 2nd Quarter Profits Up Ninjette Newsbot Motorcycling News 0 July 19th, 2010 01:10 PM
